Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem porting plugin from Europa to Galileo
Problem porting plugin from Europa to Galileo [message #412751] Thu, 30 July 2009 09:08 Go to next message
Derek is currently offline DerekFriend
Member
I am in the process of porting my feature/plugins from Europa to Galileo.
My source is in Subversion, so I have checked them out from the
repository into the Galileo PDE.
I am trying to use the Eclipse Product export wizard from within my
Branding plugin and am getting various dependency errors that I don't
understand.
For example:
Cannot complete the install because one or more required items could not
be found.
Software being installed: com.xxx.xxxx.brand.product 0.0.0
Missing requirement: XXXXX Utilities 2.1.0.200907300958
(com.xxx.xxxx 2.1.0.200907300958) requires 'bundle org.eclipse.ui 0.0.0'
but it could not be found
I have a dependency on org.eclipse.ui (without a min/max version number).
Any ideas on my problem (needless to say, this all works in Europa).
Derek
MoRe: Problem porting plugin from Europa to Galileo [message #415881 is a reply to message #412751] Thu, 30 July 2009 10:24 Go to previous messageGo to next message
Member
More info:
I notice there is now a "Validate" button. pressing this shows me that
for every Eclipse dependency, I have an error. For example
Missing Constraint: Require-Bundle: org.eclipse.ui;bundle-version="3.5.0"
I have change the Properties for my dependency to have no Minimum
version (error report as above, but with a version of "0.0.0"), to have
a Minimum version (error as above) and to have both Minimum and a
Maximum versions (error report as above but with version "[3.2.0.3.5.0)"
Any ideas?
Derek wrote:
> understand.
> For example:
> be found.
> Missing requirement: XXXXX Utilities 2.1.0.200907300958 (com.xxx.xxxx
> 2.1.0.200907300958) requires 'bundle org.eclipse.ui 0.0.0' but it could
> not be found
Derek
Re: MoRe: Problem porting plugin from Europa to Galileo [message #468043 is a reply to message #415881] Mon, 03 August 2009 18:10 Go to previous messageGo to next message
Derek wrote:
> More info:
> Any ideas?
Try removing and then re-adding the dependencies. That will force PDE to
use the latest (Galileo) versions of everything.
Hope this helps,
Eric
> Derek wrote:
>> understand.
>> For example:
>> not be found.
>> 0.0.0' but it could not be found
Re: MoRe: Problem porting plugin from Europa to Galileo [message #468095 is a reply to message #468043] Tue, 04 August 2009 06:44 Go to previous messageGo to next message
Member
Hi Eric,
I have tried that but it makes no difference.
One thing I have found is that if I uncheck the "Generate metadata
repository" checkbox, then I do not get the errors. So, this seesm to be
something caused by p2.
Any other thoughts?
On 03/08/2009 19:10, Eric Rizzo wrote:
> Derek wrote:
>> More info:
>> have a Minimum version (error as above) and to have both Minimum and a
>> Any ideas?
> Hope this helps,
> Eric
>> Derek wrote:
>>> Hi,
>>> Galileo.
>>> understand.
>>> For example:
>>> not be found.
>>> could not be found
>>> number).
Derek
MoRe: Problem porting plugin from Europa to Galileo [message #600150 is a reply to message #412751] Thu, 30 July 2009 10:24 Go to previous messageGo to next message
Member
More info:
Any ideas?
Derek wrote:
> understand.
> For example:
> be found.
> not be found
Derek
Re: MoRe: Problem porting plugin from Europa to Galileo [message #600286 is a reply to message #415881] Mon, 03 August 2009 18:10 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Derek wrote:
> More info:
> Any ideas?
Hope this helps,
Eric
> Derek wrote:
>> understand.
>> For example:
>> not be found.
Re: MoRe: Problem porting plugin from Europa to Galileo [message #600342 is a reply to message #468043] Tue, 04 August 2009 06:44 Go to previous messageGo to next message
Member
Hi Eric,
Any other thoughts?
> Derek wrote:
>> More info:
>> Any ideas?
> Hope this helps,
> Eric
>> Derek wrote:
>>> Hi,
>>> Galileo.
>>> understand.
>>> For example:
>>> not be found.
>>> could not be found
>>> number).
Derek
Re: MoRe: Problem porting plugin from Europa to Galileo [message #752891 is a reply to message #600342] Wed, 26 October 2011 14:59 Go to previous message
Konrad Missing name is currently offline Konrad Missing nameFriend
is there a solution to this issue?
I encounter the same problem when trying to export my feature-based product, with Eclipse 3.7 Indigo:
Cannot complete the install because one or more required items could not be found.
Software being installed: XXX 1.1.0.3 (com.yyy.zzz.product 1.1.0.3)
Missing requirement: Application 1.1.0.3 (com.yyy.zzz.app.feature.group 1.1.0.3) requires 'org.eclipse.ui.forms 0.0.0' but it could not be found
Cannot satisfy dependency:
Launching the application inside Eclipse works. Export with "Generate metadata repository" unchecked works, as reported by Derek, but this is unsatisfying. Removing and re-adding dependencies does not help. Setting a minimum version for org.eclipse.ui.forms does not help, too.
Any ideas?
Konrad
Previous Topic:Editors
Next Topic:Reuse of PDE project creation operations
Current Time: Sun Feb 25 10:28:04 GMT 2018
Powered by FUDForum. Page generated in 0.01867 seconds
