Home » Modeling » EMF » Generating ecore file from various sources
Generating ecore file from various sources [message #405657] Fri, 01 December 2006 03:44 Go to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
The EMF generator model (genmodel) can be initialised from several
kinds of sources, including ecore files, Java interfaces and XML
schemas. The standard wizards supports selecting either of these,
before building the genmodel file. In my project I work with dynamic
EMF models and instances, so I cannot rely on the generator. But I
would still want to support e.g. XML schemas, in addition to the
native ecore files. Is it possible to convert the above mentioned
files directly to ecore (or rather, an in-memory EMF model), without
involving the generator? I have seen an example using XSDEcoreBuilder,
which builds a set of EPackages, but what I'm looking for is a more
generic approach. I've tried to understand the importer extension
point, but AFAIU this is tied to the generator.
Hallvard
Re: Generating ecore file from various sources [message #405663 is a reply to message #405657] Fri, 01 December 2006 06:05 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------020405010506040009040403
Hallvard,
Have you seen this article yet?
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
I'm not sure it gets more generic than XSDEcoreBuilder. I.e., an XML
Schema comes in and a corresponding Ecore model comes out. That seems
very generic. There's also a corresponding JavaEcoreBuilder which
processes the annotations from Java interface...
Don't confuse the GenModel with having to use the Generator. The
GenModel helps manage your Ecore models and their dependencies and the
importer framework helps manage both. For example, when processing Java
annotations you need the GenModels for the other models on which the
current model depends...
So in the end, I don't quite understand what you are looking for...
Hallvard Tr
Re: Generating ecore file from various sources [message #405664 is a reply to message #405663] Fri, 01 December 2006 07:01 Go to previous message
Ed,
> Binding XML to Java
Yes, this is my source of information about XSDEcoreBuilder. I agree
it is generic and handles XML sources well.
Aha.
You're right that I was confused. I found slides from EclipseCon 2006,
that explained the importer/exporter mechanism, which is (almost) what
I want. I now better understand the role of GenModel and its use
outside the context of the Generator. I was hoping for a slightly
simpler and leaner mechanism, perhaps at a layer beneath the
importer/exporter, but I accept that this isn't feasible.
Hallvard
>Hallvard Trætteberg wrote:
>> Hallvard
Previous Topic:Interrupt the removal of an element
Next Topic:creating Ecore from OMG XMI?
Current Time: Tue Oct 08 07:49:36 EDT 2013
Powered by FUDForum. Page generated in 0.11735 seconds
