Home » Modeling » EMF » EMF+Teneo+ORM+JPA EAttribute with multi-valued eenum type
EMF+Teneo+ORM+JPA EAttribute with multi-valued eenum type [message #431912] Wed, 29 July 2009 11:24 Go to next message
Originally posted by: jan.pfeil.pfeilweb.de
--nextPart3452683.hk5qWAgFLt
Content-Type: text/plain; charset="US-ASCII"
Content-Transfer-Encoding: 7Bit
Hi experts,
I'm stuck with my ecore model while generating the ORM mapping for
eclipselink. I use an attribute of type EEnum with upperBound set to -1.
This gives me a perfect model so far, but when it comes to orm.xml the
attribute is not generated.
For demonstration I have modified the well known library model. See the
attached file books.ecore and notice the EAttribute tags. Tags is a copy of
the category attribute with upperBound set to -1 for multi-value behavior.
When persisting an instance as xml by using the generated model editor I get
something like this:
<Book>
<tags>Mystery</tags>
<tags>Biography</tags>
</Book>
Looks good to me. Now I use the GenerateORM class to generate the orm.xml
file (using the teneo eclipse plugin). What I get is this:
<orm:entity class="library.impl.BookImpl" name="Book">
<orm:table name="book"/>
<orm:inheritance strategy="JOINED"/>
<orm:attributes>
<orm:basic fetch="EAGER" name="title" optional="false"/>
<orm:basic fetch="EAGER" name="pages" optional="false"/>
<orm:basic fetch="EAGER" name="category" optional="false">
<orm:enumerated>ORDINAL</orm:enumerated>
</orm:basic>
</orm:entity>
So you can see the category attribute gets generated but the tags attribute
is completely missing. As soon as I change upperBound to 1 (tags
attribute) I get the same result as for category. So I infer it has
something to do with that.
Is it possible to use such a model with ORM persistence? Is there another
solution? What am I missing?
Ciao,
Jan
Content-Type: application/xml; name="books.ecore"
Content-Description:
Content-Disposition: attachment; filename="books.ecore"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPGVjb3Jl OkVQYWNrYWdlIHht
aTp2ZXJzaW9uPSIyLjAiCiAgICB4bWxuczp4bWk9Imh0dHA6Ly93d3cub21n Lm9yZy9YTUkiIHht
