Home » Modeling » EMF » How to connect my ecore model with my another ecore model?
Re: How to connect my ecore model with my another ecore model? [message #398009 is a reply to message #398008] |
Mon, 23 January 2006 20:00   |
user Messages: 296 Registered: July 2009 |
Hi, Ed
Thanks for you reply.
Actually I am using RSA. I have two ecore model: Main.ecore and
TLink.ecore. TLink.ecore has an reference whose EType is one of EClass
of Main.ecore. Then I launched a Run-time Workbench to test it. In the
run-time workbench, I saw the Main and ELink in "Example EMF Model
Creation Wizards". But when I tried to instantiate one, I got the error
"Unhandled event loop exception".
Any hints?
Tao
Ed Merks wrote:
> Tao,
> Maybe you should try the "Generating and Extended Model" tutorial, since
> that does basically this. Maybe the problem is as simple as being sure
> to specify your plugin dependencies correctly. Often folks will fiddle
> with the build path, only to have the same problem come back at runtime.
> user@domain.invalid wrote:
>> I tried to connect one of my ecore model with another ecore model by
>> EReference. However, when I tried to lauch a run-time workbench to
>> test them together, it doen't work. The new run-time workbench is
>> launched, but I cannot instantiated an instance. I don't know what the
>> problem is.
>> Any help will be appreciated.
>> Thanks.
>> Tao
Re: How to connect my ecore model with my another ecore model? [message #398010 is a reply to message #398009] |
Mon, 23 January 2006 20:05   |
Ed Merks Messages: 29329 Registered: July 2009 |
Tao,
The workspace/.metadata/.log or the Error log view will provide more
details, but this definitely sounds like a missing plugin dependency is
the likely cause. Does the plugin containing TLink.ecore depend on the
plugin containing Main.ecore?
> Hi, Ed
> error "Unhandled event loop exception".
> Any hints?
> Tao
> Ed Merks wrote:
>> Tao,
>> since that does basically this. Maybe the problem is as simple as
>> being sure to specify your plugin dependencies correctly. Often
>> folks will fiddle with the build path, only to have the same problem
>>> the problem is.
>>> Thanks.
>>> Tao
Re: How to connect my ecore model with my another ecore model? [message #398016 is a reply to message #398010] |
Mon, 23 January 2006 21:27   |
The thing is that I checked the dependencies of the plugin.xml file. And
I added all Main.edit, Main.editor into the required plug-ins list of
TLink.edit and TLink.editor respectively. Then I launched the run-time
workbench, but I just saw "Main" in "Example EMF Model Creation Wizard"
this time and I instantiated it. There is no error. But where is my TLink?
Thank you so much.
Tao
Ed Merks wrote:
> Tao,
>> Hi, Ed
>> Any hints?
>> Tao
>> Ed Merks wrote:
>>> Tao,
>>>> the problem is.
>>>> Thanks.
>>>> Tao
Re: How to connect my ecore model with my another ecore model? [message #398024 is a reply to message #398016] |
Tue, 24 January 2006 11:47   |
Tao,
For me a question like this is a little like tea leaf reading only
without a tea cup or leaves. If you look at the tutorial I pointed you
too, you'll have a working example that you can compare to your
non-working example. I'd expect your TLink editor's plugin.xml to
declare an editor and a wizard and for those to show up in your runtime
workbench...
> And I added all Main.edit, Main.editor into the required plug-ins list
> of TLink.edit and TLink.editor respectively. Then I launched the
> run-time workbench, but I just saw "Main" in "Example EMF Model
> Creation Wizard" this time and I instantiated it. There is no error.
> Thank you so much.
> Tao
> Ed Merks wrote:
>> Tao,
>> is the likely cause. Does the plugin containing TLink.ecore depend
>> on the plugin containing Main.ecore?
>>> Hi, Ed
>>> EClass of Main.ecore. Then I launched a Run-time Workbench to test
>>> it. In the run-time workbench, I saw the Main and ELink in "Example
>>> EMF Model Creation Wizards". But when I tried to instantiate one, I
>>> got the error "Unhandled event loop exception".
>>> Any hints?
>>> Tao
>>> Ed Merks wrote:
>>>> Tao,
>>>>> by EReference. However, when I tried to lauch a run-time workbench
>>>>> to test them together, it doen't work. The new run-time workbench
>>>>> is launched, but I cannot instantiated an instance. I don't know
>>>>> what the problem is.
>>>>> Thanks.
>>>>> Tao
Re: How to connect my ecore model with my another ecore model? [message #398032 is a reply to message #398024] |
Tue, 24 January 2006 18:25  |
Hi, Ed Merks
Thank you for your help. I fixed the problem.
Actually, the problem is that I used RSA's ecore Editor to creat my
Ecore models, rather than Rational Rose model or annotated Java code.
Because of this, I have to "Load Resource" Main.ecore into TLink.ecore.
Then the generated TLink.genModel will automatically build up plug-in
dependencies.
Another mistake I made is that I did not assign an unique URI for each
package.
Everything is fine now.
Tao
Ed Merks wrote:
> Tao,
> workbench...
>> Thank you so much.
>> Tao
>> Ed Merks wrote:
>>> Tao,
>>>> Hi, Ed
>>>> Any hints?
>>>> Tao
>>>> Ed Merks wrote:
>>>>> Tao,
>>>>>> Thanks.
>>>>>> Tao
Current Time: Thu Apr 26 06:03:26 GMT 2018
Powered by FUDForum. Page generated in 0.02492 seconds
