Home » Modeling » EMF » EMF and Maps
EMF and Maps [message #423062] Mon, 22 September 2008 10:52 Go to next message
Eclipse User
Originally posted by: luzi.anderegg.ergon.ch
I modelled a map in my ecore according to
http://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF .3F. Is
there an example how to use such a map with an AddCommand from the
generated edit plug-in?
Gnerally, I did not find much information about modelling maps in EMF.
Does somebody know some good pointers?
Luzi
Re: EMF and Maps [message #423069 is a reply to message #423062] Mon, 22 September 2008 11:05 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Luzi,
Just treat it like a list and use
EcoreUtil.create(XyzPackage.Literals.<MapEntryClass>) to create the
instance you want to add. Cast the result of the creation to
BasicMap.Entry to set the key and value.
Luzi Anderegg wrote:
> Luzi
Re: EMF and Maps [message #423128 is a reply to message #423069] Tue, 23 September 2008 11:23 Go to previous messageGo to next message
Eclipse User
Ed,
thanks for your answer! I still have problems with maps and emf
commands. do i have to use an addcommand or a setcommand? and what are
the feature, the owner, and the value? do you have a sample for that?
Luzi
Ed Merks wrote:
> Luzi,
>> Luzi
Re: EMF and Maps [message #423130 is a reply to message #423128] Tue, 23 September 2008 11:43 Go to previous message
Luzi,
The Ecore model's EAnnotation.details is an example so you can look at
how that works. If you simply treat an EMap as a plain old containment
EList, all the same concepts apply as for non-EMaps. Generally you'd use
add and remove commands to manipulate EMaps. The feature, owner, and
value are no different than any other non-EMap case. The only tricky
thing is that there's no strongly typed create method for the map entry
in the generated factory interface...
> Ed,
> Luzi
> Ed Merks wrote:
>> Luzi,
>>> Hi,
>>> EMF. Does somebody know some good pointers?
>>> Luzi
Previous Topic:getting additional resources via customized reflective editor
Next Topic:[CDO] CDOResource.isLoaded()
Current Time: Tue Oct 08 08:02:15 EDT 2013
Powered by FUDForum. Page generated in 0.01500 seconds
