Home » Modeling » EMF » [CDO] EFeatureMap support in DBStore
[CDO] EFeatureMap support in DBStore [message #430979] Mon, 22 June 2009 17:33 Go to next message
Christopher Albert is currently offline Christopher AlbertFriend
Hi!
We are currently migrating an Eclipse plugin to a CDO backend at Graz
University of Technology and are having problems persisting XSD-based
models because of EFeatureMap not being implemented in the DBStore
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=254455):
[ERROR] Rollback in DBStore: org.eclipse.net4j.util.ImplementationError:
Unrecognized CDOType: FEATURE_MAP_ENTRY
Do you know when this feature will be available and how much work it is to
implement it? If we could get some documentation to the design of DBStore
and the main difficulties, we could maybe try to implement it ourselves?
Thanks and
best regards,
Christopher Albert
Re: [CDO] EFeatureMap support in DBStore [message #430982 is a reply to message #430979] Mon, 22 June 2009 19:25 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Christopher,
I hope that Stefan can jump in for this question...
Cheers
/Eike
Christopher Albert schrieb:
> Hi!
> is to implement it? If we could get some documentation to the design
> of DBStore and the main difficulties, we could maybe try to implement
> it ourselves?
> Thanks and
> best regards,
> Christopher Albert
Re: [CDO] EFeatureMap support in DBStore [message #430986 is a reply to message #430979] Tue, 23 June 2009 07:17 Go to previous messageGo to next message
Stefan Winkler is currently offline Stefan WinklerFriend
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Hi,<br>
<br>
<blockquote
cite="mid:7130a96a92784e60707256bdcba400c4$1@www.eclipse.org"
type="cite">Hi!
<br>
<br>
(<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=254455">https://bugs.eclipse.org/bugs/show_bug.cgi?id=254455</a>):
<br>
<br>
<br>
<br>
<br>
to implement it? If we could get some documentation to the design of
DBStore and the main difficulties, we could maybe try to implement it
ourselves?
<br>
</blockquote>
I had a comment on this on Bug 249436. I just copied it over to 254455
so the information is all in one place:<br>
<br>
<span class="Apple-style-span"
style="border-collapse: separate; color: rgb(0, 0, 0); font-family: 'times new roman'; font-size: 16px; font-style: normal; font-variant: normal; font-weight: normal; letter-spacing: normal; line-height: normal; orphans: 2; text-indent: 0px; text-transform: none; white-space: normal; widows: 2; word-spacing: 0px;"><span
style="font-family: -webkit-sans-serif; font-size: 13px;">
<form name="changeform" method="post" action="process_bug.cgi">
<div id="comments">
<div class="bz_comment" style="margin-bottom: 2em;">
<pre class="bz_comment_text" id="comment_text_8"
style="font-family: monospace; width: 50em;"><span class="quote"
style="color: rgb(101, 55, 156); white-space: pre;">&gt; The good news:
&gt;
&gt; It is not so much effort to implement FeatureMaps in the DBStore.
&gt; I have already agreed with Eike on how to do it:
&gt; - Define a new mapping which works similar to the ListMapping,
&gt; - but with one column containing the tag (which feature are we storing)
&gt; - and one column for each feature</span>
&gt;
<span class="quote" style="color: rgb(101, 55, 156); white-space: pre;">&gt; The new DBStore structure which I introduced can be extended quite easily for
&gt; this.</span>
&gt;
&gt;
<span class="quote" style="color: rgb(101, 55, 156); white-space: pre;">&gt; The bad news:</span>
&gt;
<span class="quote" style="color: rgb(101, 55, 156); white-space: pre;">&gt; I just don't have much time currently. If you really need the feature, maybe
&gt; you are willing to invest some time (1-2 days) to create the implementation. </span>
</pre>
</div>
</div>
</form>
</span></span>So please do go ahead and try implementing it yourself. I
will be glad to give support via email or Skype. <br>
<br>
A good place to start is looking at the DBStore, in particular at the
ListMappings and the HorizontalMappingStrategy which is the factory for
the ListMappings.<br>
From there, a new class FeatureMapMapping or something like this should
be implemented, which would at first work something like this:<br>
<br>
If a EFeatureMapEntry has two entries "hello" and "world" for two
different features "foo" and "bar" then the table could look like this:<br>
<br>
cdo_id   index   tag   value_foo   value_bar<br>
1            0         foo   hello         &lt;null&gt;<br>
1            1         bar   &lt;null&gt;      world<br>
<br>
so the mapping would be:<br>
- at init time: for every EStructuralFeature create a column with its
name<br>
- at runtime for every FM-Entry create a row (as in ListMapping) but
instead of the simple value set the tag column to the
EStructuralFeature.getName() and the corresponding value column to the
actual value.<br>
<br>
An advanced mapping which is more desirable (because it takes up less
space) is:<br>
- at init time: for every unique EStructuralFeature.getType() create a
column <br>
- at runtime: map entry to row as above, but set the actual value to
the column determined by EStructuralFeature.getType()<br>
<br>
cdo_id   index   tag   value_string<br>
1            0         foo   hello         <br>
1            1         bar   world<br>
<br>
If you want to directly implement the second mapping, the better ;-)<br>
<br>
As I said, if you have more questions, I'll be happy to answer them and
support your implementation effort!<br>
<br>
Cheers,<br>
Stefan<br>
<br>
</body>
</html>
Re: [CDO] EFeatureMap support in DBStore [message #430987 is a reply to message #430986] Tue, 23 June 2009 07:32 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
The other option might be to check if the Teneo-Backend is working for
the model (or probably investing some hours to bring it uptodate - IIRC
Martin said once he has time he's going to look into the current test
failures) because Teneo supports feature maps.
