| caused by: java.io.IOException: The path '/page-ui/src/main/resources/page-designer.transformmodel' [message #410853] |
Wed, 11 July 2007 02:32  |
Alexandre Jaquet Messages: 38 Registered: July 2009 |
Member |
I'm trying to load a resource by using
createPlatformResourceURI("page-ui/src/main/resources/page-designer.transformmodel ",true);
and I'm getting the following exception :
'/page-ui/src/main/resources/page-designer.transformmodel' is unmapped
here is my code snippet :
Hashtable result = new Hashtable();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "*",
new XMIResourceFactoryImpl());
URI fileURI2 =
URI.createPlatformResourceURI("page-ui/src/main/resources/page-designer.transformmodel ",true);
TransformModelPackage packageInstance = TransformModelPackage.eINSTANCE;
Any idea ?
| Re: caused by: java.io.IOException: The path '/page-ui/src/main/resources/page-designer.transformmod [message #410863 is a reply to message #410857] |
Wed, 11 July 2007 08:14  |
Ed Merks Messages: 24689 Registered: July 2009 |
--------------060204060604080802000002
Alexandre,
Please keep in mind that "\" is just another character in a URI. It's
not a separator like it is when used in an OS-specific path. So you'd
be far better off calling
URI.createFileURI(" W:\\advisor\\OFS\\1.40.0\\ofs-designer\\ofs_plugins_editors\ \page-ui ")
I take it this avoids the problem you're seeing?
Alexandre Jaquet wrote:
> Founded by mapping the resource :
> TransformModelPackage transformModelPackage =
> URI mapping =
> URI.createURI(" file://W:\\advisor\\OFS\\1.40.0\\ofs-designer\\ofs_plugins_e ditors\\page-ui");
> EcorePlugin.getPlatformResourceMap().put("page-ui", mapping);
> URI trURI =
> URI.createPlatformResourceURI("page-ui/src/main/resources/page-designer.transformmodel ");
<html>
<head>
</head>
Alexandre,<br>
<br>
be far better off calling<br>
<blockquote>URI.createFileURI(" W:\\advisor\\OFS\\1.40.0\\ofs-designer\\ofs_plugins_editors\ \page-ui ")<br>
</blockquote>
I take it this avoids the problem you're seeing?<br>
<br>
<br>
<blockquote cite="mid:f72b85$adb$1@build.eclipse.org" type="cite">Founded
<br>
<br>
<br>
<br>
URI mapping =
URI.createURI(<a class="moz-txt-link-rfc2396E" href=" file://W:\\advisor\\OFS\\1.40.0\\ofs-designer\\ofs_plugins_e ditors\\page-ui">" file://W:\\advisor\\OFS\\1.40.0\\ofs-designer\\ofs_plugins_e ditors\\page-ui"</a>);
<br>
<br>
<br>
URI trURI =
<br>
</blockquote>
<br>
</body>
</html>
--------------060204060604080802000002--
FUDForum. Page generated in 0.01625 seconds
