Home » Modeling » EMF » Problem in edit plugin when subclassing from Ecore
Problem in edit plugin when subclassing from Ecore [message #402934] Fri, 11 August 2006 12:52 Go to next message
Victor Sanchez is currently offline Victor SanchezFriend
Hello!
I know that it is not advisable to subclass Ecore, but once I did this I
had problems to navigate models in the Sample Ecore Editor, concretely
with the Properties view. This happens in EMF v2.2.0.
The Item Provider for an EClass that subclasses directly from an Ecore
element lists in its generated 'getPropertyDescriptors' method all the
inherited properties from the Ecore element, together with the ones that
specifically belong to it. The properties are added sequentially through
independent methods whose name is 'add<property_nm>PropertyDescriptor'.
The problem is that those properties that are inherited from an Ecore
element are referencing string such as '_UI_ENamedElement_type' or
'_UI_ENamedElement_name_feature', but these are missing from the
'plugin.properties' generated file in the Edit plugin, so in the
Properties View nothing appeared at all when selecting objects of the
affected types.
In order for the .genmodel to work I have had to change the textual
references to Ecore in the .ecore model by hand from
'eSuperTypes=" ../../../plugin/org.eclipse.emf.ecore/model/Ecore.ecore#...'
to 'eSuperTypes="http://www.eclipse.org/emf/2002/Ecore#...', so otherwise
I wouldn't come up with the abovementioned problem.
What I was wondering is whether the code generation should be more
consistent with these circumstances and either:
1.- automatically include the missing strings in the
'plugin.properties' file or
2.- eliminate the conflicting property descriptor additions for the
'<type>ItemProvider' files, which I suppose is an unacceptable solution.
Victor
Re: Problem in edit plugin when subclassing from Ecore [message #402936 is a reply to message #402934] Fri, 11 August 2006 13:46 Go to previous messageGo to next message
--------------000502090901040102070001
Victor,
I would expect the generated .edit plugin's plugin class to include a
reference to the EcoreEditPlugin's instance like UML2's edit plugin
class does:
* Create the instance.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
public UMLEditPlugin() {
super(new ResourceLocator[]{*EcoreEditPlugin.INSTANCE*,
EMFEditPlugin.INSTANCE});
This will result in delegation during property lookup.
Victor Sanchez wrote:
> Hello!
> affected types.
> Thanks
> Victor
<html>
<head>
</head>
Victor,<br>
<br>
class does:<br>
<blockquote>&nbsp;&nbsp;&nbsp; /**<br>
&nbsp;&nbsp;&nbsp; &nbsp;* Create the instance.<br>
&nbsp;&nbsp;&nbsp; &nbsp;* &lt;!-- begin-user-doc --&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;* &lt;!-- end-user-doc --&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;* @generated NOT<br>
&nbsp;&nbsp;&nbsp; &nbsp;*/<br>
&nbsp;&nbsp;&nbsp; public UMLEditPlugin() {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; super(new ResourceLocator[]{<b>EcoreEditPlugin.INSTANCE</b>,<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; EMFEditPlugin.INSTANCE});<br>
&nbsp;&nbsp;&nbsp; }<br>
</blockquote>
This will result in delegation during property lookup.<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.12.51.59.4328@opencanarias.com"
type="cite">
<pre wrap="">Hello!
independent methods whose name is 'add&lt;property_nm&gt;PropertyDescriptor'.
affected types.
to 'eSuperTypes="<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore#">http://www.eclipse.org/emf/2002/Ecore#</a>...', so otherwise
'&lt;type&gt;ItemProvider' files, which I suppose is an unacceptable solution.
Victor
</pre>
</blockquote>
<br>
</body>
</html>
--------------000502090901040102070001--
Re: Problem in edit plugin when subclassing from Ecore [message #402937 is a reply to message #402936] Fri, 11 August 2006 14:31 Go to previous messageGo to next message
Thank you very much. I finally only included a reference to the
'EcoreEditPlugin' instance and now the editor works fine.
By the way, is there a reason why this reference is not included
automatically in the generated plugin class?
Best regards!
Victor
On Fri, 11 Aug 2006 09:46:29 -0400, Ed Merks wrote:
> Victor,
> class does:
> * @generated NOT
Re: Problem in edit plugin when subclassing from Ecore [message #402941 is a reply to message #402937] Fri, 11 August 2006 15:02 Go to previous messageGo to next message
--------------080707010000080003070608
Victor,
I wondered about that too. Perhaps because all models depend on Ecore's
types we filter Ecore out which we shouldn't do if Ecore's classes are
being extended, but then we recommend folks not do that. If you can
provide a small example to illustrate the issue, we can look into fixing
it. Yes, I'm too lazy, I mean busy, to make one. ;-)
> Best regards!