Because Teneo-Support is quite high on my list of needed CDO-stuff in
the next half year, I might take a look into it myself hopefully soon
but I can't promise.
Tom
Stefan Winkler schrieb:
>> Hi!
>> it ourselves?
>> The good news:
>> this.
>> The bad news:
> So please do go ahead and try implementing it yourself. I will be glad
> the ListMappings.
> 1 0 foo hello <null>
> 1 1 bar <null> world
> - at init time: for every EStructuralFeature create a column with its name
> actual value.
> space) is:
> column
> - at runtime: map entry to row as above, but set the actual value to the
> 1 0 foo hello
> 1 1 bar world
> Cheers,
> Stefan
Re: [CDO] EFeatureMap support in DBStore [message #430988 is a reply to message #430987] Tue, 23 June 2009 10:02 Go to previous messageGo to next message
Tom Schindl schrieb:
Hey, we'd love to finally welcome you as a CDO committer! ;-)
Cheers
/Eike
> Tom
>>> Hi!
>>> it ourselves?
>>> The good news:
>>> this.
>>> The bad news:
>> the ListMappings.
>> actual value.
>> space) is:
>> column
>> 1 0 foo hello
>> 1 1 bar world
>> Cheers,
>> Stefan
Re: [CDO] EFeatureMap support in DBStore [message #430996 is a reply to message #430986] Tue, 23 June 2009 17:13 Go to previous messageGo to next message
Thank you for the quick reply!
Thanks, I've just added you on Skype.
> the ListMappings.
I've browsed throught the code, it looks clean and easy to understand :D
> actual value.
> space) is:
> column
> 1 0 foo hello
> 1 1 bar world
OK, I will implement the second one if you think it's better.
But if I have understood correctly (I'm no DB-developer and also quite
new to EMF), the first one has the advantage that you can use other
DB-field types than strings, I think this will add some performance
overhead (apart from the problem to map everything to strings).
A third option would be to generate multiple list tables, one for each
tag, and join them when needed. What do you think about that?
I'd be very glad!
regards,
Chris
Re: [CDO] EFeatureMap support in DBStore [message #431007 is a reply to message #430996] Wed, 24 June 2009 07:31 Go to previous messageGo to next message
Comments below.
>> space) is:
>> a column
>> 1 0 foo hello 1 1
>> bar world
Ok, my second example was too simple ;). I meant one column for each
type. The difference to the first mapping is that one column is created
for each EStructuralFeature which can be contained in the feature map.
In the second mapping, we only create one column for each distinct
feature type.
So, if you have mixed type, as in this (first) mapping
cdo_id
index
tag
value_foo
value_bar
value_count
1
0
foo
hello
1
1
bar
world
1
2
count
1
you would get (in the second mapping):
cdo_id
index
tag
value_string
value_int
1
0
foo
hello
1
1
bar
world
1
2
count
1
The problem with that is that reading and updating (moving, inserting,
deleting -- at least in non-audit mode) gets a lot more complicated,
because then the indexes are scattered among different tables. I had
discussed that with Eike, too, but as far as I remember that solution
introduces more problems than it solves.
Stefan
Re: [CDO] EFeatureMap support in DBStore [message #431008 is a reply to message #431007] Wed, 24 June 2009 07:42 Go to previous messageGo to next message
<html>
<head>
</head>
Sorry, the example tables were messed up.<br>
<br>
Below is the next try ...<br>
<br>
<blockquote cite="mid:4A41D667.8010704@fernuni-hagen.de" type="cite">
<pre wrap="">Hi,
Comments below.
</pre>
<blockquote type="cite">
<pre wrap="">An advanced mapping which is more desirable (because it takes up less
space) is:
a column
1 0 foo hello 1 1
bar world
</pre>
</blockquote>
<pre wrap="">OK, I will implement the second one if you think it's better.
</pre>
</blockquote>
<pre wrap=""><!---->Ok, my second example was too simple ;). I meant one column for each
feature type.
