Home » Modeling » EMF » creating XML instances with multiple schemas
creating XML instances with multiple schemas [message #417643] Wed, 19 March 2008 11:58 Go to next message
Eclipse User
Originally posted by: fjgarcia.alumnos.upm.es
I have this three schemas, referenced between them, my objective is to
create XML instances of the first one:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace=" urn:oasis:names:specification:ubl:schema:xsd:CatalogueReques t-2 "
xmlns=" urn:oasis:names:specification:ubl:schema:xsd:CatalogueReques t-2 "
xmlns:cbc=" urn:oasis:names:specification:ubl:schema:xsd:CommonBasicComp onents-2 "
elementFormDefault="qualified"
attributeFormDefault="unqualified"
version="2.0">
<xsd:import
namespace=" urn:oasis:names:specification:ubl:schema:xsd:CommonBasicComp onents-2 "
schemaLocation="../common/UBL-CommonBasicComponents-2.0.xsd "/>
<xsd:element name="CatalogueRequest" type="CatalogueRequest">
<xsd:annotation>
<xsd:documentation>This element MUST be conveyed as the root
element in any instance document based on this Schema
expression</xsd:documentation>
</xsd:annotation>
</xsd:element>
<xsd:complexType name="CatalogueRequest">
<xsd:sequence>
<xsd:element ref="cbc:ID" minOccurs="1" maxOccurs="1">
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
targetNamespace=" urn:oasis:names:specification:ubl:schema:xsd:CommonBasicComp onents-2 "
xmlns:udt=" urn:un:unece:uncefact:data:specification:UnqualifiedDataType sSchemaModule:2 "
version="2.0">
<!-- ===== Imports ===== -->
<xsd:import
namespace=" urn:un:unece:uncefact:data:specification:UnqualifiedDataType sSchemaModule:2 "
schemaLocation="UnqualifiedDataTypeSchemaModule-2.0.xsd"/>
<xsd:element name="ID" type="cbc:ID"/>
<xsd:complexType name="ID">
<xsd:simpleContent>
<xsd:extension base="udt:IdentifierType"/>
</xsd:simpleContent>
</xsd:complexType>
</xsd:schema>
<xsd:schema
targetNamespace=" urn:un:unece:uncefact:data:specification:UnqualifiedDataType sSchemaModule:2 "
xmlns:xsd="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xsd:complexType name="IdentifierType">
<xsd:simpleContent>
<xsd:extension base="xsd:normalizedString">
<xsd:attribute name="schemeID" type="xsd:normalizedString"
use="optional">
</xsd:attribute>
<xsd:attribute name="schemeName" type="xsd:string" use="optional">
</xsd:attribute>
<xsd:attribute name="schemeAgencyID"
type="xsd:normalizedString" use="optional">
</xsd:attribute>
<xsd:attribute name="schemeAgencyName" type="xsd:string"
use="optional">
</xsd:attribute>
<xsd:attribute name="schemeVersionID"
</xsd:attribute>
<xsd:attribute name="schemeDataURI" type="xsd:anyURI"
use="optional">
</xsd:attribute>
<xsd:attribute name="schemeURI" type="xsd:anyURI" use="optional">
</xsd:attribute>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
I have created the ecore model and I have changed the name of the ecore
files to catalogueRequest, cbc and udt.ecore
In the properties editor I have changed:
NSPrefix from _2 to “”, “cbc” and “udt”
Name and EFactoryInstance from “_2” to “CatalogueRequest”, “CBC” and “UDT”
In the CatalogueRequest.genModel I perform the same change for each
package in the prefix property. Now it’s “CatalogueRequest”, “CBC” and
“UDT” instead of _2.
