Home » Modeling » EMF » Reference from one model to another?
Reference from one model to another? [message #430876] Mon, 15 June 2009 11:25 Go to next message
No real name is currently offline No real nameFriend
Member
lets say I have a simple meta-model. It basically has only the EClass
"Person". "Person" has a name and a reference to another "Person", named
"father".
Lets say I generate two models from this meta-model:
- model A:
- Person "Anakin"
- model B:
- Person "Luke"
Now I want the father of Luke to reference Anakin. Is there a
standard-way to this, or do I have to work on that on my own (maybe by
introcing a boolean "isLink" property to "Person") ?
If there is a standard way, I would expect that to work:
- create a constraint which says a person can not have more then 5 children
- create the genmodel from the ecore
- create the editor from the ecore
- create a model B with one person "James"
- create a model A with 10 persons
- tell 6 of the 10 persons in model A that their father is "James"
- validate model B => get a validation error
Thank you for any help
Re: Reference from one model to another? [message #430878 is a reply to message #430876] Mon, 15 June 2009 12:12 Go to previous messageGo to next message
Originally posted by: tim.baumgartner.innovations.de
Hi Usul,
> "father".
> - model A:
> - Person "Anakin"
> - model B:
> - Person "Luke"
You want Luke to be Anakin's father, right? What you wrote sounds a bit like
there are three persons involved.
> Is there a standard-way to this, or do I have to work on that on my own
> (maybe by introcing a boolean "isLink" property to "Person") ?
why not anakin.setFather(luke) ?
> children
you could introduce a reference "children" from Person to Person and specify
4 as it's upper bound and "father" as it's opposite.
Best wishes,
Tim
Re: Reference from one model to another? [message #430886 is a reply to message #430876] Tue, 16 June 2009 07:57 Go to previous messageGo to next message
Usul,
Comments below.
Usul wrote:
> named "father".
> - model A:
> - Person "Anakin"
> - model B:
> - Person "Luke"
> children
Set the multiplicity to 5.
Yes, create a new EMF Generator Model for it.
Generate All...
The generated editors will generally only create one root object per
resource but you could create 10 such resources.
Yes, using the properties view.
If you exceed the multiplicity it will validate as an error.
Re: Reference from one model to another? [message #430894 is a reply to message #430886] Tue, 16 June 2009 15:41 Go to previous messageGo to next message
Member
thank you for your reply. But I haven't been clear enough.
I mean, that I have two different models (that means, two different
files). Now I want to make a reference from one model-element in the one
model (file A) to a model-element in the other model (file B). I did not
find a way to do this.
thank you
Re: Reference from one model to another? [message #430896 is a reply to message #430894] Tue, 16 June 2009 17:10 Go to previous messageGo to next message
Mario Winterer is currently offline Mario WintererFriend
Usul schrieb:
> one model (file A) to a model-element in the other model (file B). I
> did not find a way to do this.
> thank you
Hi!
(1) create a ResourceSet
ResourceSet resourceSet = new ResourceSetImpl();
(2) load both resources into this ResourceSet
Resource resource1 = resourceSet.getResource(uri1, true);
Resource resource2 = resourceSet.getResource(uri2, true);
(3) get persons "anakin" and "luke" from the two resources
Person anakin = (Person)resource1.getContents().get(0);
Person luke = (Person)resource2.getContents().get(1);
(4) set anakin as father of luke: luke.setFather(anakin)
luke.setFather(anakin);
(5) save both resources
resource1.save(null);
resource2.save(null);
Now, the second resource refers the first resource.
Mario
Re: Reference from one model to another? [message #430911 is a reply to message #430896] Wed, 17 June 2009 11:31 Go to previous messageGo to next message
Member
Thank you Mario.
I tried it and it works. So you can only do this programmaticly and not
with the generated editor, right? Because I tried to do this with the
editor. I opened one ressource, loaded the the one but then I did not
manage to create a reference from one ressource to the other.
But OK, it works, thank you.
> Usul schrieb:
>> thank you
> Hi!
> Mario
Re: Reference from one model to another? [message #430912 is a reply to message #430911] Wed, 17 June 2009 12:01 Go to previous message
Usul,
It should work in the generated editors as well. Once a resource is
loaded, the objects in it should be available as choices in any of the
properties...
Usul wrote:
> Thank you Mario.
> not with the generated editor, right? Because I tried to do this with
> the editor. I opened one ressource, loaded the the one but then I did
> not manage to create a reference from one ressource to the other.
>> Usul schrieb:
>>> Hi,
>>> the one model (file A) to a model-element in the other model (file
>>> B). I did not find a way to do this.
>>> thank you
>> Hi!
>> Mario
Previous Topic:How to get model instance from other Plugin?
Next Topic:Using generated itemproviders from another plugin
Current Time: Fri Jan 19 07:58:38 GMT 2018
Powered by FUDForum. Page generated in 0.01809 seconds
