Re: CTRL+F6 not working on RCP [message #432612 is a reply to message #432566] |
Tue, 14 June 2005 02:03 |
Michael Permana Messages: 23 Registered: July 2009 |
Junior Member |
I am having problem with F5, but I cfan work around by specifying some
random schemeId,
I have problems woth Ctrl-M and Ctrl-N, other keys seems to be able to bind
properly
any one has clues why certain key can'tbebinded ?
I have an RCP product, I'm trying to bind Ctrl-N, and F5 to my action, but
it doesn't seem to work. I can bind other sequences.
I realized the F5 is usually used for refresh, I am trying to create my
refresh action. Should I try it differently instead of using key binding in
plugin.xml ?
Here's my plugin.xml snippet:
<key commandId="com.siebel.analytics.jobmanager.rcp.ConfigurationOptions "
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
sequence="CTRL+N"> </key>
<key
commandId="com.siebel.analytics.jobmanager.rcp.RefreshJobList "
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration" <-- IF THIS IS
CHANGED, F5 CAN BE BINDED
sequence="F5">
</key>
"Don" <don@inpowersoft.com> wrote in message
news:d8ksau$opd$1@news.eclipse.org...
> Do I have to tie the F6 to the switch editor action and contribute to the
> main menu manually?
> thanks
> "Eugene Ostroukhov" <eostroukhov@gmail.com> wrote in message
> news:d8j6a5$in7$1@news.eclipse.org...
> >I had the same problem. You should add the respective actions to the main
> >menu.
> > news:d8id2g$str$1@news.eclipse.org...
> >> All,
> >> we have been quite successful in using RCP for a very complex
> >> application.
> >> But the CRTL+F6 keys for the workbench which is to switch Editor does
not
> >> work.
> >> We have a custom Editor type that is derived from EditorPart directly.
> >> Any ideas?
> >> Thanks
> >> -dy
FUDForum. Page generated in 0.03183 seconds
