Home » Modeling » EMF » EPackage.Registry.INSTANCE.getEFactory
EPackage.Registry.INSTANCE.getEFactory [message #405328] Wed, 15 November 2006 15:10 Go to next message
Originally posted by: kellypu.ie.ibm.com
Hi all,
I have the following snippet of code
String ePackageName = configElement.getAttribute("nsURI");
EFactory factory = EPackage.Registry.INSTANCE.getEFactory(ePackageName);
if (factory instanceof IAdapterEFactory) {
allAdapterFactories.add(factory);
What I want to do is if the factory is not loaded (i.e. factory = null
above). I want to load the factory. I was wondering how I force this
load. Do I use the EPackage.Descriptor object to achieve this?
Also, The ePackageName a valid package nsURI.
Paul
Re: EPackage.Registry.INSTANCE.getEFactory [message #405329 is a reply to message #405328] Wed, 15 November 2006 15:28 Go to previous messageGo to next message
--------------090405010500020603070402
Paul,
It's better to fetch the EPackage and ask it for the factory. I.e.,
this will always return the factory if there is a registration for the
given nsURI.
EPackage.Registry.INSTANCE.getEPackage(ePackageNsURI).getEFa ctoryInstance()
The registry's getEFactory method is really just designed to support the
factory_override extension point. If there is no override and the
package hasn't been instantiated yet, it will return null so I don't
expect it to be used outside of the package initialization code.
Paul Kelly wrote:
> Hi all,
> Cheers,
> Paul
<html>
<head>
</head>
Paul,<br>
<br>
It's better to fetch the EPackage and ask it for the factory.&nbsp; I.e.,
given nsURI.<br>
<blockquote> EPackage.Registry.INSTANCE.getEPackage(ePackageNsURI).getEFa ctoryInstance() <br>
</blockquote>
the factory_override extension point.&nbsp; If there is no override and the
expect it to be used outside of the package initialization code.<br>
<br>
<br>
Paul Kelly wrote:
<blockquote cite="midejfals$mru$1@utils.eclipse.org" type="cite">Hi
all,
<br>
<br>
<br>
<br>
<br>
EFactory factory =
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;allAdapterFactories. add(factory);
<br>
<br>
<br>
<br>
above). I want to load the factory.&nbsp; I was wondering how I force this
<br>
<br>
<br>
<br>
<br>
Paul
<br>
</blockquote>
<br>
</body>
</html>
--------------090405010500020603070402--
Re: EPackage.Registry.INSTANCE.getEFactory [message #405330 is a reply to message #405329] Wed, 15 November 2006 16:01 Go to previous message
That sorted it.
Thanks (again!) Ed.
Paul
Ed Merks wrote:
> Paul,
> given nsURI.
> Paul Kelly wrote:
>> Hi all,
>> Cheers,
>> Paul
Previous Topic:JMerge problem
Next Topic:XSD editor NullPointerException
Current Time: Sun Feb 25 14:25:16 GMT 2018
Powered by FUDForum. Page generated in 0.02116 seconds
