| Question re href and @children [message #430045] |
Fri, 08 May 2009 11:17  |
Alan Messages: 44 Registered: July 2009 |
Member |
I am having a strange issue with hrefs.
I have 2 resources.
In the first I have a number of Object As which contains a collection of
Object Bs (containment = true)
(I also have something things above A but we'll focus on A and B for
example)
In the second I have a reference to a collection of Object Bs (containment =
false)
The href for one of the Object Bs in the second resource reads like this:
href="resource1.config#//@children.2/@children.3/@myobjectBs.0
The issue arises when I delete an Object A.
In the first resource it is now found at @children.2/@children.2
instead of at @children.2/@children.3
This only occurs if I delete an Object A that was not the last created one.
In other words it seems as if that format is like an index.
So when I delete one Object A any ObjectAs created after it have their
"indexes" updated.
However the second resource does not update to reflect this.
So when I try to restart the application the collection of ObjectBs from
resource 2 does not find an object.
I confirmed that this was what was happening by changing the reference
manually in the xml file of the second resource
So If I change index to reflect resource 1 it works fine.
I tried making sure that resource1 was saved first and then resource2 but it
made no difference.
Has anyone any ideas as to why this is happening an how I might fix it ?
thanks,
Alan.
| Re: Question re href and @children [message #430121 is a reply to message #430054] |
Mon, 11 May 2009 12:07   |
Member |
Hi Ed,
I used the eKeys and set it to use the id attribute which is a unique
identifier for everything in my model
but the xml did not change and still used the old @childre.index style.
I feel like I am missing something easy. Any ideas ?
thanks,
Alan.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gu1vi7$j2q$1@build.eclipse.org...
> Alan,
> Comments below.
> Alan wrote:
>> Hello,
>> I have 2 resources.
>> example)
>> (containment = false)
> Yes, that's expected.
>> one.
> Yes, exactly.
>> "indexes" updated.
> Indeed the format it fragile with respect to reordering.
> It makes a difference whether the proxy is resolved or not. If it's not
> resolved yet, it will end up keeping the same proxy URI and will point to
> a different object.
>> it made no difference.
> Whether proxies have been resolved makes a difference.
> EcoreUtil.resolveAll can be used to force all proxies to be resolve.
> If possible take advantage of EReference.eKeys. I.e., identify an
> attribute or combination of attributes in A that make it unique with
> respect to the containment reference. The serialization will then look
> like @children[key='value'] and will be resilient with respect to
> reordering.
>> thanks,
>> Alan.
| Re: Question re href and @children [message #430122 is a reply to message #430121] |
Mon, 11 May 2009 12:14  |
Ed Merks Messages: 24529 Registered: July 2009 |
--------------000007080502050309050308
Alan,
Should the id EAttribute had isID be true? If it's unique across the
whole resource, then yes....
Try setting a breakpoint in BasicEObjectImpl.eURIFragmentSegment. Pay
special attention to this part since eKeys.isEmpty should be false
according to your assertion that you've specified a key.
else if (eStructuralFeature.isMany())
EList<EAttribute> eKeys = ((EReference)eStructuralFeature).getEKeys();
if (eKeys.*isEmpty*())
Alan wrote:
> Hi Ed,
> thanks,
> Alan.
>> Alan,
>> Comments below.
>> Alan wrote:
>>> Hello,
>>> I have 2 resources.
>>> example)
>>> one.
>> Yes, exactly.
>>> "indexes" updated.
>> a different object.
>> reordering.
>>> thanks,
>>> Alan.
<html>
<head>
</head>
Alan,<br>
<br>
whole resource, then yes....<br>
<br>
according to your assertion that you've specified a key.<br>
<br>
else if (eStructuralFeature.isMany())<br>
{<br>
((EReference)eStructuralFeature).getEKeys();<br>
if (eKeys.<b>isEmpty</b>())<br>
{<br>
<br>
<br>
<br>
Alan wrote:
<blockquote cite="mid:gu9ig7$s4$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
thanks,
Alan.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gu1vi7$j2q$1@build.eclipse.org">news:gu1vi7$j2q$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Alan,
Comments below.
Alan wrote:
</pre>
<pre wrap="">Hello,
I have 2 resources.
example)
href="<a class="moz-txt-link-abbreviated" href=" mailto:resource1.config#//@children.2/@children.3/@myobjectB s.0 ">resource1.config#//@children.2/@children.3/@myobjectBs.0</a >
</pre>
</blockquote>
<pre wrap="">Yes, that's expected.
</pre>
<pre wrap="">This only occurs if I delete an Object A that was not the last created
one.
</pre>
</blockquote>
<pre wrap="">Yes, exactly.
</pre>
<pre wrap="">So when I delete one Object A any ObjectAs created after it have their
"indexes" updated.
</pre>
</blockquote>
<pre wrap="">Indeed the format it fragile with respect to reordering.
</pre>
<pre wrap="">However the second resource does not update to reflect this.
</pre>
</blockquote>
<pre wrap="">It makes a difference whether the proxy is resolved or not. If it's not
a different object.
</pre>
<pre wrap="">So when I try to restart the application the collection of ObjectBs from
</pre>
</blockquote>
<pre wrap="">Whether proxies have been resolved makes a difference.
</pre>
<pre wrap="">Has anyone any ideas as to why this is happening an how I might fix it ?
</pre>
</blockquote>
<pre wrap="">If possible take advantage of EReference.eKeys. I.e., identify an
reordering.
</pre>
<pre wrap="">thanks,
Alan.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------000007080502050309050308--
FUDForum. Page generated in 0.01613 seconds
