Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Putting a Toolbar inside an EditorPart
Putting a Toolbar inside an EditorPart [message #432797] Fri, 26 March 2004 19:42 Go to next message
David Havrda is currently offline David HavrdaFriend
I have a plug-in and I wish to put a ToolBar inside of an Editor/EditorPart?
I do NOT want to append menu items to the existing menu nor do I wish to
have a context menu. I want a BAR style ToolBar to show up in my editor
area. Any help would be appreciated. Below is a snippet of code I have
tried. I found some of it elsewhere on the forums.
This is a piece of code from the createPartControl(Composite parent) method
of my editor.
properties is a Composite which is a child of parent arguement.
Decorations decs = new Decorations(properties, SWT.DIALOG_TRIM);
layout = new GridLayout();
decs.setLayout(layout);
decs.setBounds(20, 30, 200, 30);
Menu menu = new Menu(decs, SWT.BAR);
decs.setMenuBar(menu);
MenuItem item = new MenuItem(menu, SWT.PUSH);
item.setText("item");
Re: Putting a Toolbar inside an EditorPart [message #432800 is a reply to message #432797] Fri, 26 March 2004 20:59 Go to previous messageGo to next message
Originally posted by: paull.NOSPAMcodetelligence.com
I'm not exactly sure what you want to accomplish. Did you look at
contributeToToolBar() in your editor contributor?
Paul Lever
www.codetelligence.com
"David Havrda" <dhavrda@motive.com> wrote in message
news:c420q7$jcn$1@eclipse.org...
Editor/EditorPart?
method
> of my editor.
Re: Putting a Toolbar inside an EditorPart [message #432801 is a reply to message #432800] Fri, 26 March 2004 21:10 Go to previous messageGo to next message
I want to have a toolbar actually reside in the editor area.
"Paul L" <paull@NOSPAMcodetelligence.com> wrote in message
news:c425cv$odv$1@eclipse.org...
> Paul Lever
> Editor/EditorPart?
> method
> > of my editor.
Re: Putting a Toolbar inside an EditorPart [message #432803 is a reply to message #432801] Fri, 26 March 2004 21:31 Go to previous messageGo to next message
So are you looking for a floating toolbar? Not that I know how to do that.
Paul Lever
news:c425va$p5j$1@eclipse.org...
> > Paul Lever
> > Editor/EditorPart?
to
editor
have
> > method
> > > of my editor.
Re: Putting a Toolbar inside an EditorPart [message #432805 is a reply to message #432803] Fri, 26 March 2004 21:54 Go to previous messageGo to next message
No fixed is fine. Say my editor area has some controls at the top and then
below that resides a fixed toolbar. I know the layout sounds funny but that
is my task.
news:c4278f$qjo$1@eclipse.org...
> Paul Lever
> > > Paul Lever
> > > Editor/EditorPart?
wish
> to
> editor
> have
> > > method
> > > > of my editor.
Re: Putting a Toolbar inside an EditorPart [message #432806 is a reply to message #432805] Sat, 27 March 2004 01:03 Go to previous message
James Willans is currently offline James WillansFriend
David,
I'm not sure it helps, but is something like this done in GEF where the
palette is integrated into the editor? You might want to take a look at
the code and see how that is done.
James
> is my task.
> > Paul Lever
> > > > Paul Lever
> > > > Editor/EditorPart?
> wish
> > to
> > editor
> > have
> > > > method
> > > > > of my editor.
Previous Topic:Newbie trouble: dynamic wizard controls
Next Topic:true SYSTEM_MODAL behaviour? : additional fact
Current Time: Wed May 23 05:12:56 GMT 2018
Powered by FUDForum. Page generated in 0.02625 seconds