</pre>
</blockquote>
<br>
<table border="1" cellpadding="2" cellspacing="2" width="100%">
<tbody>
<tr>
<td valign="top">cdo_id<br>
</td>
<td valign="top">index<br>
</td>
<td valign="top">tag<br>
</td>
<td valign="top">value_foo</td>
<td valign="top">value_bar<br>
</td>
<td valign="top">value_count<br>
</td>
</tr>
<tr>
<td valign="top">1<br>
</td>
<td valign="top">0<br>
</td>
<td valign="top">foo<br>
</td>
<td valign="top">hello<br>
</td>
<td valign="top"><br>
</td>
</td>
</tr>
<tr>
</td>
</td>
<td valign="top">bar<br>
</td>
</td>
<td valign="top">world<br>
</td>
</td>
</tr>
<tr>
</td>
<td valign="top">2<br>
</td>
<td valign="top">count<br>
</td>
</td>
</td>
</td>
</tr>
</tbody>
</table>
<br>
.... you would get (in the second mapping):<br>
<br>
<tbody>
<tr>
</td>
</td>
</td>
<td valign="top">value_string</td>
<td valign="top">value_int<br>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
</tbody>
</table>
<br>
<pre wrap="">A third option would be to generate multiple list tables, one for each
</pre>
</blockquote>
<pre wrap=""><!---->The problem with that is that reading and updating (moving, inserting,
Stefan
</pre>
</blockquote>
</body>
</html>
Re: [CDO] EFeatureMap support in DBStore [message #431012 is a reply to message #431008] Wed, 24 June 2009 10:38 Go to previous messageGo to next message
--------------040602010501060409000000
Content-Type: text/plain; charset=ISO-8859-15
Guys,
One mapping looks a bit more space preserving, while the other seems to
be easier to query with SQL. What about making this configurable?
Cheers
/Eike
>> Comments below.
>>>> space) is:
>>>> a column
>>>> 1 0 foo hello 1 1
>>>> bar world
>> feature type.
> cdo_id
> index
> tag
> value_foo value_bar
> value_count
> 1
> 0
> foo
> hello
> 1
> 1
> bar
> world
> 1
> 2
> count
> 1
> cdo_id
> index
> tag
> value_string value_int
> 1
> 0
> foo
> hello
> 1
> 1
> bar
> world
> 1
> 2
> count
> 1
>> Cheers,
>> Stefan
<html>
<head>
</head>
Guys,<br>
<br>
be easier to query with SQL. What about making this configurable?<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
<blockquote cite="mid:4A41D8EA.1080405@fernuni-hagen.de" type="cite">
<br>
<br>
<pre wrap="">Hi,
Comments below.
</pre>
space) is:
a column
1 0 foo hello 1 1
bar world
</pre>
</blockquote>
</pre>
</blockquote>
feature type.
</pre>
</blockquote>
<br>
<tbody>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</td>
</tr>
</tbody>
</table>
<br>
..... you would get (in the second mapping):<br>
<br>
<tbody>
<tr>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</td>
</tr>
</tbody>
</table>
<br>
</pre>
</blockquote>
Stefan
</pre>
</blockquote>
</blockquote>
</body>
</html>
--------------040602010501060409000000--
Re: [CDO] EFeatureMap support in DBStore [message #431013 is a reply to message #430979] Wed, 24 June 2009 10:55 Go to previous messageGo to next message
> Hi!
> ourselves?
> Thanks and
> best regards,
> Christopher Albert
I've updated the bug and aded a patch with basic FeatureMap support in
audit mode.
cheers,
Chris
Re: [CDO] EFeatureMap support in DBStore [message #431043 is a reply to message #431012] Thu, 25 June 2009 07:06 Go to previous message
> to be easier to query with SQL. What about making this configurable?
No problem - after one implementation is finished, we can refactor
common code into a abstract superclass and then implement the other
mapping based on that.
Configuration happend through MappingStrategy (which is the factory for
the mappings). On the long term, this even allows for
per-class-configuration.
Stefan
> Cheers
> /Eike
>>> Hi,
>>> Comments below.
>>>>> space) is:
>>>>> a column
>>>>> 1 0 foo hello 1 1
>>>>> bar world
>>> feature type.
>> cdo_id
>> index
>> tag
>> value_foo value_bar
>> value_count
>> 1
>> 0
>> foo
>> hello
>> 1
>> 1
>> bar
>> world
>> 1
>> 2
>> count
>> 1
>> cdo_id
>> index
>> tag
>> 1
>> 0
>> foo
>> hello
>> 1
>> 1
>> bar
>> world
>> 1
>> 2
>> count
>> 1
>>> Cheers,
>>> Stefan
Previous Topic:galileo there but cdo and net4j not?
Next Topic:seems like an "unsettable"-related serialization issue
Current Time: Tue Feb 20 15:57:08 GMT 2018
Powered by FUDForum. Page generated in 0.02537 seconds