> Victor
>> Victor,
>> class does:
>> * @generated NOT
<html>
<head>
</head>
Victor,<br>
<br>
I wondered about that too.&nbsp; Perhaps because all models depend on
Ecore's types we filter Ecore out which we shouldn't do if Ecore's
classes are being extended, but then we recommend folks not do that.&nbsp;
If you can provide a small example to illustrate the issue, we can look
into fixing it.&nbsp; Yes, I'm too lazy, I mean busy, to make one. ;-)<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.14.31.30.268400@opencanarias.com"
type="cite">
<pre wrap="">Thank you very much. I finally only included a reference to the
Best regards!
Victor
</pre>
<blockquote type="cite">
<pre wrap="">Victor,
class does:
* @generated NOT
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080707010000080003070608--
Re: Problem in edit plugin when subclassing from Ecore [message #402948 is a reply to message #402941] Fri, 11 August 2006 16:22 Go to previous messageGo to next message
Ok, I know what the problem is. I've based the test on a single EClass
contained in an EPackage and ENamedElement as its ESuper Type.
When editing the .genmodel an Ecore EPackage dependency is shown under
the main package, and under these circumstances the generated .edit
plugin's plugin class includes the dependency with the Ecore Edit
plugin as expected:
* @generated
public TempEditPlugin() {
super
(new ResourceLocator [] {
EcoreEditPlugin.INSTANCE,
Now I put my hands directly upon the .ecore file text and change the
reference to the super type ENamedElement from:
to
and a similar change is performed on the .genmodel file for the
'usedGenPackages' property so it now has the following value:
'usedGenPackages="http://www.eclipse.org/emf/2002/GenModel#//ecore">'
Just after this last modification, the genmodel file is no longer
showing the Ecore dependency in the Sample Ecore Editor, and at the same
time, the edit plugin generation is now missing the Ecore Edit plugin
instance in the resource locator of the 'TempEditPlugin' constructor.
Regards!
Victor
On Fri, 11 Aug 2006 11:02:55 -0400, Ed Merks wrote:
> Victor,
>> Best regards!
>> Victor
Re: Problem in edit plugin when subclassing from Ecore [message #402950 is a reply to message #402948] Fri, 11 August 2006 16:43 Go to previous messageGo to next message
--------------010300050005000907000906
Victor,
If you extend the Ecore types, it's important to use the version of
Ecore with an associated GenModel so that you will pick up all the
GenModel settings for the Ecore model (such as the bit flags setting).
I.e., you really should use
if you are extending Ecore and you are likely run into problems if you
don't (as you're seeing already)...
> plugin as expected:
> * @generated
> super
> to
> Regards!
> Victor
>> Victor,
>>> Best regards!
>>> Victor
<html>
<head>
</head>
Victor,<br>
<br>
&nbsp; I.e., you really should use<br>
<blockquote>
<pre wrap="">org.eclipse.emf.ecore/model/Ecore.ecore</pre>
</blockquote>
don't (as you're seeing already)...<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.16.22.43.874663@opencanarias.com"
type="cite">
<pre wrap="">Ok, I know what the problem is. I've based the test on a single EClass
plugin as expected:
* @generated
super
to
'eSuperTypes=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore#... 'andasimilarchangeisperformedonthe.genmodelfileforthe'usedGe nPackages'propertysoitnowhasthefollowingvalue:'usedGenPackag es= ">"http://www.eclipse.org/emf/2002/Ecore#...'
'usedGenPackages="</a<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/GenModel#//ecore">"http://www.eclipse.org/emf/2002/GenModel#//ecore"</a>&gt;'
Regards!
Victor
</pre>
</pre>
Best regards!
Victor
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010300050005000907000906--
Re: Problem in edit plugin when subclassing from Ecore [message #402951 is a reply to message #402950] Fri, 11 August 2006 17:11 Go to previous message
Ok. My problem did probably arise in the first place because of the
..ecore and .genmodel files I was using, which were generated with an older
EMF version (2.0.X, I think).
Thank you, Ed.
On Fri, 11 Aug 2006 12:43:54 -0400, Ed Merks wrote:
> Victor,
Previous Topic:Attribute - File Browser
Next Topic:stereotypes in Rose mapping to ecore elements
Current Time: Thu Apr 26 00:13:18 GMT 2018
Powered by FUDForum. Page generated in 0.02351 seconds