bG5zOnhzaT0iaHR0cDovL3d3dy53My5vcmcvMjAwMS9YTUxTY2hlbWEtaW5z dGFuY2UiCiAgICB4
bWxuczplY29yZT0iaHR0cDovL3d3dy5lY2xpcHNlLm9yZy9lbWYvMjAwMi9F Y29yZSIgbmFtZT0i
bGlicmFyeSIKICAgIG5zVVJJPSJodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2Vt Zi90ZW5lby9zYW1w
bGVzL2VtZi9zYW1wbGUvTGlicmFyeSIgbnNQcmVmaXg9ImxpYnJhcnkiPgog IDxlQ2xhc3NpZmll
cnMgeHNpOnR5cGU9ImVjb3JlOkVDbGFzcyIgbmFtZT0iQm9vayI+CiAgICA8 ZUFubm90YXRpb25z
IHNvdXJjZT0iaHR0cDovLy9vcmcvZWNsaXBzZS9lbWYvZWNvcmUvdXRpbC9F eHRlbmRlZE1ldGFE
YXRhIj4KICAgICAgPGRldGFpbHMga2V5PSJuYW1lIiB2YWx1ZT0iQm9vayIv PgogICAgICA8ZGV0
YWlscyBrZXk9ImtpbmQiIHZhbHVlPSJlbGVtZW50T25seSIvPgogICAgPC9l QW5ub3RhdGlvbnM+
CiAgICA8ZVN0cnVjdHVyYWxGZWF0dXJlcyB4c2k6dHlwZT0iZWNvcmU6RUF0 dHJpYnV0ZSIgbmFt
ZT0idGl0bGUiIHVuaXF1ZT0iZmFsc2UiIGxvd2VyQm91bmQ9IjEiCiAgICAg ICAgZVR5cGU9ImVj
b3JlOkVEYXRhVHlwZSBodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2VtZi8yMDAz L1hNTFR5cGUjLy9T
dHJpbmciPgogICAgICA8ZUFubm90YXRpb25zIHNvdXJjZT0iaHR0cDovLy9v cmcvZWNsaXBzZS9l
bWYvZWNvcmUvdXRpbC9FeHRlbmRlZE1ldGFEYXRhIj4KICAgICAgICA8ZGV0 YWlscyBrZXk9Imtp
bmQiIHZhbHVlPSJlbGVtZW50Ii8+CiAgICAgICAgPGRldGFpbHMga2V5PSJu YW1lIiB2YWx1ZT0i
dGl0bGUiLz4KICAgICAgPC9lQW5ub3RhdGlvbnM+CiAgICA8L2VTdHJ1Y3R1 cmFsRmVhdHVyZXM+
ZT0icGFnZXMiIHVuaXF1ZT0iZmFsc2UiIGxvd2VyQm91bmQ9IjEiCiAgICAg ICAgZVR5cGU9ImVj
b3JlOkVEYXRhVHlwZSBodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2VtZi8yMDAz L1hNTFR5cGUjLy9J
bnQiIHVuc2V0dGFibGU9InRydWUiPgogICAgICA8ZUFubm90YXRpb25zIHNv dXJjZT0iaHR0cDov
Ly9vcmcvZWNsaXBzZS9lbWYvZWNvcmUvdXRpbC9FeHRlbmRlZE1ldGFEYXRh Ij4KICAgICAgICA8
ZGV0YWlscyBrZXk9ImtpbmQiIHZhbHVlPSJlbGVtZW50Ii8+CiAgICAgICAg PGRldGFpbHMga2V5
PSJuYW1lIiB2YWx1ZT0icGFnZXMiLz4KICAgICAgPC9lQW5ub3RhdGlvbnM+ CiAgICA8L2VTdHJ1
Y3R1cmFsRmVhdHVyZXM+CiAgICA8ZVN0cnVjdHVyYWxGZWF0dXJlcyB4c2k6 dHlwZT0iZWNvcmU6
RUF0dHJpYnV0ZSIgbmFtZT0iY2F0ZWdvcnkiIHVuaXF1ZT0iZmFsc2UiCiAg ICAgICAgbG93ZXJC
b3VuZD0iMSIgZVR5cGU9IiMvL0Jvb2tDYXRlZ29yeSIgZGVmYXVsdFZhbHVl TGl0ZXJhbD0iTXlz
dGVyeSIgdW5zZXR0YWJsZT0idHJ1ZSI+CiAgICAgIDxlQW5ub3RhdGlvbnMg c291cmNlPSJ0ZW5l
by5qcGEiPgogICAgICAgIDxkZXRhaWxzIGtleT0iYXBwaW5mbyIgdmFsdWU9 IkBFbnVtZXJhdGVk
KE9SRElOQUwpIi8+CiAgICAgIDwvZUFubm90YXRpb25zPgogICAgICA8ZUFu bm90YXRpb25zIHNv
