Home » Modeling » EMF » Ecore Annotation as the operation body
Ecore Annotation as the operation body [message #406042] Fri, 22 December 2006 15:46 Go to next message
A. Jibran Shidqie is currently offline A. Jibran ShidqieFriend
I'd like to generate the operation body using EMF model. Is there anyone who
has the experience in using Ecore Annotation as the body of the operation.
What I mean is the body of the operation is generated by some tools and
wrapped as String, then put the string as the Ecore annotation of its
EOperation, then let the EMF codegen generates the model code. And by
modifying the JET templates, those String will be generated as the
corresponding operation body.
What would be the correct thing to do? Is there any problem using that way?
Jibran
Re: Ecore Annotation as the operation body [message #406043 is a reply to message #406042] Fri, 22 December 2006 16:20 Go to previous message
--------------070207020603040708010104
Jibran,
The generator supports this without modifying the templates because
GenOperationImpl has this in it:
protected String getBody()
EOperation eOperation = getEcoreOperation();
EAnnotation eAnnotation =
eOperation.getEAnnotation(*GenModelPackage.eNS_URI*);
return eAnnotation == null ? null :
(String)eAnnotation.getDetails().get("*body*");
Here's an example from SDO.ecore:
<eClassifiers xsi:type="ecore:EClass" name="EDataObject"
eSuperTypes="../../org.eclipse.emf.ecore/model/Ecore.ecore#//EObject
#//DataObject">
<eOperations name="getInstanceProperties" eType="#//EJavaList">
<eAnnotations source="*http://www.eclipse.org/emf/2002/GenModel*">
<details key="*body*" value="return
&lt;%org.eclipse.emf.ecore.sdo.util.SDOUtil%>.getInstanceProperties(this); "/>
</eAnnotations>
</eOperations>
</eClassifiers>
The <%...%> marks things that will be imported so the above produces
this in EDataObjectImpl:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public List getInstanceProperties()
return SDOUtil.getInstanceProperties(this);
Note that the method is fully @generated and was not hand changed.
So you can use this same technique in any Ecore model...
A. Jibran Shidqie wrote:
> Best regards,
> Jibran
<html>
<head>
</head>
Jibran,<br>
<br>
GenOperationImpl has this in it:<br>
<blockquote>&nbsp; protected String getBody()<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; EOperation eOperation = getEcoreOperation();<br>
&nbsp;&nbsp;&nbsp; EAnnotation eAnnotation = eOperation.getEAnnotation(<b>GenModelPackage.eNS_URI</b>); <br>
&nbsp;&nbsp;&nbsp; return eAnnotation == null ? null :
(String)eAnnotation.getDetails().get("<b>body</b>");<br >
&nbsp; }<br>
</blockquote>
Here's an example from SDO.ecore:<br>
<blockquote>&nbsp; &lt;eClassifiers xsi:type="ecore:EClass"
name="EDataObject"
#//DataObject"&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;eOperations name="getInstanceProperties"
eType="#//EJavaList"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;eAnnotations source="<b><a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/GenModel">http://www.eclipse.org/emf/2002/GenModel</a></b>"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;details key="<b>body</b>" value="return
&amp;lt;%org.eclipse.emf.ecore.sdo.util.<font color="#3333ff">SDOUtil</font>%&gt;.getInstanceProperties(this); "/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/eAnnotations&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;/eOperations&gt;<br>
&nbsp; &lt;/eClassifiers&gt;<br>
</blockquote>
The &lt;%...%&gt; marks things that will be imported so the above
produces this in EDataObjectImpl:<br>
<blockquote>&nbsp; /**<br>
&nbsp;&nbsp; * &lt;!-- begin-user-doc --&gt;<br>
&nbsp;&nbsp; * &lt;!-- end-user-doc --&gt;<br>
&nbsp;&nbsp; * @generated<br>
&nbsp;&nbsp; */<br>
&nbsp; public List getInstanceProperties()<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; return <font color="#3333ff">SDOUtil</font>.getInstanceProperties(this); <br>
&nbsp; }<br>
</blockquote>
Note that the method is fully @generated and was not hand changed.<br>
<br>
So you can use this same technique in any Ecore model...<br>
<br>
<br>
<blockquote cite="midemgukt$4l1$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi,
Jibran
</pre>
</blockquote>
<br>
</body>
</html>
--------------070207020603040708010104--
Previous Topic:[Announce] EMF 2.3.0M4 is available
Next Topic:Generated vs. Reflective ItemProviders
Current Time: Mon May 21 07:23:22 GMT 2018
Powered by FUDForum. Page generated in 0.01965 seconds
