Home » Modeling » EMF » Generics for multiplicity-many references
Generics for multiplicity-many references [message #422103] Fri, 22 August 2008 04:31 Go to next message
Tom Crockett is currently offline Tom CrockettFriend
Member
Hi, I'm having a strange problem where when I generate java code for
models with multiplicity-many references, the resulting ELists are
unparameterized. I am generating the code from XML Schema, using the
XSD2Java ant task. Simplified, the XSD version of the type looks basically
like this (Apple is defined elsewhere):
<xs:element name="Basket">
<xs:complexType ecore:name="Basket">
<xs:sequence>
<xs:element name="Apples" ecore:name="Apples" type="Apple"
minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
</xs:element>
From this I get the following interface:
public interface Basket extends EObject
* Returns the value of the '<em><b>Apples</b></em>' containment
reference list.
* The list contents are of type {@link test.Apple}.
* <!-- begin-user-doc -->
* <p>
* If the meaning of the '<em>Apples</em>' containment reference list
isn't clear,
* there really should be more of a description here...
* </p>
* <!-- end-user-doc -->
* @return the value of the '<em>Apples</em>' containment reference list.
* @see test.ApplesPackage#getBasket_Apples()
* @model type="test.Apple" containment="true"
* extendedMetaData="kind='element' name='Apples'
namespace='##targetNamespace'"
* @generated
EList getApples();
} // Basket
Why doesn't that method look like this:
EList<Apple> getApples();
I've never had a problem with this before, when the source of my model was
annotated interfaces, but coming from XSD there seems to be a problem. Any
ideas?
Re: Generics for multiplicity-many references [message #422105 is a reply to message #422103] Fri, 22 August 2008 05:41 Go to previous messageGo to next message
Member
Ah, I think I've uncovered what's going on, but I'm not sure how to fix
it. I manually created a genmodel via the wizard, importing from the same
xsd file, and this time when I generated the source code it correctly used
generics. So I diffed the two genmodels and, surprise surprise, these two
changes came up:
Attribute complianceLevel:GenJDKLevel in Apples has changed from 5.0 to 1.4
Attribute runtimeVersion:GenRuntimeVersion in Apples has changed from 2.4
to 2.2
So is there a way to inform the ant task to use 5.0/2.4?
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> reference list.
> * <p>
> isn't clear,
> * </p>
> * @generated
> EList getApples();
> } // Basket
> ideas?
Re: Generics for multiplicity-many references [message #422106 is a reply to message #422105] Fri, 22 August 2008 06:08 Go to previous messageGo to next message
Member
Aha! I figured out the right argument through trial and error. By adding
this:
<arg line="-jdkLevel 5.0"/>
to the ant task, I was able to make it generate generics. Still, I wonder
why that's not the default?
> changes came up:
> to 2.2
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:element>
>> reference list.
>> * <p>
>> isn't clear,
>> * </p>
>> * @generated
>> EList getApples();
>> } // Basket
>> ideas?
Re: Generics for multiplicity-many references [message #422115 is a reply to message #422106] Fri, 22 August 2008 09:55 Go to previous message
Thomas,
When 5.0 supported was added, it was new, and you don't generally want
to make defaults change for existing clients.
> adding this:
> wonder why that's not the default?
>> fix it. I manually created a genmodel via the wizard, importing from
>> the same xsd file, and this time when I generated the source code it
>> correctly used generics. So I diffed the two genmodels and, surprise
>> surprise, these two changes came up:
>> to 1.4
>> 2.4 to 2.2
>>> basically like this (Apple is defined elsewhere):
>>> <xs:sequence>
>>> type="Apple" minOccurs="0" maxOccurs="unbounded"/>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </xs:element>
>>> reference list.
>>> * <p>
>>> list isn't clear,
>>> * </p>
>>> reference list.
>>> * @generated
>>> EList getApples();
>>> } // Basket
>>> model was annotated interfaces, but coming from XSD there seems to
>>> be a problem. Any ideas?
Previous Topic:How to fix the DanglingHREFException
Next Topic:Unicode character in a xmi ID
Current Time: Fri May 25 18:57:58 GMT 2018
Powered by FUDForum. Page generated in 0.01526 seconds