dXJjZT0iaHR0cDovLy9vcmcvZWNsaXBzZS9lbWYvZWNvcmUvdXRpbC9FeHRl bmRlZE1ldGFEYXRh
Ij4KICAgICAgICA8ZGV0YWlscyBrZXk9ImtpbmQiIHZhbHVlPSJlbGVtZW50 Ii8+CiAgICAgICAg
PGRldGFpbHMga2V5PSJuYW1lIiB2YWx1ZT0iY2F0ZWdvcnkiLz4KICAgICAg PC9lQW5ub3RhdGlv
bnM+CiAgICA8L2VTdHJ1Y3R1cmFsRmVhdHVyZXM+CiAgICA8ZVN0cnVjdHVy YWxGZWF0dXJlcyB4
c2k6dHlwZT0iZWNvcmU6RUF0dHJpYnV0ZSIgbmFtZT0idGFncyIgdW5pcXVl PSJmYWxzZSIgdXBw
ZXJCb3VuZD0iLTEiCiAgICAgICAgZVR5cGU9IiMvL0Jvb2tDYXRlZ29yeSIg ZGVmYXVsdFZhbHVl
TGl0ZXJhbD0iTXlzdGVyeSIgdW5zZXR0YWJsZT0idHJ1ZSI+CiAgICAgIDxl QW5ub3RhdGlvbnMg
c291cmNlPSJ0ZW5lby5qcGEiPgogICAgICAgIDxkZXRhaWxzIGtleT0iYXBw aW5mbyIgdmFsdWU9
IkBFbnVtZXJhdGVkKE9SRElOQUwpIi8+CiAgICAgIDwvZUFubm90YXRpb25z PgogICAgICA8ZUFu
bm90YXRpb25zIHNvdXJjZT0iaHR0cDovLy9vcmcvZWNsaXBzZS9lbWYvZWNv cmUvdXRpbC9FeHRl
bmRlZE1ldGFEYXRhIj4KICAgICAgICA8ZGV0YWlscyBrZXk9ImtpbmQiIHZh bHVlPSJlbGVtZW50
Ii8+CiAgICAgICAgPGRldGFpbHMga2V5PSJuYW1lIiB2YWx1ZT0iY2F0ZWdv cnkiLz4KICAgICAg
PC9lQW5ub3RhdGlvbnM+CiAgICA8L2VTdHJ1Y3R1cmFsRmVhdHVyZXM+CiAg ICA8ZVN0cnVjdHVy
YWxGZWF0dXJlcyB4c2k6dHlwZT0iZWNvcmU6RVJlZmVyZW5jZSIgbmFtZT0i YXV0aG9yIiBsb3dl
ckJvdW5kPSIxIgogICAgICAgIGVUeXBlPSIjLy9Xcml0ZXIiIGVPcHBvc2l0 ZT0iIy8vV3JpdGVy
L2Jvb2tzIj4KICAgICAgPGVBbm5vdGF0aW9ucyBzb3VyY2U9Imh0dHA6Ly8v b3JnL2VjbGlwc2Uv
ZW1mL2Vjb3JlL3V0aWwvRXh0ZW5kZWRNZXRhRGF0YSI+CiAgICAgICAgPGRl dGFpbHMga2V5PSJr
aW5kIiB2YWx1ZT0iZWxlbWVudCIvPgogICAgICAgIDxkZXRhaWxzIGtleT0i bmFtZSIgdmFsdWU9
ImF1dGhvciIvPgogICAgICA8L2VBbm5vdGF0aW9ucz4KICAgIDwvZVN0cnVj dHVyYWxGZWF0dXJl
cz4KICA8L2VDbGFzc2lmaWVycz4KICA8ZUNsYXNzaWZpZXJzIHhzaTp0eXBl PSJlY29yZTpFRW51
bSIgbmFtZT0iQm9va0NhdGVnb3J5Ij4KICAgIDxlQW5ub3RhdGlvbnMgc291 cmNlPSJodHRwOi8v
L29yZy9lY2xpcHNlL2VtZi9lY29yZS91dGlsL0V4dGVuZGVkTWV0YURhdGEi PgogICAgICA8ZGV0
YWlscyBrZXk9Im5hbWUiIHZhbHVlPSJCb29rQ2F0ZWdvcnkiLz4KICAgIDwv ZUFubm90YXRpb25z
PgogICAgPGVMaXRlcmFscyBuYW1lPSJNeXN0ZXJ5Ii8+CiAgICA8ZUxpdGVy YWxzIG5hbWU9IlNj
aWVuY2VGaWN0aW9uIiB2YWx1ZT0iMSIvPgogICAgPGVMaXRlcmFscyBuYW1l PSJCaW9ncmFwaHki
IHZhbHVlPSIyIi8+CiAgPC9lQ2xhc3NpZmllcnM+CiAgPGVDbGFzc2lmaWVy cyB4c2k6dHlwZT0i
ZWNvcmU6RURhdGFUeXBlIiBuYW1lPSJCb29rQ2F0ZWdvcnlPYmplY3QiIGlu c3RhbmNlQ2xhc3NO
