Home » Modeling » EMF » How to get the parent of an EAttribute ??
How to get the parent of an EAttribute ?? [message #410299] Tue, 19 June 2007 11:07 Go to next message
Nicholas Loulloudes is currently offline Nicholas LoulloudesFriend
Member
I have the following model
<DocumentRoot>
<Ident>
<ID>123</ID>
<Anot>A1</Anot>
<Anot>A2</Anot>
<Anot>A3</Anot>
</Ident>
</DocumentRoot>
The IdentType has two attributes, ID and Anot. Anot returns an EList of strings.
Now if i do EObject eObject = this.identType; and then
System.out.println(eObject), i get the JobIdentImpl with all the content and values.
Now, in one of my methods, i iterate within the JobIdent and try to get the parent of Anot via:
EObject parent = eAttribute.eContainer();
and then try to print parent, i only get the following:
org.eclipse.emf.ecore.impl.EClassImpl@1c10834 (name: JobIdentificationType)....
This causes problem for me since i cannot get the values of Annot via:
Object value = parent.eGet(eAttribute);
any suggestions?
Thanks.
Re: How to get the parent of an EAttribute ?? [message #410301 is a reply to message #410299] Tue, 19 June 2007 11:13 Go to previous message
Nicholas,
Comments below.
Nicholas Loulloudes wrote:
> Hello,
> <DocumentRoot>
> <Ident>
> <ID>123</ID>
> <Anot>A1</Anot>
> <Anot>A2</Anot>
> <Anot>A3</Anot>
> </Ident>
> </DocumentRoot>
This is asking the parent of the meta data object, which will be another
meta data object and will have nothing to do with your particular instance.
There is no EObject representing the Anot element (unless it was an
element that had a complex type with simple content rather than an
element with a simple type). So this is like wanting to know the parent
of a java.lang.String. A String don't know who is all referencing it,
and, in general, the value of an EAttribute will not know that it's
being referenced by one or more EObjects.
> any suggestions?
> Thanks.
Previous Topic:convert EMF URI to file URI
Next Topic:EReference.eKeys
Current Time: Sun Feb 25 07:19:28 GMT 2018
Powered by FUDForum. Page generated in 0.01791 seconds
