Home » Modeling » EMF » HREF Problem
HREF Problem [message #398925] Wed, 01 March 2006 13:50 Go to next message
Stefan Sommer is currently offline Stefan SommerFriend
------=_NextPart_000_006F_01C63D3F.82E5F3A0
Content-Type: text/plain;
charset="iso-8859-1"
i am trying to load a xml which has a hyperref to another document. In =
my testcode the getHRef-Method returns null?
adaptorResource.load(options);
adaptor.getConnector().getHref();
Before loading the adaptor i added the 2 required resources to the =
resourceset and i think the loader must initialize the connector ref as =
a proxy. What's going wrong?
=20
The xml i am trying to load:
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<adaptor xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance" =
xsi:noNamespaceSchemaLocation=3D"C:\workspace\wbII\CH.obj.wb.model\resour=
ces\core_modelDefinition.xsd">
<timeout code=3D"da vinci">1000</timeout>
<name>Read_from_Bison</name>
<enabled>true</enabled>
<maxTx>8</maxTx>
<mode>reader</mode>
<length>2</length>
<que>
<enabled>false</enabled>
</que>
<connector href=3D"sample_connector.xml#abc"/>
</adaptor>
The schema for my hyperref-complextype looks like this:
<xs:complexType name=3D"ConnectorRef">
<xs:attribute name=3D"href" type=3D"xs:anyURI" use=3D"required" =
ecore:reference=3D"Connector"/>
</xs:complexType>
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>Hi,</DIV>
<DIV>i am trying to load&nbsp;a xml which has a hyperref&nbsp;to another =
document. In my testcode the getHRef-Method returns null?</DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial><FONT size=3D2>&nbsp;<FONT=20
face=3D"Courier =
New">adaptorResource.load(options);</FONT></FONT></FONT> </DIV>
<DIV><FONT face=3D"Courier New" size=3D2><FONT face=3D"Times New Roman"=20
size=3D3>&nbsp;</FONT><FONT face=3D"Courier New"=20
size=3D2>adaptor.getConnector().getHref();</FONT></FONT></DIV >
<DIV><FONT face=3D"Courier New" size=3D2></FONT>&nbsp;</DIV>
<DIV>&nbsp;Before loading the adaptor i added the 2 required resources =
to the=20
a proxy.=20
What's going wrong?</DIV>
<DIV>&nbsp;</DIV>
<DIV>The xml i am trying to load:</DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV><FONT size=3D2>
<P>&lt;?xml version=3D"1.0" encoding=3D"UTF-8"?&gt;</P>
<P>&lt;adaptor xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore"=20
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance"=20
ces\core_modelDefinition.xsd"&gt;</P>
<P>&lt;timeout code=3D"da vinci"&gt;1000&lt;/timeout&gt;</P>
<P>&lt;name&gt;Read_from_Bison&lt;/name&gt; </P>
<P>&lt;enabled&gt;true&lt;/enabled&gt;</P>
<P>&lt;maxTx&gt;8&lt;/maxTx&gt;</P>
<P>&lt;mode&gt;reader&lt;/mode&gt;</P>
<P>&lt;length&gt;2&lt;/length&gt;</P>
<P>&lt;que&gt;</P>
<P>&lt;enabled&gt;false&lt;/enabled&gt;</P >
<P>&lt;/que&gt;</P>
<P>&lt;connector href=3D"sample_connector.xml#abc"/&gt;</P>
<P>&lt;/adaptor&gt;</FONT></P></DIV></BLOCKQUOTE >
<DIV>The schema for my hyperref-complextype looks like this:</DIV>
<P>&lt;xs:complexType name=3D"ConnectorRef"&gt;</P>
<P>&lt;xs:attribute name=3D"href" type=3D"xs:anyURI" use=3D"required"=20
ecore:reference=3D"Connector"/&gt;</P>
<P>&lt;/xs:complexType&gt;</P></FONT></DIV></BODY ></HTML>
------=_NextPart_000_006F_01C63D3F.82E5F3A0--
Re: HREF Problem [message #398930 is a reply to message #398925] Wed, 01 March 2006 14:55 Go to previous messageGo to next message
--------------020201010409060906030406
Stefan,
Which version of EMF are you using? Older versions used to always treat
handle "href" exactly as it is for XMI, i.e., it would set the value as
the InternalEObject.eProxyURI of the current object.... You can tell
this is happening if adapter.getConnector().eIsProxy() returns true.