YW1lPSJvcmcuZWNsaXBzZS5lbWYuY29tbW9uLnV0aWwuRW51bWVyYXRvciI+ CiAgICA8ZUFubm90
YXRpb25zIHNvdXJjZT0iaHR0cDovLy9vcmcvZWNsaXBzZS9lbWYvZWNvcmUv dXRpbC9FeHRlbmRl
ZE1ldGFEYXRhIj4KICAgICAgPGRldGFpbHMga2V5PSJuYW1lIiB2YWx1ZT0i Qm9va0NhdGVnb3J5
Ok9iamVjdCIvPgogICAgICA8ZGV0YWlscyBrZXk9ImJhc2VUeXBlIiB2YWx1 ZT0iQm9va0NhdGVn
b3J5Ii8+CiAgICA8L2VBbm5vdGF0aW9ucz4KICA8L2VDbGFzc2lmaWVycz4K ICA8ZUNsYXNzaWZp
ZXJzIHhzaTp0eXBlPSJlY29yZTpFQ2xhc3MiIG5hbWU9IkxpYnJhcnkiPgog ICAgPGVBbm5vdGF0
aW9ucyBzb3VyY2U9Imh0dHA6Ly8vb3JnL2VjbGlwc2UvZW1mL2Vjb3JlL3V0 aWwvRXh0ZW5kZWRN
ZXRhRGF0YSI+CiAgICAgIDxkZXRhaWxzIGtleT0ibmFtZSIgdmFsdWU9Ikxp YnJhcnkiLz4KICAg
ICAgPGRldGFpbHMga2V5PSJraW5kIiB2YWx1ZT0iZWxlbWVudE9ubHkiLz4K ICAgIDwvZUFubm90
YXRpb25zPgogICAgPGVTdHJ1Y3R1cmFsRmVhdHVyZXMgeHNpOnR5cGU9ImVj b3JlOkVBdHRyaWJ1
dGUiIG5hbWU9Im5hbWUiIHVuaXF1ZT0iZmFsc2UiIGxvd2VyQm91bmQ9IjEi CiAgICAgICAgZVR5
cGU9ImVjb3JlOkVEYXRhVHlwZSBodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2Vt Zi8yMDAzL1hNTFR5
cGUjLy9TdHJpbmciPgogICAgICA8ZUFubm90YXRpb25zIHNvdXJjZT0iaHR0 cDovLy9vcmcvZWNs
aXBzZS9lbWYvZWNvcmUvdXRpbC9FeHRlbmRlZE1ldGFEYXRhIj4KICAgICAg ICA8ZGV0YWlscyBr
ZXk9ImtpbmQiIHZhbHVlPSJlbGVtZW50Ii8+CiAgICAgICAgPGRldGFpbHMg a2V5PSJuYW1lIiB2
YWx1ZT0ibmFtZSIvPgogICAgICA8L2VBbm5vdGF0aW9ucz4KICAgIDwvZVN0 cnVjdHVyYWxGZWF0
dXJlcz4KICAgIDxlU3RydWN0dXJhbEZlYXR1cmVzIHhzaTp0eXBlPSJlY29y ZTpFUmVmZXJlbmNl
IiBuYW1lPSJ3cml0ZXJzIiB1cHBlckJvdW5kPSItMSIKICAgICAgICBlVHlw ZT0iIy8vV3JpdGVy
IiBjb250YWlubWVudD0idHJ1ZSI+CiAgICAgIDxlQW5ub3RhdGlvbnMgc291 cmNlPSJodHRwOi8v
L29yZy9lY2xpcHNlL2VtZi9lY29yZS91dGlsL0V4dGVuZGVkTWV0YURhdGEi PgogICAgICAgIDxk
ZXRhaWxzIGtleT0ia2luZCIgdmFsdWU9ImVsZW1lbnQiLz4KICAgICAgICA8 ZGV0YWlscyBrZXk9
Im5hbWUiIHZhbHVlPSJ3cml0ZXJzIi8+CiAgICAgIDwvZUFubm90YXRpb25z PgogICAgICA8ZUFu
bm90YXRpb25zIHNvdXJjZT0idGVuZW8uaGliZXJuYXRlIj4KICAgICAgICA8 ZGV0YWlscyBrZXk9
ImFwcGluZm8iIHZhbHVlPSJARmV0Y2goU1VCU0VMRUNUKSYjeEE7QEZvcmVp Z25LZXkobmFtZT0m
cXVvdDtzY2hyaWp2ZXJzJnF1b3Q7KSIvPgogICAgICA8L2VBbm5vdGF0aW9u cz4KICAgIDwvZVN0
cnVjdHVyYWxGZWF0dXJlcz4KICAgIDxlU3RydWN0dXJhbEZlYXR1cmVzIHhz aTp0eXBlPSJlY29y
ZTpFUmVmZXJlbmNlIiBuYW1lPSJib29rcyIgdXBwZXJCb3VuZD0iLTEiCiAg ICAgICAgZVR5cGU9
IiMvL0Jvb2siIGNvbnRhaW5tZW50PSJ0cnVlIj4KICAgICAgPGVBbm5vdGF0 aW9ucyBzb3VyY2U9
