Home » Modeling » EMF » Swapping EStores
Swapping EStores [message #411314] Mon, 23 July 2007 07:39 Go to next message
Eike Stepper is currently offline Eike StepperFriend
Maybe I asked a similar question before but I couldn't find a thread
anymore.
EStoreEObjectImpl has got an eSetStore() method (even InternalEObject)
which connects the instance to or disconnects it from an EStore.
Unfortunately it is only usable *before* state has been set to the instance.
After lists habe been created lazily it is not possible anymore to
change the store because the it is stored in member fields of the lists.
There is even not a setter to change the list store after construction ;-(
With this implementation I'll have to iterate over the eSettings of the
EStoreEObjectImpl and reflectively change the eStore field.
Maybe I can overwrite createList() and createFeatureMap() to provide
collections with a setter method that can be used after explicit
downcasting.
I'm not sure if at all there is a use case for different stores in
EStoreEObjectImpl and its internal collections.
It would at least be much nicer if abstract superclasses of these
collections were provided that have an abstract eStore() method that I
could implement to return the store of the owner.
What do you think?
Cheers
/Eike
Re: Swapping EStores [message #411315 is a reply to message #411314] Mon, 23 July 2007 07:50 Go to previous messageGo to next message
--------------020903030208020807080402
Oh no:
public static class EStoreFeatureMap extends DelegatingFeatureMap
protected *final *InternalEObject.EStore store;
Hmm, whether reflection can trick this one???
Eike Stepper schrieb:
> anymore.
> instance.
> the EStoreEObjectImpl and reflectively change the eStore field.
> downcasting.
> What do you think?
> Cheers
> /Eike
<html>
<head>
http-equiv="Content-Type">
</head>
Oh no:<br>
<br>
Re: Swapping EStores [message #411319 is a reply to message #411314] Mon, 23 July 2007 12:12 Go to previous messageGo to next message
Eike,
Perhaps base classes that simply fetch the store from the owner would be
a good idea. I suppose it's also possible to use a store than can
itself be redirected to talk to different data sources.
Eike Stepper wrote:
> anymore.
> instance.
> downcasting.
> What do you think?
> Cheers
> /Eike
Re: Swapping EStores [message #411323 is a reply to message #411319] Mon, 23 July 2007 13:56 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
> be a good idea.
Shall I open an Enhancement request?
> I suppose it's also possible to use a store than can itself be
I already do something like that. My stores don't store the model values
themselves, i.e. they don't store instance specific state. But they have
some other data related that is common for certain groups of instances.
> Eike Stepper wrote:
>> anymore.
>> InternalEObject) which connects the instance to or disconnects it
>> from an EStore.
>> instance.
>> construction ;-(
>> downcasting.
>> I could implement to return the store of the owner.
>> What do you think?
>> Cheers
>> /Eike
Re: Swapping EStores [message #411324 is a reply to message #411323] Mon, 23 July 2007 14:01 Go to previous messageGo to next message
Eike,
Yes, please open an enhancement request.
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
>> be a good idea.
> values themselves, i.e. they don't store instance specific state. But
> they have some other data related that is common for certain groups of
> instances.
>> Eike Stepper wrote:
>>> Hi,
>>> anymore.
>>> from an EStore.
>>> instance.
>>> lists.
>>> construction ;-(
>>> downcasting.
>>> What do you think?
>>> Cheers
>>> /Eike
Re: Swapping EStores [message #411325 is a reply to message #411324] Mon, 23 July 2007 14:26 Go to previous message
Ed,
I entered this one: https://bugs.eclipse.org/bugs/show_bug.cgi?id=197487
Somehow I hit Enter before the summary was complete ;-(
It should be "Provide stateless EstoreEList and EStoreFeatureMap base classes"
Cheers
/Eike
Ed Merks schrieb:
> Eike,
> Eike Stepper wrote:
>> Ed Merks schrieb:
>>> Eike,
>>> would be a good idea.
>> of instances.
>>> Eike Stepper wrote:
>>>> Hi,
>>>> thread anymore.
>>>> from an EStore.
>>>> instance.
>>>> lists.
>>>> construction ;-(
>>>> provide collections with a setter method that can be used after
>>>> explicit downcasting.
>>>> that I could implement to return the store of the owner.
>>>> What do you think?
>>>> Cheers
>>>> /Eike
Previous Topic:Serializing a dynamic model instance with xsi:schemaLocation
Next Topic:Setting EDefault to Inherited Constant Value
Current Time: Mon May 28 10:10:04 GMT 2018
Powered by FUDForum. Page generated in 0.02243 seconds