Stefan Sommer wrote:
> as a proxy. What's going wrong?
> <adaptor xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation=" C:\workspace\wbII\CH.obj.wb.model\resources\core_modelDefini tion.xsd ">
> <timeout code="da vinci">1000</timeout>
> <maxTx>8</maxTx>
> <mode>reader</mode>
> <length>2</length>
> <que>
> </que>
> <connector href="sample_connector.xml#abc"/>
> </adaptor>
> <xs:complexType name="ConnectorRef">
> <xs:attribute name="href" type="xs:anyURI" use="required"
> ecore:reference="Connector"/>
> </xs:complexType>
<html>
<head>
</head>
Stefan,<br>
<br>
Which version of EMF are you using?&nbsp; Older versions used to always
treat handle "href" exactly as it is for XMI, i.e., it would set the
value as the InternalEObject.eProxyURI of the current object.... You
can tell this is happening if adapter.getConnector().eIsProxy() returns
true.<br>
<br>
<br>
<blockquote cite="middu48rh$34v$1@utils.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta content="MSHTML 6.00.2900.2802" name="GENERATOR">
<style></style>
<div>Hi,</div>
<div>i am trying to load&nbsp;a xml which has a hyperref&nbsp;to another
document. In my testcode the getHRef-Method returns null?</div>
<div>&nbsp;</div>
<div><font face="Arial"><font size="2">&nbsp;<font face="Courier New">adaptorResource.load(options);</font></font></font> </div>
<div><font face="Courier New" size="2"><font face="Times New Roman"
size="3">&nbsp;</font><font face="Courier New" size="2">adaptor.getConnector().getHref();</font></font> </div>
<div>&nbsp;</div>
<div>&nbsp;Before loading the adaptor i added the 2 required resources to
the resourceset and i think the loader must initialize the connector
ref as a proxy. What's going wrong?</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>The xml i am trying to load:</div>
<blockquote style="margin-right: 0px;" dir="ltr">
<div><font size="2"> </font>
<p><font size="2">&lt;?xml version="1.0" encoding="UTF-8"?&gt;</font></p>
<p><font size="2">&lt;adaptor
xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xsi:noNamespaceSchemaLocation=" C:\workspace\wbII\CH.obj.wb.model\resources\core_modelDefini tion.xsd "&gt;</font></p>
<p><font size="2">&lt;timeout code="da
vinci"&gt;1000&lt;/timeout&gt;</font></p>
<p><font size="2">&lt;name&gt;Read_from_Bison&lt;/name&gt; </font></p>
<p><font size="2">&lt;enabled&gt;true&lt;/enabled&gt; </font></p>
<p><font size="2">&lt;maxTx&gt;8&lt;/maxTx&gt;</font ></p>
<p><font size="2">&lt;mode&gt;reader&lt;/mode&gt;</font ></p>
<p><font size="2">&lt;length&gt;2&lt;/length&gt;</font ></p>
<p><font size="2">&lt;que&gt;</font></p>
<p><font size="2">&lt;enabled&gt;false&lt;/enabled&gt; </font></p>
<p><font size="2">&lt;/que&gt;</font></p>
<p><font size="2">&lt;connector href="sample_connector.xml#abc"/&gt;</font></p>
<p><font size="2">&lt;/adaptor&gt;</font></p>
</div>
</blockquote>
<div>&nbsp;</div>
<div>The schema for my hyperref-complextype looks like this:</div>
<p>&lt;xs:complexType name="ConnectorRef"&gt;</p>
<p>&lt;xs:attribute name="href" type="xs:anyURI" use="required"
ecore:reference="Connector"/&gt;</p>
<p>&lt;/xs:complexType&gt;</p>
</font></div>
</blockquote>
<br>
</body>
</html>
--------------020201010409060906030406--
Re: HREF Problem [message #398935 is a reply to message #398930] Wed, 01 March 2006 16:46 Go to previous messageGo to next message
------=_NextPart_000_00A8_01C63D58.12E60A40
i am using EMF Version 2.1.2 and the method =
adaptor.getConnector().eIsProxy() returns true. Do i have to use a newer =
version of emf or is there another solution to access the referenced =
object without loading it explicitly?