Imh0dHA6Ly8vb3JnL2VjbGlwc2UvZW1mL2Vjb3JlL3V0aWwvRXh0ZW5kZWRN ZXRhRGF0YSI+CiAg
ICAgICAgPGRldGFpbHMga2V5PSJraW5kIiB2YWx1ZT0iZWxlbWVudCIvPgog ICAgICAgIDxkZXRh
aWxzIGtleT0ibmFtZSIgdmFsdWU9ImJvb2tzIi8+CiAgICAgIDwvZUFubm90 YXRpb25zPgogICAg
PC9lU3RydWN0dXJhbEZlYXR1cmVzPgogIDwvZUNsYXNzaWZpZXJzPgogIDxl Q2xhc3NpZmllcnMg
eHNpOnR5cGU9ImVjb3JlOkVDbGFzcyIgbmFtZT0iV3JpdGVyIj4KICAgIDxl QW5ub3RhdGlvbnMg
c291cmNlPSJodHRwOi8vL29yZy9lY2xpcHNlL2VtZi9lY29yZS91dGlsL0V4 dGVuZGVkTWV0YURh
dGEiPgogICAgICA8ZGV0YWlscyBrZXk9Im5hbWUiIHZhbHVlPSJXcml0ZXIi Lz4KICAgICAgPGRl
dGFpbHMga2V5PSJraW5kIiB2YWx1ZT0iZWxlbWVudE9ubHkiLz4KICAgIDwv ZUFubm90YXRpb25z
PgogICAgPGVTdHJ1Y3R1cmFsRmVhdHVyZXMgeHNpOnR5cGU9ImVjb3JlOkVB dHRyaWJ1dGUiIG5h
bWU9Im5hbWUiIHVuaXF1ZT0iZmFsc2UiIGxvd2VyQm91bmQ9IjEiCiAgICAg ICAgZVR5cGU9ImVj
bmFtZSIvPgogICAgICA8L2VBbm5vdGF0aW9ucz4KICAgIDwvZVN0cnVjdHVy YWxGZWF0dXJlcz4K
ICAgIDxlU3RydWN0dXJhbEZlYXR1cmVzIHhzaTp0eXBlPSJlY29yZTpFUmVm ZXJlbmNlIiBuYW1l
PSJib29rcyIgdXBwZXJCb3VuZD0iLTEiCiAgICAgICAgZVR5cGU9IiMvL0Jv b2siIGVPcHBvc2l0
ZT0iIy8vQm9vay9hdXRob3IiPgogICAgICA8ZUFubm90YXRpb25zIHNvdXJj ZT0iaHR0cDovLy9v
cmcvZWNsaXBzZS9lbWYvZWNvcmUvdXRpbC9FeHRlbmRlZE1ldGFEYXRhIj4K ICAgICAgICA8ZGV0
YWlscyBrZXk9ImtpbmQiIHZhbHVlPSJlbGVtZW50Ii8+CiAgICAgICAgPGRl dGFpbHMga2V5PSJu
YW1lIiB2YWx1ZT0iYm9va3MiLz4KICAgICAgPC9lQW5ub3RhdGlvbnM+CiAg ICA8L2VTdHJ1Y3R1
cmFsRmVhdHVyZXM+CiAgPC9lQ2xhc3NpZmllcnM+CjwvZWNvcmU6RVBhY2th Z2U+Cg==
--nextPart3452683.hk5qWAgFLt--
Re: EMF+Teneo+ORM+JPA EAttribute with multi-valued eenum type [message #431913 is a reply to message #431912] Wed, 29 July 2009 11:27 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi Jan,
This should be possible so seems a bug. Can you enter a bugzilla for this? Then I will solve this in the next build.
gr. Martin
equisitus wrote:
> Hi experts,
> <Book>
> </Book>
> <orm:attributes>
> </orm:basic>
> </orm:entity>
> Ciao,
> Jan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:cdo - unimplemented methods and missing repositories
Next Topic:Headless mode, project creation + code generation
Current Time: Thu Jun 21 08:59:43 GMT 2018
Powered by FUDForum. Page generated in 0.01509 seconds
