Home » Modeling » EMF » How to best display child object attributes via ITableItemLabelProvider
How to best display child object attributes via ITableItemLabelProvider [message #403865] Tue, 26 September 2006 18:04 Go to next message
Mario Winterer is currently offline Mario WintererFriend
Hi!
I've a question concerning my ITableItemLabelProvider implementation.
In short: I want to have a JFace table with several columns visualizing
object attributes mixed with attributes of their child object(s).
Therefore imagine the following (simplified) (emf)model:
class Person {
String name;
Address address; // containment
class Address {
String street;
String city;
String zip;
Now I want to "enhance" the generated PersonItemLabelProvider to
implement ITableItemLabelProvider.
Concrete I want PersonItemLabelProvider to provide labels for four
columns where column zero should be the person's name, and columns one
to three should be the person's address fields.
The straight-forward implementation (direct model access via getters)
works fine, but when I change some attributes of the Address object(s),
those changes are not reflected in my JFace table because no label
refresh occures.
I can see clearly why this does not work, but so far I've found no
satisfying solution to this problem (All solutions seem to be some kind
of "hack" or workaround).
What's the best way to implement the method getColumnText(Object, int)
with full viewer-update/refresh support?
Thanks in advance,
Mario
Re: How to best display child object attributes via ITableItemLabelProvider [message #403866 is a reply to message #403865] Tue, 26 September 2006 18:21 Go to previous messageGo to next message
Mario,
One way another you need to produce a ViewerNotification with Person as
the object and with a boolean indicating that the label is affected.
You could do this by specializing the AddressItemProvider to produce
such notifications (and then be sure the adapter has actually been
created, which normally happens because the object is adapted to ask it
for a label or children) or you could have the PersonItemProvider attach
an adapter to the Address to filter its notifications, much like
AddressItemProvider.notifyChanged would do; probably you'll need to make
the item provider stateful in this case and you'll probably want to be
sure to remove the adapter when the item provider is disposed.
Mario Winterer wrote:
> Hi!
> visualizing object attributes mixed with attributes of their child
> object(s).
> class Person {
> String name;
> class Address {
> String street;
> String city;
> String zip;
> object(s), those changes are not reflected in my JFace table because
> no label refresh occures.
> kind of "hack" or workaround).
> Thanks in advance,
> Mario
Re: How to best display child object attributes via ITableItemLabelProvider [message #403869 is a reply to message #403866] Tue, 26 September 2006 18:40 Go to previous messageGo to next message
Hi Ed,
thanks for your quick response.
Specializing AddressItemProvider is no good solution for my purpose,
because I want to use it in several other situations in which that
specialization is not desired.
My final conclusion - and this seems to be one of your suggestions - was
to access the person's address via its AddressItemProvider and to
register an INotifyChangeListener on it that converts
Address-ViewerNotifications to Person-ViewerNotifications.
The disadvantage of this solution is that - as you wrote - I have to
make both, the PersonItemProvider as well as the AddressItemProvider
stateful. This is a little bit annoying because now an adaption of the
gen.model is required to make some internal implementation work.
But I think I can live with that...
Mario
Ed Merks wrote:
> Mario,
>> Hi!
>> object(s).
>> class Person {
>> String name;
>> class Address {
>> String street;
>> String city;
>> String zip;
>> Thanks in advance,
>> Mario
Re: How to best display child object attributes via ITableItemLabelProvider [message #403874 is a reply to message #403869] Tue, 26 September 2006 19:28 Go to previous messageGo to next message
Mario,
You could still create a specialized override that's used only in the
context of the table. This is similar to what I did with
XSDSemanticItemProviderAdapterFactory which has local classes for all
the overrides so that the basic generated item providers and the basic
factory are not modified at all. Probably this pattern would be best
for your scenario. That way the basic things can still be stateless,
but the override factory will make the appropriate things stateful or do
overrides that are appropriate only for that context.
> Hi Ed,
> was to access the person's address via its AddressItemProvider and to
> Mario
> Ed Merks wrote:
>> Mario,
>> as the object and with a boolean indicating that the label is
>> affected. You could do this by specializing the AddressItemProvider
>> to produce such notifications (and then be sure the adapter has
>> actually been created, which normally happens because the object is
>> adapted to ask it for a label or children) or you could have the
>> PersonItemProvider attach an adapter to the Address to filter its
>> notifications, much like AddressItemProvider.notifyChanged would do;
>> probably you'll need to make the item provider stateful in this case
>> and you'll probably want to be sure to remove the adapter when the
>>> Hi!
>>> object(s).
>>> class Person {
>>> String name;
>>> class Address {
>>> String street;
>>> String city;
>>> String zip;
>>> one to three should be the person's address fields.
>>> getters) works fine, but when I change some attributes of the
>>> Address object(s), those changes are not reflected in my JFace table
>>> because no label refresh occures.
>>> int) with full viewer-update/refresh support?
>>> Thanks in advance,
>>> Mario
Re: How to best display child object attributes via ITableItemLabelProvider [message #403876 is a reply to message #403874] Tue, 26 September 2006 19:40 Go to previous message
Sounds interesting; maybe this is what I'm searching for.
I'll make a code investigation. :-)
Mario
Ed Merks wrote:
> Mario,
>> Hi Ed,
>> Thanks,
>> Mario
>> Ed Merks wrote:
>>> Mario,
>>>> Hi!
>>>> object(s).
>>>> class Person {
>>>> String name;
>>>> class Address {
>>>> String street;
>>>> String city;
>>>> String zip;
>>>> Thanks in advance,
>>>> Mario
Previous Topic:createXyzArrayToString and createXyzArrayFromString
Next Topic:delete attribute value from XML file
Current Time: Tue Jan 23 22:16:31 GMT 2018
Powered by FUDForum. Page generated in 0.02112 seconds
