Home » Modeling » EMF » Newbie Question: Update Properties View
Newbie Question: Update Properties View [message #407907] Tue, 20 March 2007 20:41 Go to next message
Thomas Porcham is currently offline Thomas PorchamFriend
Hi everybody,
I started to play around with EMF some days ago.
I like it because of the generic approach. I think I will be able to use
it in many situations.
Here comes my problem:
I created an emf editor by hand, that displays a list of objects in an
editable table. It also has a standard properties view (uses
AdapterFactoryContentProvider as PropertySourceProvider). So you can edit
properties (string properties) in the table and in the properties view.
When I edit properties in the properties view the tables content provider
gets notified and updates the table like this:
public void notifyChanged(Notification notification) {
getTableViewer().update(notification.getNotifier(), null);
However, when I edit a property in the table viewer the property view
won't update.
I tried to update the properties view by calling refresh():
commandStack.addCommandStackListener(new CommandStackListener() {
public void commandStackChanged(final EventObject event) {
if (propertySheetPage != null &&
propertySheetPage.getControl().isDisposed()) {
propertySheetPage.refresh();
But this leeds to an endless recursion. A new command gets created and
executed ,then the listener gets notified and calls refresh(); another
command gets created...
How can I update the properties view after a change of my EMF model?
TIA, cheers,
Thomas
Re: Newbie Question: Update Properties View [message #407909 is a reply to message #407907] Tue, 20 March 2007 21:06 Go to previous messageGo to next message
Steve Blass is currently offline Steve BlassFriend
This quote from Ed back in May of 2005 about avoiding the recursive
looping might apply...
"... way to avoid that is perhaps to do a Display.asyncExec to ensure
that the current interaction is completed before you execute a command
and cause a notification cascade."
And this snippet from the Eclipse Help files shows the pattern for using
Display.asyncExec
// do time-intensive computations
// now update the UI. We don't depend on the result,
// so use async.
display.asyncExec (new Runnable () {
public void run () {
if (!myWindow.isDisposed())
myWindow.redraw ();
// now do more computations
HTH
Steve
Thomas Porcham wrote:
> Hi everybody,
> edit properties (string properties) in the table and in the properties
> view.
> provider gets notified and updates the table like this:
> @Override
> won't update.
> TIA, cheers,
> Thomas
Re: Newbie Question: Update Properties View [message #407939 is a reply to message #407909] Thu, 22 March 2007 09:10 Go to previous message
Thanks for your quick reply!
I will try this.
Previous Topic:Setting xsi:schemaLocation
Next Topic:Looking exact EObject
Current Time: Mon Feb 26 01:45:22 GMT 2018
Powered by FUDForum. Page generated in 0.02277 seconds
