Home » Modeling » EMF » Adding eattributes to existing static eclass
Adding eattributes to existing static eclass [message #400160] Wed, 12 April 2006 13:38 Go to next message
Martin Taal is currently offline Martin TaalFriend
In other posts of the newsgroup I have read that it is not possible to add
dynamic eattributes to an existing generated-static eclass. Is this
neither possible if there is a featuremap (like a choice) present in the
model/eclass? What I am thinking of is something like a xsd choice
(maxOccurs="unbounded") to which I can dynamically add new elements
(estructuralfeatures).
I can remember that I saw something like this when I was
debugging in emf somewhere but I do not remember where this was and maybe
I didn't see it correctly.
Am I thinking in the right direction or is this really not possible?
With Regards, Martin Taal
The Elver Project
Barchman Wuytierslaan 72b
3818 LK Amersfoort
tel: +31 (0)33 462 02 07
fax: +31 (0)33 463 77 12
Mobile: +31 (0)6 288 48 943
email: mtaal@elver.org
web: www.elver.org
Re: Adding eattributes to existing static eclass [message #400165 is a reply to message #400160] Wed, 12 April 2006 15:35 Go to previous message
--------------080003080902020808030102
Martin,
You definitely cannot change the list of features of a generated EClass
or of any EClass for which instances already exist. A wildcard in XML
Schema will result in a feature map that lets you add any
attribute/element (depending on the kind of the wildcard) from any
document root to that feature map. AnyType from the XMLType package is a
good example of this and this project shows how it can be used:
< http://www.eclipse.org/emf/docs/presentations/EclipseCon/Ecl ipseCon2006_EMF_XML_Binding_project.zip>
Martin Taal wrote:
>Hi,
<html>
<head>
</head>
Martin,<br>
<br>
a good example of this and this project shows how it can be used:<a
href=" http://www.eclipse.org/emf/docs/presentations/EclipseCon/Ecl ipseCon2006_EMF_XML_Binding_project.zip"><br>
</a>
<blockquote><a
href=" http://www.eclipse.org/emf/docs/presentations/EclipseCon/Ecl ipseCon2006_EMF_XML_Binding_project.zip"> http://www.eclipse.org/emf/docs/presentations/EclipseCon/Ecl ipseCon2006_EMF_XML_Binding_project.zip</a><br>
</blockquote>
<br>
Martin Taal wrote:
<blockquote cite="midpan.2006.04.12.13.38.11.882608@elver.org"
type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<br>
</body>
</html>
--------------080003080902020808030102--
Previous Topic:Force generation of xsi:type
Next Topic:WhatÂ’s New for Callisto?
Current Time: Tue Apr 24 21:19:56 GMT 2018
Powered by FUDForum. Page generated in 0.01575 seconds
