Home » Modeling » EMF » Unmodifiable model
Unmodifiable model [message #396835] Wed, 16 November 2005 18:43 Go to next message
Brad Townsend is currently offline Brad TownsendFriend
I'm writing a plug-in that uses an EMF model and that model will be
accessible through an extension point. While my plugin needs to modify
the model, I only intend to provide read-only access through the
extension point.
Is there a mechanism in EMF that can create an unmodifiable model
reference from an EMF model? The functionality I'm looking for would be
similar to the Java API method
java.util.Collections.unmodifiableCollection(Collection c) but for EMF.
-Brad
Re: Unmodifiable model [message #396837 is a reply to message #396835] Wed, 16 November 2005 18:53 Go to previous message
Brad,
You could add an EContentAdapter that throws an exception for any change
that it sees. Something like an ChangeRecorder could be used to do the
same thing, and could be used to undo the change to restore the state.
> extension point.
> be similar to the Java API method
> -Brad
Previous Topic:How do YOU lazily load EMF objects from a server?
Next Topic:[Announce] EMF 2.1.2 M200511161952 is available
Current Time: Tue Apr 24 10:56:17 GMT 2018
Powered by FUDForum. Page generated in 0.02197 seconds