I generate the model code: It creates the packages
“….CatalogueRequest”, “CBC” and “UDT” with the correspondents .impl and
..util
Now want to create an XML instance document for the CatalogueRequest
element. For that I do the following
cbcFactory=new CBCFactoryImpl();
IDType id=cbcFactory.createIDType();
id.setValue(“CN758494”);
factory=new CatalogueRequestFactoryImpl();
CatalogueRequestType catalogueRequest=factory.createCatalogueRequestType();
CatalogueRequest.setID(id);
Resource resource =
new XMLResourceImpl(URI.createURI("../file.xml"));
resource.getContents().add(catalogueRequest);
try {
resource.save(null);
JFrame window=(JFrame)creator.getTopLevelAncestor();
window.dispose();
The document built is:
<?xml version="1.0" encoding="ASCII"?>
<CatalogueRequestType
xmlns=" urn:oasis:names:specification:ubl:schema:xsd:CatalogueReques t-2 ">
<iD value=" CN758494"/>
</CatalogueRequestType>
But the one I want to create should be like this other:
<CatalogueRequest xmlns=
<cbc:ID>CN758494</cbc:ID>
</CatalogueRequest>
Am I creating correctly the objects?
Is the problem in the how have I built the model code?
Any suggestion?
Javier
Re: creating XML instances with multiple schemas [message #417644 is a reply to message #417643] Wed, 19 March 2008 12:28 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------040506090907070109090603
Content-Type: text/plain; charset=windows-1252; format=flowed
Javier,
Comments below.
Javier garcia wrote:
> Hi
> to create XML instances of the first one:
> version="2.0">
> <xsd:import
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> <xsd:sequence>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> version="2.0">
> <xsd:import
> <xsd:simpleContent>
> </xsd:complexType>
> </xsd:schema>
> <xsd:schema
> <xsd:simpleContent>
> use="optional">
> </xsd:attribute>
> use="optional">
> </xsd:attribute>
> </xsd:attribute>
> use="optional">
> </xsd:attribute>
> </xsd:attribute>
> use="optional">
> </xsd:attribute>
> use="optional">
> </xsd:attribute>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
> ecore files to catalogueRequest, cbc and udt.ecore
> NSPrefix from _2 to
Re: creating XML instances with multiple schemas [message #417663 is a reply to message #417644] Thu, 20 March 2008 14:14 Go to previous message
Eclipse User
Hummm
I had not thought about the .test examples.
I also had that document but I didn't remember.
Now it works.
Thank you very much Ed
Javier
Ed Merks escribió:
> Javier,
> Comments below.
>> Hi
>> <?xml version="1.0" encoding="UTF-8"?>
>> version="2.0">
>> <xsd:import
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:sequence>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> version="2.0">
>> <xsd:import
>> <xsd:simpleContent>
>> </xsd:complexType>
>> </xsd:schema>
>> <xsd:schema
>> <xsd:simpleContent>
>> use="optional">
>> </xsd:attribute>
>> use="optional">
>> </xsd:attribute>
>> </xsd:attribute>
>> use="optional">
>> </xsd:attribute>
>> </xsd:attribute>
>> use="optional">
>> </xsd:attribute>
>> use="optional">
>> </xsd:attribute>
>> </xsd:extension>
>> </xsd:complexType>
>> </xsd:schema>
>> “UDT”
> There are ecore annotations you can put in the schema to specify this
> there, i.e, ecore:nsPrefix and ecore:package.
> XML Schema to Ecore Mapping
> < http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
>> and .util
> No. Use CBCFactory.eINSTANCE. Try invoking Generate Test Code and have
> a look in the *.tests project for the CBCExample.java...
>> Resource resource =
> No. Use the generated resource factory or minimally be use you've set
> the same options that it sets. Again. Look at the example. Be sure to
> use a document root to properly control the root element.
>> try {
>> JFrame
>> window.dispose();
>> </CatalogueRequest>
> There are quite a few mistakes. It will be good to look at the
> generated example to make sure you get it right.
>> Any suggestion?
>> Thanks
>> Javier
Previous Topic:How to generate compound document model using emf?
Next Topic:Error in generating code with Qname with older IDE
Current Time: Tue Oct 08 08:09:57 EDT 2013
Powered by FUDForum. Page generated in 0.07580 seconds