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:du4ckk$e9j$1@utils.eclipse.org...
Stefan,
Which version of EMF are you using? Older versions used to always =
treat handle "href" exactly as it is for XMI, i.e., it would set the =
value as the InternalEObject.eProxyURI of the current object.... You can =
tell this is happening if adapter.getConnector().eIsProxy() returns =
true.
Stefan Sommer wrote:=20
i am trying to load a xml which has a hyperref to another document. =
<maxTx>8</maxTx>
<mode>reader</mode>
<length>2</length>
<que>
</que>
</adaptor>
</xs:complexType>
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR></HEAD>
<DIV><FONT size=3D1>&nbsp;</FONT><FONT face=3DArial size=3D2>Hi,</FONT>
<P><FONT face=3DArial size=3D2>i am using EMF Version 2.1.2 and the =
method=20
version=20
of emf or is there another solution to access the referenced object =
without=20
loading it explicitly?</FONT></P></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
schrieb im Newsbeitrag <A=20
href=3D"news:du4ckk$e9j$1@utils.eclipse.org">news:du4ckk$e9j$1@utils.ecli=
pse.org</A>...</DIV>Stefan,<BR><BR>Which=20
version of EMF are you using?&nbsp; Older versions used to always =
treat handle=20
"href" exactly as it is for XMI, i.e., it would set the value as the=20
InternalEObject.eProxyURI of the current object.... You can tell this =
is=20
true.<BR><BR><BR>Stefan=20
Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu48rh$34v$1@utils.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV>Hi,</DIV>
<DIV>i am trying to load&nbsp;a xml which has a hyperref&nbsp;to =
another=20
<DIV>&nbsp;</DIV>
face=3D"Courier =
<DIV><FONT face=3D"Courier New" size=3D2><FONT face=3D"Times New =
Roman"=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;Before loading the adaptor i added the 2 required =
resources to=20
the resourceset and i think the loader must initialize the connector =
ref as=20
a proxy. What's going wrong?</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=3D2></FONT>
<P><FONT size=3D2>&lt;?xml version=3D"1.0"=20
encoding=3D"UTF-8"?&gt;</FONT></P><FONT size=3D2></FONT>
<P><FONT size=3D2>&lt;adaptor xmlns:ecore=3D<A =
class=3Dmoz-txt-link-rfc2396E=20
href=3D"http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/em=
f/2002/Ecore"</A>=20
xmlns:xsi=3D<A class=3Dmoz-txt-link-rfc2396E=20
href=3D"http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/200=
1/XMLSchema-instance"</A>=20
ces\core_modelDefinition.xsd"&gt;</FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;timeout code=3D"da=20
vinci"&gt;1000&lt;/timeout&gt;</FONT></P><FONT size=3D2></FONT>
<P><FONT =
size=3D2>&lt;name&gt;Read_from_Bison&lt;/name&gt; </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT =
size=3D2>&lt;enabled&gt;true&lt;/enabled&gt; </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;maxTx&gt;8&lt;/maxTx&gt;</FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;mode&gt;reader&lt;/mode&gt;</FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;length&gt;2&lt;/length&gt;</FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;que&gt;</FONT></P><FONT size=3D2></FONT>
<P><FONT =
size=3D2>&lt;enabled&gt;false&lt;/enabled&gt; </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2>&lt;/que&gt;</FONT></P><FONT size=3D2></FONT>
<P><FONT size=3D2>&lt;connector=20
href=3D"sample_connector.xml#abc"/&gt;</FONT></P><FONT =
size=3D2></FONT>
<P><FONT size=3D2>&lt;/adaptor&gt;</FONT></P></DIV></BLOCKQUOTE >
<DIV>&nbsp;</DIV>
<P>&lt;xs:attribute name=3D"href" type=3D"xs:anyURI" =
use=3D"required"=20
<P>&lt;/xs:complexType&gt;</P></FONT></DIV></BLOCKQUOTE ><BR></BLOCKQUOTE>=
</BODY></HTML>
------=_NextPart_000_00A8_01C63D58.12E60A40--
Re: HREF Problem [message #398946 is a reply to message #398935] Wed, 01 March 2006 20:18 Go to previous messageGo to next message
--------------080705020803010507040107
Stefan,
XMLHandler has this code in the constructor:
hrefAttribute = XMLResource.HREF;
if
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE_STYLE)))
hrefAttribute = null;
This SAXXMLHandler method uses that:
protected void handleObjectAttribs(EObject obj)
if (attribs != null)
InternalEObject internalEObject = (InternalEObject)obj;
for (int i = 0, size = attribs.getLength(); i < size; ++i)
String name = attribs.getQName(i);
if (name.equals(idAttribute))
xmlResource.setID(internalEObject, attribs.getValue(i));
else if (name.equals(*hrefAttribute*) &&
(!recordUnknownFeature || types.peek() != UNKNOWN_FEATURE_TYPE))
handleProxy(internalEObject, attribs.getValue(i));
else if (!name.startsWith(XMLResource.XML_NS) &&
!notFeatures.contains(name))
setAttribValue(obj, name, attribs.getValue(i));
So you need this to be null for it to work properly. Are you using the
XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
> newer version of emf or is there another solution to access the
> referenced object without loading it explicitly?
