Home » Modeling » EMF » Datatype Identifier problem
Datatype Identifier problem [message #429323] Sun, 19 April 2009 17:54 Go to next message
Originally posted by: krdbrm.gmail.com
Dear Martin Taal,
I use the Teneo for mapping an ecore Modell to the Mysql Database. this
is a model for a Project and i did not create this model and i can not
change the Model. in this modell is a id as EData Type. if i try to
create an diagram and save in Database i get following Error Messeag
wich property can i use for a resolve dies Problem.
I used some EAnnotation an DataStore-Properties,Unfortunately I was not
successful.
the Error Code:
java.lang.ClassCastException: Identifier classes must be serializable.
org.efixes.Id is not serializable. org.efixes.Id
org.hibernate.tuple.entity.AbstractEntityTuplizer.getIdentif ier(AbstractEntityTuplizer.java:198)
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.getIden tifier(EMFTuplizer.java:94)
org.hibernate.persister.entity.AbstractEntityPersister.getId entifier(AbstractEntityPersister.java:3591)
thank you very much for your help
best regards
Bahram
Re: Datatype Identifier problem [message #429324 is a reply to message #429323] Sun, 19 April 2009 22:15 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Bahram,
Can you change the id class (org.efixes.Id) and add the Serializable interface to it?
Other questions inline marked with MT>>.
gr. Martin
Bahram Kord wrote:
> Dear Martin Taal,
MT>> I am sorry but I do not understand what you mean here.
> successful.
MT>> What eannotation did you use?
> the Error Code:
> at
> at
> at
> best regards
> Bahram
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Datatype Identifier problem [message #429347 is a reply to message #429324] Tue, 21 April 2009 07:22 Go to previous message
Hallo Martin
I add the Serializable interface to the id class and
I do not get this error message.
thank you very much for your help.
best regards
Bahram
Martin Taal schrieb:
> Hi Bahram,
> interface to it?
> gr. Martin
> Bahram Kord wrote:
>> Dear Martin Taal,
>> this is a model for a Project and i did not create this model and i
>> can not change the Model. in this modell is a id as EData Type. if i
>> try to create an diagram and save in Database i get following Error
>> Messeag wich property can i use for a resolve dies Problem.
>> not successful.
>> the Error Code:
>> at
>> at
>> at
>> best regards
>> Bahram
Previous Topic:rdb schema to xsd/java/ecore
Next Topic:Illegal Value Exception by loading a custom model
Current Time: Mon May 21 11:20:27 GMT 2018
Powered by FUDForum. Page generated in 0.01820 seconds
