Home » Modeling » EMF » GenModel annotations
GenModel annotations [message #418473] Wed, 16 April 2008 21:45 Go to next message
Conrad Hoffmann is currently offline Conrad HoffmannFriend
I just recently came across GenModel annotations to specify an
implementation for an eOperation.
I was wondering if the same could be used to generate a
get*FromString/getStringFrom* implementation for custom data types?
Even better would be a some kind of complete documentation what exactly can
be done using annotations. I have only found bits and pieces so far...
Thanks, Conrad
Re: GenModel annotations [message #418476 is a reply to message #418473] Wed, 16 April 2008 23:28 Go to previous messageGo to next message
Conrad,
On there's no support for code snippets that could be used for data type
conversion. There's no complete document (other than the second edition
of the book) of all the annotation magic either. Sorry. :-(
Conrad Hoffmann wrote:
> Hello,
> Thanks, Conrad
Re: GenModel annotations [message #418487 is a reply to message #418476] Thu, 17 April 2008 07:11 Go to previous messageGo to next message
Hello Ed,
Thanks a lot.
Unfortunately the local bookstore doesn't have it yet :/
So maybe one last question "manually": can I specifiy code for the
get-Method of derived attributes, and if so, how?
Conrad
Ed Merks wrote:
> Conrad,
>> Hello,
>> can be done using annotations. I have only found bits and pieces so
>> far...
>> Thanks, Conrad
Re: GenModel annotations [message #418488 is a reply to message #418487] Thu, 17 April 2008 07:33 Go to previous messageGo to next message
Reinhold Bihler is currently offline Reinhold BihlerFriend
Member
Conrad,
you can download the rough cuts version of the second edition form safari
for $35. See:
http://safari.awprofessional.com/9780321331885
IMHO it is well worth the money.
Of course asking Ed is a bit cheaper :-P
Reinhold
www.emf4net.org
"Conrad Hoffmann" <conrausch@gmx.de> wrote in message
news:fu6td1$ugr$1@build.eclipse.org...
> Hello Ed,
> Thanks a lot.
> Conrad
> Ed Merks wrote:
>> Conrad,
>>> Hello,
>>> far...
>>> Thanks, Conrad
Re: GenModel annotations [message #418499 is a reply to message #418487] Thu, 17 April 2008 11:23 Go to previous message
--------------090509070302050302090206
Conrad,
No. I spent a little bit of time exploring
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701 as a general
mechanism for being able to specify the behavior for a derived feature,
but there will not be sufficient time to complete that for this release.
> Hello Ed,
> Thanks a lot.
> Conrad
> Ed Merks wrote:
>> Conrad,
>>> Hello,
>>> far...
>>> Thanks, Conrad
<html>
<head>
</head>
Conrad,<br>
<br>
No.&nbsp; I spent a little bit of time exploring <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701">https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701</a>
as a general mechanism for being able to specify the behavior for a
derived feature, but there will not be sufficient time to complete that
for this release.<br>
<br>
<br>
<blockquote cite="mid:fu6td1$ugr$1@build.eclipse.org" type="cite">
<pre wrap="">Hello Ed,
Thanks a lot.
Conrad
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Conrad,
</pre>
<pre wrap="">Hello,
far...
Thanks, Conrad
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090509070302050302090206--
Previous Topic:Avoiding Ecore extension...
Next Topic:org.eclipse.emf.codegen.ecore.generatorAdapters extension point
Current Time: Fri May 25 07:21:00 GMT 2018
Powered by FUDForum. Page generated in 0.02245 seconds