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> schrieb im
> Newsbeitrag news:du4ckk$e9j$1@utils.eclipse.org...
> Stefan,
> the value as the InternalEObject.eProxyURI of the current
> object.... You can tell this is happening if
>> connector ref as a proxy. What's going wrong?
>> <?xml version="1.0" encoding="UTF-8"?>
>> <maxTx>8</maxTx>
>> <mode>reader</mode>
>> <length>2</length>
>> <que>
>> </que>
>> </adaptor>
>> </xs:complexType>
<html>
<head>
</head>
Stefan,<br>
<br>
XMLHandler has this code in the constructor:<br>
<br>
<small>&nbsp;&nbsp;&nbsp; hrefAttribute = XMLResource.HREF;<br>
&nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; if
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE_STYLE))) <br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hrefAttribute = null;<br>
&nbsp;&nbsp;&nbsp; }</small><br>
<br>
This SAXXMLHandler method uses that:<br>
<blockquote><small>&nbsp; protected void handleObjectAttribs(EObject obj)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; if (attribs != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; InternalEObject internalEObject = (InternalEObject)obj;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for (int i = 0, size = attribs.getLength(); i &lt; size; ++i)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; String name = attribs.getQName(i);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (name.equals(idAttribute))<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; xmlResource.setID(internalEObject, attribs.getValue(i));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if (name.equals(<b>hrefAttribute</b>) &amp;&amp;
(!recordUnknownFeature || types.peek() != UNKNOWN_FEATURE_TYPE))<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; handleProxy(internalEObject, attribs.getValue(i));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if (!name.startsWith(XMLResource.XML_NS) &amp;&amp;
!notFeatures.contains(name))<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; setAttribValue(obj, name, attribs.getValue(i));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
</blockquote>
So you need this to be null for it to work properly.&nbsp; Are you using the
<small>XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?</small><br>
<br>
<br>
<blockquote cite="middu4j58$4dl$1@utils.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<div><font size="1">&nbsp;</font><font face="Arial" size="2">Hi,</font>
<p><font face="Arial" size="2">i am using EMF Version 2.1.2 and the
method adaptor.getConnector().eIsProxy() returns true. Do i have to use
a newer version of emf or is there another solution to access the
referenced object without loading it explicitly?</font></p>
</div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt;
schrieb im Newsbeitrag <a href="news:du4ckk$e9j$1@utils.eclipse.org">news:du4ckk$e9j$1@utils.eclipse.org</a>...</div>
Stefan,<br>
<br>
true.<br>
<br>
<br>
<style></style>
<div>Hi,</div>
<div>&nbsp;</div>
face="Times New Roman" size="3">&nbsp;</font><font face="Courier New"
<div>&nbsp;</div>
to the resourceset and i think the loader must initialize the connector
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>
<p><font size="2">&lt;adaptor xmlns:ecore=<a
</div>
</blockquote>
<div>&nbsp;</div>
</font></div>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080705020803010507040107--
Re: HREF Problem [message #398967 is a reply to message #398946] Thu, 02 March 2006 09:18 Go to previous messageGo to next message
------=_NextPart_000_0009_01C63DE2.A2735B10
When i set the option "OPTION_USE_ENCODED_ATTRIBUTE_STYLE" to false it =
works fine!
thankz a lot
greets stef
news:du4vhr$cm5$1@utils.eclipse.org...
