Home » Eclipse Projects » Rich Client Platform (RCP) » Perspective customization questions
Perspective customization questions [message #431971] Wed, 25 May 2005 23:37 Go to next message
Mark Powell is currently offline Mark PowellFriend
Hi group,
There's a couple of things that I'd like to do with my RCP app that aren't
yet obvious to me how to do or even if there's a way to do. Both things are
in the area of customization of how the perspective selection toolbar
appears when you first launch the application.
First, I'd like to programmatically be able to turn off the text next to the
perspective icons. I want this behavior to be the default behavior for my
app.
Second, I'd like to put the icons for all of the perspectives that I define
in the toolbar by default. I don't want the user to have to "Show
perspective" to get each one for the first time, or even to use the
short-list menu to get one for the first time. I want the button for each
perspective visible the from the first moment they see the workbench appear.
Thanks in advance for any advice or information about whether the platform
API currently supports/would be able to support these desirements.
Mark Powell
JPL
Re: Perspective customization questions [message #432111 is a reply to message #431971] Tue, 31 May 2005 17:03 Go to previous messageGo to next message
Nick Edgar is currently offline Nick EdgarFriend
Hi Mark,
> app.
See http://eclipse.org/rcp/faq.html#customPrefs
and specify the following in the perspective_customization.ini file:
org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false
Doing it this way is preferable to changing the value programmatically,
since it allows different product entry points to have different
defaults. Of course, you may still allow the user to change the value
by using:
PlatformUI.getPreferenceStore().
setValue(IWorkbenchPreferenceConstants.SHOW_TEXT_ON_PERSPECT IVE_BAR, x);
This is not currently well supported, but is something I'd like to
address for 3.2. See the following for a workaround:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=84226
Another approach is to use a custom window layout, with your own button
bar for switching between some well-known perspectives, rather than
using the built-in perspective bar. See
WorkbenchWindowAdvisor.createWindowContents(Shell).
HTH,
Nick
Re: Perspective customization questions [message #432155 is a reply to message #431971] Fri, 03 June 2005 15:14 Go to previous message
nielinjie is currently offline nielinjieFriend
Mark Powell wrote:
> Hi group,
> app.
I use following solution in my rcp, through looks foolish, but works
public void postWindowOpen(IWorkbenchWindowConfigurer configurer) {
super.postWindowOpen(configurer);
IWorkbench wb = configurer.getWindow().getWorkbench();
try {
wb.showPerspective("PerspectiveA.Id",configurer.getWindow());
wb.showPerspective("PerspectiveB.Id",configurer.getWindow());
wb.showPerspective("PerspectiveDefault",configurer.getWindow());
} catch (WorkbenchException e) {
e.printStackTrace();
> Mark Powell
> JPL
Previous Topic:drag and drop of views in eclipse
Next Topic:JDBC type 2 drivers & plugins?
Current Time: Mon May 21 15:07:26 GMT 2018
Powered by FUDForum. Page generated in 0.03198 seconds
