Home » Modeling » EMF » newbie: "Property Category" in attribute in *.ecore
newbie: "Property Category" in attribute in *.ecore [message #399356] Wed, 15 March 2006 11:59 Go to next message
Frederic is currently offline FredericFriend
What is the purpose of "Property Category", "Property Description" and
"Property Filter Flags" at attribute level in *.ecore?
I suppose that I can group the attributes in groups in the editor by
specifying that - is it correct? But How can they be used? Where can I
read about this issue?
Maybe my question is very easy or stupid but please apologize me as I'm
new to this.
Frederic
Re: newbie: "Property Category" in attribute in *.ecore [message #399357 is a reply to message #399356] Wed, 15 March 2006 12:18 Go to previous messageGo to next message
--------------020207070301090605010907
Frederic,
Try and see is an effective technique. The property category determines
the category label, e.g., Ecore and Edit below, the property description
determines what's shown on the status line when the property is
selected, and the filter lets you specify the filter IDs that must be
active to show the property, e.g., using
org.eclipse.ui.views.properties.expert for this will cause the property
to be displayed only when "Show Advanced Properties" is enabled in the
properties view.
Frederic wrote:
> I'm new to this.
> Frederic
Content-Type: multipart/related;
boundary="------------090200040109040504090800"
--------------090200040109040504090800
<html>
<head>
http-equiv="Content-Type">
</head>
Frederic,<br>
<br>
Re: newbie: "Property Category" in attribute in *.ecore [message #399360 is a reply to message #399357] Wed, 15 March 2006 12:30 Go to previous messageGo to next message
Ed,
I tried to set 'Test Category' in Property Category and 'Test Description'
in Property Description to test it but the attrubute disappear from
properties in the generated model :-( So, I think I miss something...
Frederic
Ed Merks wrote:
> Frederic,
> properties view.
> Frederic wrote:
>> I'm new to this.
>> Frederic
Re: newbie: "Property Category" in attribute in *.ecore [message #399361 is a reply to message #399360] Wed, 15 March 2006 12:41 Go to previous messageGo to next message
--------------080306010308020605060906
Frederic,
I tried this:
And that has this effect:
I'm not sure exactly what you tried. (Did you specify
org.eclipse.ui.views.properties.expert as the filter? That would hide it.)
Frederic wrote:
> Ed,
> Description' in Property Description to test it but the attrubute
> disappear from properties in the generated model :-( So, I think I
> miss something...
> Frederic
> Ed Merks wrote:
>> Frederic,
>> determines the category label, e.g., Ecore and Edit below, the
>> property description determines what's shown on the status line when
>> the property is selected, and the filter lets you specify the filter
>> IDs that must be active to show the property, e.g., using
>> property to be displayed only when "Show Advanced Properties" is
>> enabled in the properties view.
>> Frederic wrote:
>>> Hi,
>>> and "Property Filter Flags" at attribute level in *.ecore?
>>> I read about this issue?
>>> I'm new to this.
>>> Frederic
boundary="------------040004020601080302070105"
--------------040004020601080302070105
<html>
<head>
</head>
Frederic,<br>
<br>
I tried this:<br>
<blockquote><img src="cid:part1.07090804.08030402@ca.ibm.com" alt=""><br>
</blockquote>
And that has this effect:<br>
<blockquote><img src="cid:part2.03080900.06030305@ca.ibm.com" alt=""><br>
</blockquote>
Re: newbie: "Property Category" in attribute in *.ecore [message #399362 is a reply to message #399361] Wed, 15 March 2006 13:01 Go to previous messageGo to next message
Ed,
it's very strange. If I set property category and property description to
attribute EString (as in your example) - everything is ok, the attrubute
is in specified group and all others are in 'Misc' group. But when I set
property category and property description to attribute EBoolean - the
attribute disappears.
Ed Merks wrote:
> Frederic,
> I tried this:
> Frederic wrote:
>> Ed,
>> miss something...
>> Frederic
>> Ed Merks wrote:
>>> Frederic,
>>> Frederic wrote:
>>>> Hi,
>>>> I'm new to this.
>>>> Frederic
Re: newbie: "Property Category" in attribute in *.ecore [message #399364 is a reply to message #399362] Wed, 15 March 2006 14:36 Go to previous message
--------------000204030803010308050405
Frederic,
I tried this:
Which results in this:
I'm not sure what's special about your example...
Frederic wrote:
> Ed,
> to attribute EString (as in your example) - everything is ok, the
> attrubute is in specified group and all others are in 'Misc' group.
> But when I set property category and property description to attribute
> EBoolean - the attribute disappears.
> Ed Merks wrote:
>> Frederic,
>> I tried this:
>> hide it.)
>> Frederic wrote:
>>> Ed,
>>> miss something...
>>> Frederic
>>> Ed Merks wrote:
>>>> Frederic,
>>>> when the property is selected, and the filter lets you specify the
>>>> filter IDs that must be active to show the property, e.g., using
>>>> Frederic wrote:
>>>>> Hi,
>>>>> by specifying that - is it correct? But How can they be used?
>>>>> Where can I read about this issue?
>>>>> as I'm new to this.
>>>>> Frederic
boundary="------------010102050504020502070006"
--------------010102050504020502070006
<html>
<head>
</head>
Frederic,<br>
<br>
I tried this:<br>
<blockquote><img src="cid:part1.05000601.02080804@ca.ibm.com" alt=""><br>
</blockquote>
Which results in this:<br>
<blockquote><img src="cid:part2.00010401.08020907@ca.ibm.com" alt=""><br>
</blockquote>
I'm not sure what's special about your example...<br>
<br>
<br>
Frederic wrote:
<blockquote cite="mid2ccc6d8731534493d744399ba2dd4503$1@www.eclipse.org"
type="cite">Ed,
<br>
<br>
attrubute is in specified group and all others are in 'Misc' group. But
<br>
<br>
Ed Merks wrote:
<br>
<br>
<blockquote type="cite">Frederic,
<br>
</blockquote>
<br>
<blockquote type="cite">I tried this:
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">And that has this effect:
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">I'm not sure exactly what you tried.
Previous Topic:Recursive models
Next Topic:noob: How to know when objects get added to an EList
Current Time: Sun May 27 21:45:39 GMT 2018
Powered by FUDForum. Page generated in 0.02324 seconds
