Home » Language IDEs » AJDT » workbench build failed 3.0
workbench build failed 3.0 [message #40918] Tue, 28 September 2004 18:11 Go to next message
Originally posted by: poekel.gmx.de
my problem is the following:
I've installed ajdt and aspectj successfully on Eclipse3.0 / WINXP /
Java1.4.2.
But everytime i start eclipse my workspace is hanging up when the project
is build. In eclipse progress bar in the bottom of the workbench appears
"build 0%" and then eclipse crashes.
I've increased the min and max memory to 128m-512m but obviously this
seems not to be the problem...
anyone knows?
thank a lot!
dennis
Re: workbench build failed 3.0 [message #41383 is a reply to message #40918] Fri, 01 October 2004 13:11 Go to previous message
Originally posted by: mchapman.uk.ibm.com
> Java1.4.2.
> anyone knows?
> thank a lot!
It's pretty difficult trying to diagnose problems like this. The easiest
thing might be to try creating a new workspace, make sure some simple
projects are working okay, such as the AspectJ examples included with
AJDT, and then creating a new project and copying your source across from
the old version.
Alternatively, answers to the following might narrow things down a
little. I assume you're using the latest version of AJDT, 1.1.12? Did you
have a previous version of AJDT installed - if so which one? Is the
hanging project an AspectJ project? In what way does Eclipse crash? Which
is your Eclipse build id? And is there anything in your .log file?
Matt.
Re: workbench build failed 3.0 [message #583454 is a reply to message #40918] Fri, 01 October 2004 13:11 Go to previous message
Matt Chapman is currently offline Matt ChapmanFriend
> Java1.4.2.
> anyone knows?
> thank a lot!
the old version.
Matt.
Previous Topic:"java" sources file extensions hardcoded
Next Topic:Can't get AJDT to work...
Current Time: Wed Jan 17 22:35:57 GMT 2018
Powered by FUDForum. Page generated in 0.01885 seconds