Stefan,
hrefAttribute =3D XMLResource.HREF;
=20
if =
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE=
_STYLE)))
hrefAttribute =3D null;
if (attribs !=3D null)
InternalEObject internalEObject =3D (InternalEObject)obj;
for (int i =3D 0, size =3D attribs.getLength(); i < size; ++i)
String name =3D attribs.getQName(i);
else if (name.equals(hrefAttribute) && =
(!recordUnknownFeature || types.peek() !=3D UNKNOWN_FEATURE_TYPE))
else if (!name.startsWith(XMLResource.XML_NS) && =
So you need this to be null for it to work properly. Are you using =
the XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
Hi,=20
Stefan,
true.
i am trying to load a xml which has a hyperref to another =
Before loading the adaptor i added the 2 required resources to =
the resourceset and i think the loader must initialize the connector ref =
<maxTx>8</maxTx>
<mode>reader</mode>
<length>2</length>
<que>
</que>
</adaptor>
</xs:complexType>
<HTML><HEAD>
<DIV><FONT size=3D2><FONT size=3D3>When i set the option</FONT>=20
"OPTION_USE_ENCODED_ATTRIBUTE_STYLE" </FONT><FONT size=3D3>to false it =
works=20
fine!</FONT></DIV>
<DIV><FONT size=3D2></FONT>&nbsp;</DIV>
<DIV>thankz a lot</DIV>
<DIV>greets stef</DIV>
<BLOCKQUOTE=20
href=3D"news:du4vhr$cm5$1@utils.eclipse.org">news:du4vhr$cm5$1@utils.ecli=
pse.org</A>...</DIV>Stefan,<BR><BR>XMLHandler=20
has this code in the constructor:<BR><BR><SMALL>&nbsp;&nbsp;&nbsp;=20
hrefAttribute =3D XMLResource.HREF;<BR>&nbsp;&nbsp;&nbsp; =
<BR>&nbsp;&nbsp;&nbsp;=20
if=20
_STYLE)))<BR>&nbsp;&nbsp;&nbsp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hrefAttribute =3D=20
null;<BR>&nbsp;&nbsp;&nbsp; }</SMALL><BR><BR>This SAXXMLHandler method =
uses=20
that:<BR>
<BLOCKQUOTE><SMALL>&nbsp; protected void handleObjectAttribs(EObject=20
obj)<BR>&nbsp; {<BR>&nbsp;&nbsp;&nbsp; if (attribs !=3D=20
null)<BR>&nbsp;&nbsp;&nbsp; {<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
InternalEObject internalEObject =3D=20
(InternalEObject)obj;<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for (int i =
=3D 0, size=20
=3D attribs.getLength(); i &lt; size; =
++i)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
{<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; String name =3D=20
attribs.getQName(i);<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; =
if=20
(name.equals(idAttribute))<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; =
{<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;=20
xmlResource.setID(internalEObject,=20
attribs.getValue(i));<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
}<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if=20
(name.equals(<B>hrefAttribute</B>) &amp;&amp; (!recordUnknownFeature =
||=20
types.peek() !=3D=20
UNKNOWN_FEATURE_TYPE))<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; =
handleProxy(internalEObject,=20
(!name.startsWith(XMLResource.XML_NS) &amp;&amp;=20
!notFeatures.contains(name))<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp=
;=20
setAttribValue(obj, name,=20
}<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<BR>&nbsp;&nbsp;&nbsp; =
}<BR>&nbsp;=20
}</SMALL><BR></BLOCKQUOTE>So you need this to be null for it to work =
properly.&nbsp; Are you using the=20
<SMALL>XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE=20
option?</SMALL><BR><BR><BR>Stefan Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu4j58$4dl$1@utils.eclipse.org type=3D"cite">
<DIV><FONT size=3D1>&nbsp;</FONT><FONT face=3DArial =
size=3D2>Hi,</FONT>=20
method=20
adaptor.getConnector().eIsProxy() returns true. Do i have to use a =
newer=20
object=20
without loading it explicitly?</FONT></P></DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; schrieb =
im=20
Newsbeitrag <A=20
treat=20
value as=20
tell this=20
is happening if adapter.getConnector().eIsProxy() returns=20
true.<BR><BR><BR>Stefan Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu48rh$34v$1@utils.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV>Hi,</DIV>
