Home » Modeling » EMF » EMF 2.3.0M5 unsettable property
EMF 2.3.0M5 unsettable property [message #407248] Tue, 20 February 2007 13:07 Go to next message
Stephane  Fournier is currently offline Stephane FournierFriend
I used the "unsettable" property with EMF 2.2.x, and it works fine.
I moved to EMF 2.3.0M5 to get Java 5.0 compliance, but it seems that the
"unsettable" property is no longer taken into account at generation time.
The generated code includes set metho
Re: EMF 2.3.0M5 unsettable property [message #407249 is a reply to message #407248] Tue, 20 February 2007 13:15 Go to previous messageGo to next message
Stephane,
The generated code should include a set method. If you make the feature
be not changeable, then there won't be a set method. But this hasn't
changed from 2.2.x to 2.3...
Stephane wrote:
> the "unsettable" property is no longer taken into account at
> generation time.
Re: EMF 2.3.0M5 unsettable property [message #407250 is a reply to message #407249] Tue, 20 February 2007 13:21 Go to previous message
Ed,
First, I am sorry my post was sent too early, but you guess my question.
I'll try that right now.
Stephane.
Ed Merks wrote:
> Stephane,
> Stephane wrote:
>> generation time.
Previous Topic:Attribute default value
Next Topic:confusing explanation
Current Time: Tue May 22 12:10:13 GMT 2018
Powered by FUDForum. Page generated in 0.01661 seconds
