Home » Eclipse Projects » Rich Client Platform (RCP) » Adding Error Log View and writing to Problem View
Adding Error Log View and writing to Problem View [message #403505] Fri, 31 December 2004 18:48 Go to next message
Michael Scott is currently offline Michael ScottFriend
I would like to add the Error Log View to my RCP application so that I can
display logged IStatus objects. I have not found how to activate it. I did
find how to add the Problems view but have not found how to write to it. I
would like pointers to documentation containing such information.
Mike.
Re: Adding Error Log View and writing to Problem View [message #403507 is a reply to message #403505] Sun, 02 January 2005 15:11 Go to previous messageGo to next message
It's in org.eclipse.pde.runtime.
> I did
You have to create markers of type IMarker.PROBLEM.
HTH
Dani
> I
>Thanks,
>Mike.
Re: Adding Error Log View and writing to Problem View [message #403719 is a reply to message #403507] Mon, 03 January 2005 20:54 Go to previous messageGo to next message
Daniel,
Thanks for your help. I placed an addView("org.eclipse.pde.runtime.LogView")
statement in my perspective factory class and the Error Log came right up.
My writes to the plugin log show up fine. I looked up the IMarker interface
in the eclipse help and it describes what I need. I also used such criteria
to find and purchase the book "eclipse Building Commercial Quality
Plug-ins". I found it has a chapter on Markers and another on the Properties
view, which would have been my next question.
Thanks again,
Mike.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:cr92uf$d8a$1@www.eclipse.org...
can
> > I did
> HTH
> Dani
> > I
> >Thanks,
> >Mike.
Re: Adding Error Log View and writing to Problem View [message #403736 is a reply to message #403719] Tue, 04 January 2005 08:10 Go to previous messageGo to next message
>Daniel,
There's also a good article on eclipse.org called "Mark My Words".
Dani
>Thanks again,
>Mike.
>can
>>>I did
>>HTH
>>Dani
>>>I
>>>Thanks,
>>>Mike.
Re: Adding Error Log View and writing to Problem View [message #403937 is a reply to message #403507] Tue, 04 January 2005 13:40 Go to previous messageGo to next message
Originally posted by: ramim.kauhajoki.fi
Could you show me the code how you opened the Error Log-view. Somehow my
code didn't work. Here's what I tried:
layout.addView("org.eclipse.pde.runtime.LogView",
IPageLayout.BOTTOM,
new Float(0.40).floatValue(),
IPageLayout.ID_EDITOR_AREA);
And the result was:
Could not create view: org.eclipse.pde.runtime.LogView
I guess because this is trying to locate the View from my plugin.xml-file
which is not listed in there...??...
- noon -
>> I did
> HTH
> Dani
>> I
>>Thanks,
>>Mike.
Re: Adding Error Log View and writing to Problem View [message #403953 is a reply to message #403937] Wed, 05 January 2005 02:53 Go to previous message
I created a folder and placed it there along with the Problem and Property
Sheet views. I do not have the view listed in my plugin.xml file either. I
do, however, have it listed in my runtime-workbench plugin list. Hope this
helps.
Mike.
public void createInitialLayout(IPageLayout layout) {
// Get the editor area.
String editorArea = layout.getEditorArea();
// Bottom: Task area with Logs and Properties
IFolderLayout bottom = layout.createFolder("Bottom", IPageLayout.BOTTOM,
0.66f,
editorArea);
bottom.addView(IPageLayout.ID_PROBLEM_VIEW);
bottom.addView(IPageLayout.ID_PROP_SHEET);
bottom.addView("org.eclipse.pde.runtime.LogView");
"noon" <ramim@kauhajoki.fi> wrote in message
news:cre6bn$90h$1@www.eclipse.org...
> IPageLayout.BOTTOM,
> And the result was:
> - noon -
can
> >> I did
> > HTH
> > Dani
> >> I
> >>Thanks,
> >>Mike.
Previous Topic:config.ini getting re-written
Next Topic:Hibernate files not found, even in project root
Current Time: Mon May 21 17:12:18 GMT 2018
Powered by FUDForum. Page generated in 0.02993 seconds
