Home » Modeling » EMF » JMERGE without Eclipse
JMERGE without Eclipse [message #402861] Tue, 08 August 2006 14:11 Go to next message
Ben is currently offline BenFriend
Member
I'd like to tun JMerge in the command line without eclipse. It works
succefully when I run jmerge into my eclipse plugin. But when I use this
part of the code in the command line, without eclipse, I'm getting this
exception:
at org.eclipse.jdt.internal.core.util.Util.getLineSeparator(Uti l.java:881)
at org.eclipse.jdt.core.jdom.DOMFactory.<init>(DOMFactory.java:32)
org.eclipse.emf.codegen.merge.java.facade.jdom.JDOMFacadeHel per.getJDOMFactory(JDOMFacadeHelper.java:60)
org.eclipse.emf.codegen.merge.java.facade.jdom.JDOMFacadeHel per.createCompilationUnit(JDOMFacadeHelper.java:67)
org.eclipse.emf.codegen.merge.java.JMerger.createCompilation UnitForContents(JMerger.java:285)
fr.dcn.components.sdk.arogenerator.utils.JMergeUtils.merge(J MergeUtils.java:165)
fr.dcn.components.sdk.arogenerator.codegenerator.VegaGenerat or.generate(VegaGenerator.java:109)
at AnnuaireTest.main(AnnuaireTest.java:45)
Line 881 is:
lineSeparator =
Platform.getPreferencesService().getString(Platform.PI_RUNTI ME,
Platform.PREF_LINE_SEPARATOR, null, scopeContext);
So, I think Preferences service is not initialized because i'm don't
running it into an eclipse application. What should I do?
I initialize JMerge with this code:
private JMerger getJMerger() {
String uri = "";
try {
uri = new
URI(getClass().getResource("/conf/merge.xml").toString()).toString();
} catch (URISyntaxException e) {
e.printStackTrace();
System.out.println("CWD: " + uri);
JControlModel controlModel = new JControlModel();
JDOMFacadeHelper helper = new JDOMFacadeHelper();
//ASTFacadeHelper helper = new ASTFacadeHelper();
controlModel.initialize(helper, uri);
JMerger jmerger = new JMerger(controlModel);
return jmerger;
I tried the ASTFacadeHelper but it doesn't merge anything.
Ben
Re: JMERGE without Eclipse [message #402863 is a reply to message #402861] Tue, 08 August 2006 14:27 Go to previous message
Ben,
Yes, I didn't think JDT was completely set up to work standalone so
you'll need to run headless if you need to use the capability. Perhaps
when we switch from using JDOM to using AST
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=124372), we'll find that
AST will work standalone. We've not experimented with that yet.
Ben wrote:
> Hello,
> this part of the code in the command line, without eclipse, I'm
> getting this exception:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> Line 881 is:
> lineSeparator =
> private JMerger getJMerger() { String uri = "";
> try {
> uri = new
> return jmerger;
> Thanks
> Ben
Previous Topic:Should ItemPropertyDescriptor#isMany handle unspecified multiplicities?
Next Topic:Resource Set and Resources
Current Time: Wed Jun 20 12:03:00 GMT 2018
Powered by FUDForum. Page generated in 0.01571 seconds
