Home » Modeling » EMF » [sdo serialization] want to use reference instead of id
[sdo serialization] want to use reference instead of id [message #431198] Thu, 02 July 2009 09:35 Go to next message
Thomas is currently offline ThomasFriend
Member
Hi all,
I have problem with sdo serialization.
We are using teneo for loading our data, so ids are generated by
database. Depending on database type, id for different EObject are
generated differently as it can be unique for all object or inside a
type of object.
In the second case (which is the case with sql server database), I have
Here is a sample of serialization
<sdo:datagraph xmlns:com.oslo.dreams="http:///com.oslo.dreams.model"
xmlns:sdo="commonj.sdo">
<com.oslo.dreams:Root>
<resources name="toto" resourceCategories="#1"
capabilities="#//@eRootObject/@capabilities.0
#//@eRootObject/@capabilities.1"
capacity="5"/>
<capabilities name="capa1" skill="#1"
resourceOwner="#//@eRootObject/@resources.0"/>
<capabilities name="capa2" skill="#2"
<resourceCategories id="1" name="haute categorie"/>
<skills id="1" name="s1"/>
<skills id="2" name="s2"/>
</com.oslo.dreams:Root>
</sdo:datagraph>
As we can see, some references are using ids.
But for id 1 we have to kind of EObject (Skill and ResourceCategorie)
So the deserialization will not work.
We are working with ecore 2.4.2 and teneo 1.1.0.
Thank's all for any clue that can help me to get ahead.
Thomas
Re: [sdo serialization] want to use reference instead of id [message #431200 is a reply to message #431198] Thu, 02 July 2009 10:52 Go to previous message
Thomas,
Comments below.
Thomas Franconville wrote:
> Hi all,
> type of object.
Well, that's not how IDs are defined in XML Schema or Ecore though.
They must be unique with a resource/document across all types.
> capacity="5"/>
> </sdo:datagraph>
It's an invalid document so unfortunately it's not going to work.
Resource.getEObject only gets a String argument. It does not know the
type of object it should return.
I'd suggest using a specialized EDataType for each such id EAttribute
and encode the type name, as part of convertAbcToString.
> Thomas
Previous Topic:Question about EFeatureMap
Next Topic:Accessing attributes in generated code for editor
Current Time: Wed May 23 18:54:23 GMT 2018
Powered by FUDForum. Page generated in 0.01738 seconds