another=20
<DIV>&nbsp;</DIV>
face=3D"Courier =
Roman"=20
<DIV>&nbsp;</DIV>
resources=20
to the resourceset and i think the loader must initialize the =
connector=20
ref as a proxy. What's going wrong?</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>
<P><FONT =
<P><FONT =
<P><FONT =
<P><FONT =
<DIV>&nbsp;</DIV>
<DIV>The schema for my hyperref-complextype looks like =
this:</DIV>
use=3D"required"=20
</BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0009_01C63DE2.A2735B10--
Re: HREF Problem [message #398978 is a reply to message #398967] Thu, 02 March 2006 12:47 Go to previous message
--------------050805030404090904050301
Stefan,
I'm concerned that it might be working correctly, but for the wrong
reason. Perhaps you've generated code before this bugzilla was fixed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512
I would expect the resource to use that option set to TRUE for both load
and save like this:
public Resource createResource(URI uri) {
XMLResource result = new WemResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);*
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
> works fine!
> thankz a lot
> greets stef
> Newsbeitrag news:du4vhr$cm5$1@utils.eclipse.org...
> Stefan,
> if
> using the XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
>> schrieb im Newsbeitrag news:du4ckk$e9j$1@utils.eclipse.org...
>> Stefan,
>> always treat handle "href" exactly as it is for XMI, i.e., it
>> would set the value as the InternalEObject.eProxyURI of the
>> current object.... You can tell this is happening if
>>> Hi,
>>> the connector ref as a proxy. What's going wrong?
>>> <adaptor
>>> <maxTx>8</maxTx>
>>> <mode>reader</mode>
>>> <length>2</length>
>>> <que>
>>> </que>
>>> </adaptor>
>>> </xs:complexType>
<html>
<head>
</head>
Stefan,<br>
<br>
reason.&nbsp; Perhaps you've generated code before this bugzilla was fixed:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512">https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512</a><br>
</blockquote>
load and save like this:<br>
<br>
<small>&nbsp;&nbsp;&nbsp; public Resource createResource(URI uri) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; XMLResource result = new WemResourceImpl(uri);<br>
extendedMetaData);<br>
<br>
Boolean.TRUE);<br>
<br>
<b>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
Boolean.TRUE);</b><br>
Boolean.TRUE);<br>
<br>
Boolean.TRUE);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return result;<br>
<br>
<blockquote cite="middu6d71$d1a$1@utils.eclipse.org" type="cite">
<div><font size="2"><font size="3">When i set the option</font>
"OPTION_USE_ENCODED_ATTRIBUTE_STYLE" </font><font size="3">to false it
works fine!</font></div>
<div>&nbsp;</div>
<div>thankz a lot</div>
<div>&nbsp;</div>
<div>greets stef</div>
<blockquote
schrieb im Newsbeitrag <a href="news:du4vhr$cm5$1@utils.eclipse.org">news:du4vhr$cm5$1@utils.eclipse.org</a>...</div>
Stefan,<br>
<br>
<br>
<br>
&nbsp; {<br>
</blockquote>
<br>
<br>
the method adaptor.getConnector().eIsProxy() returns true. Do i have to
use a newer version of emf or is there another solution to access the
</div>
<blockquote
Stefan,<br>
<br>
true.<br>
<br>
<br>
<style></style>
<div>Hi,</div>
another document. In my testcode the getHRef-Method returns null?</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
resources to the resourceset and i think the loader must initialize the
connector ref as a proxy. What's going wrong?</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote dir="ltr" style="margin-right: 0px;">
<div>
</div>
</blockquote>
<div>&nbsp;</div>
use="required" ecore:reference="Connector"/&gt;</p>
</font></div>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050805030404090904050301--
Previous Topic:EMF editor not writing certain attributes to XML
Next Topic:HREF and xlink
Current Time: Fri Apr 20 07:20:18 GMT 2018
Powered by FUDForum. Page generated in 0.01997 seconds
