Home » Modeling » EMF » [Teneo] ObjectDeletedException even though no deletion?
[Teneo] ObjectDeletedException even though no deletion? [message #426665] Fri, 16 January 2009 18:09 Go to next message
David Wynter is currently offline David WynterFriend
I have this exception
org.hibernate.ObjectDeletedException: deleted object would be re-saved
by cascade (remove deleted object from associations): [InstrumentDomain#918]
But am not doing any deletions?
I have this code
public BondResult getBondResultRows(Integer[] ids) {
BondResult result = new BondResult();
if(!(ids!=null && ids.length>0))
return result;
// open transaction
Session session = HibernateUtil.getCurrentSession();
Transaction tx = session.beginTransaction();
try
// construct search
String queryString = "select inst from InstrumentDomain inst" +
" left join fetch inst.instrumentIdentifier ident" +
" inner join ident.schemeInfo info" +
" inner join inst.instrumentType as type" +
" left join fetch inst.debtIssueData did" +
" left join fetch did.interestRate intr" +
" left join fetch did.denomination denom" +
" left join fetch inst.issuerClass issr" +
" left join fetch issr.location loc" +
" left join fetch intr.indicatorsType indtype" +
" where inst.id in (:ids)";
// build query
Query query = session.createQuery(queryString);
query.setParameterList("ids", ids);
// then create a BondResult with the constituent objects
try {
List<InstrumentDomain> results = query.list();
if (results != null)
for (InstrumentDomain instrument : results)
BondResultRow brr = new BondResultRow(instrument);
result.addBondResultRow(brr);
} catch (ClassCastException cce) {
Log.error("Hibernate cast error: ", cce);
// commit transaction
tx.commit();
catch (RuntimeException e)
tx.rollback();
throw e;
// done
return result;
Which calls this
public BondResultRow(final InstrumentDomain domain)
which is quite long, but definitely does not delete anything.
So I am at a loss to explain why I get this exception.
Here are my PersistanceOptions
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH , "28");
props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY, "true");
props.setProperty(PersistenceOptions.DEFAULT_ID_FEATURE_NAME , "id");
props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRA TEGY, "simple");
props.setProperty(PersistenceOptions.JOIN_TABLE_FOR_NON_CONT AINED_ASSOCIATIONS,
"false");
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE, "DATE");
props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPP ING, "true");
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG, "true");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
//ManyToOne and OneToMany are normally fetch eagerly, only if you do
SET_PROXY=true then these are set to lazy
props.setProperty(PersistenceOptions.SET_PROXY, "true");
Any ideas?
Thx
David
Re: [Teneo] ObjectDeletedException even though no deletion? [message #426667 is a reply to message #426665] Fri, 16 January 2009 20:03 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi David,
The main reason why this can happen is when an child is removed from its containment relation to the
parent. Then because of orphan-delete the object will automatically be deleted.
One thing you can do to analyse the situation is to use a Hibernate Interceptor. The interceptor has
an ondelete method where you can set a breakpoint to see what causes the delete action. You need to
extend the EMFInterceptor and then set your Interceptor class in Teneo like this:
final ExtensionManager extensionManager = dataStore.getExtensionManager();
extensionManager.registerExtension(EMFInterceptor.class.getN ame(), DavidsInterceptor.class.getName());
and then initialize the datastore.
An interceptor can also be used to analyse why hibernate updates an object. At least that is what I
use it for.
gr. Martin
David Wynter wrote:
> I have this code
> return result;
> // open transaction
> try
> // construct search
> // build query
> try {
> tx.commit();
> tx.rollback();
> throw e;
> // done
> return result;
> Which calls this
> "28");
> "simple");
> "false");
> Any ideas?
> Thx
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:Fragment-based URIs
Next Topic:How to update objects within XMIResource?
Current Time: Tue Jun 19 09:11:40 GMT 2018
Powered by FUDForum. Page generated in 0.02147 seconds
