Home » Modeling » EMF » Saving emfresource while updating references
| Saving emfresource while updating references [message #425645] |
Wed, 03 December 2008 11:48  |
Originally posted by: benoit.maggi.atosorigin.com
Hi everyone,
I'm stuck by a very annoying problem.
When i try to rename an emf file, it works but all models referencing
this model are not updating.
For example, i have 2 uml models : A and B, A reference B
so it contains text like : href="B.uml"
When i rename B.uml in NewB.uml, the text stay as href="B.uml", and my A
model is now broken.
I don't find any emf option to allow this comportment. Is there one?
Otherwise i don't find any solution to get easily ( without parsing all
the workspace) the list of the resource which reference ones.
Benoit MAGGI
| Re: Saving emfresource while updating references [message #425650 is a reply to message #425645] |
Wed, 03 December 2008 12:44   |
Ed Merks Messages: 25227 Registered: July 2009 |
Benoit,
Comments below.
Benoit MAGGI wrote:
> Hi everyone,
They need to be loaded before the renaming, and saved as well after the
renaming.
> A model is now broken.
> all the workspace) the list of the resource which reference ones.
That's the only way. I.e., you have to physically change all these
referencing files, right?
> Regards
> Benoit MAGGI
| Re: Saving emfresource while updating references [message #425662 is a reply to message #425650] |
Thu, 04 December 2008 06:59   |
Thanks for answering.
I'm trying to change the uri of a file and update all the file that
reference it. I don't find a function that migrate an model from one uri
to ah other. So here is my algorithm:
FIRST : i load the A resource that reference B
Resource A= resourceSet.getResource(fileURI, true);
try {
A.load(Collections.EMPTY_MAP);
} catch (IOException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
SECOND : i set to B a new URI
URI newRenamedFileURI =
URI.createPlatformResourceURI(newPath.toOSString(), true);
B.setURI(newRenamedFileURI);
THIRD : i save B
try {
B.save(Collections.EMPTY_MAP);
} catch (IOException e) {
System.out.println("ERROR");
e.printStackTrace();
At the end i get a A referencing the old B file, and neWB file tha is
correct ( copy of b with new Name and uri).
Where am i wrong?
regards
Benoit MAGGI
Ed Merks a écrit :
> Benoit,
> Comments below.
> Benoit MAGGI wrote:
>> Hi everyone,
> renaming.
>> Regards
>> Benoit MAGGI
| Re: Saving emfresource while updating references [message #425668 is a reply to message #425662] |
Thu, 04 December 2008 08:06  |
Benoit,
Comments below.
Benoit MAGGI wrote:
> uri to ah other. So here is my algorithm:
> try {
It's already loaded by now, so this is redundant.
Probably it's important to use EcoreUtil.resolveAll to ensure that all
proxies to B are resolved.
I can't imagine that using toOSString is good given that it will use "\"
instead of "/" on Windows.
> THIRD : i save B
> try {
Where do you save A?
> Where am i wrong?
Load all the files that refer to B into the resource set using
getResource(uri, true), use EcoreUtil.resolveAll on the resource set,
rename the URI of B, then save all the resources.
> regards
> Benoit MAGGI
> Ed Merks a écrit :
>> Benoit,
>> Comments below.
>> Benoit MAGGI wrote:
>>> Hi everyone,
>>> referencing this model are not updating.
>> the renaming.
>>> my A model is now broken.
>>> Regards
>>> Benoit MAGGI
Current Time: Tue Oct 08 08:07:45 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
