Home » Modeling » EMF » remove objects from resource
| remove objects from resource [message #410612] |
Mon, 02 July 2007 11:05  |
Christian Donhofer Messages: 94 Registered: July 2009 |
Member |
hi all,
im trying to remove unnecessary objects from a resource. the following
code throws a ConcurrentModificationException.
//remove blocks of types not needed
for(Object o : render_resource.getContents()){
EObject eo = (EObject)o;
if(eo instanceof HypertextBlockImpl){
HypertextBlockImpl hb = (HypertextBlockImpl)eo;
boolean show = true;
for(String type : blocktypesList.keySet()){
if(type.equalsIgnoreCase(hb.getBlockMeta().getBlocktype().ge tName()) &&
blocktypesList.get(type)[0].equalsIgnoreCase("hide")
System.out.println("REMOVING BLOCK WITH TYPE "+type);
show = false;
//remove block
if(!show){
//tried EcoreUtil.remove() here too --> same exception
render_resource.getContents().remove(eo);
i also tried for(Object o :
EcoreUtil.copyAll(render_resource.getContents())){}
since that works in comparable situations, but of course not when trying
to delete something.
i know that it can't work like that, but somehow i can't find another
solution to this task - can somebody help me with that? =)
TIA, chris
| Re: remove objects from resource [message #410633 is a reply to message #410625] |
Mon, 02 July 2007 13:09   |
Member |
hi ed,
thanks for your reply. since when does that delete method exist?
unfortunately, in the version we've been using for this project, it's not
yet present. anyway, google found me that ng-post containing this method:
public static void delete(EObject eObject)
EObject rootEObject = EcoreUtil.getRootContainer(eObject);
Resource resource = rootEObject.eResource();
Collection usages;
if (resource == null)
usages = UsageCrossReferencer.find(eObject, rootEObject);
else
ResourceSet resourceSet = resource.getResourceSet();
if (resourceSet == null)
usages = UsageCrossReferencer.find(eObject, resource);
else
usages = UsageCrossReferencer.find(eObject, resourceSet);
for (Iterator i = usages.iterator(); i.hasNext(); )
EStructuralFeature.Setting setting =
(EStructuralFeature.Setting)i.next();
if (setting.getEStructuralFeature().isChangeable())
EcoreUtil.remove(setting, eObject);
EcoreUtil.remove(eObject);
does this method equal the one you mean? if so, that doesn't solve my
problem, since i still get the DanglingHrefException when serializing.
if not, i'll try to get the EMF version that implements the method you
were suggesting.
cheers, chris
On Mon, 02 Jul 2007 12:40:56 -0400 Ed Merks wrote:
> Christian,
> Because of bidirectional updates, there will often be reasons why a list
> is modified indirectly. Iterating over a copy should help. Building a
> collection of things to operate on and then doing the removal later is
> also a good technique. Note that EcoreUtil.remove and EcoreUtil.delete
> might do exactly the kind of thing you want. So you could first build a
> collection of the object you want to remove and then use
> EcoreUtil.remove/delete to remove them or delete all references to that.
| Re: remove objects from resource [message #410635 is a reply to message #410633] |
Mon, 02 July 2007 13:23   |
Ed Merks Messages: 25227 Registered: July 2009 |
--------------030505000208010200030204
Christian,
The delete method should find all references to the object within the
resource set and clean those up. Perhaps it should be removing
references to recursively contained children as well, but it does only
what the Javadoc says, so you'd need to call it for the children too...
Christian Donhofer wrote:
> hi ed,
> Collection usages;
> else
> else
> were suggesting.
> cheers, chris
>> Christian,
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Christian,<br>
<br>
| Re: remove objects from resource [message #410640 is a reply to message #410638] |
Mon, 02 July 2007 14:30  |
--------------060606000004000701050407
Christian,
If you look closely at the single argument delete method that you are
calling, you'll see that it needs to walk up the containers of the
argument to find the resource set, so if you've already removed the
object from its container, no resource set will be reachable and no
references will be cleaned up. The debugger is ever so helpful to see
how things are working dynamically...
Christian *Donhofer* wrote:
> On Mon, 02 Jul 2007 13:23:38 -0400 Ed Merks wrote:
>> Christian,
> well, i tried adding the children to the removallist too, like
> remove.add(eo);
> for(Iterator iter = eo.eAllContents(); iter.hasNext(); ){
> remove.add((EObject)iter.next());
> and then
> for(EObject e : remove){
> EcoreUtil.remove(e);
> delete(e);
> and still there seem to be some references, so i guess it's not
> eAllContents i need to use to get all children...?
> cheers, chris
<html>
<head>
<title></title>
</head>
Christian,<br>
<br>
Current Time: Tue Oct 08 07:54:11 EDT 2013
Powered by FUDForum. Page generated in 0.02037 seconds
