Home » Modeling » EMF » use of dynamic templates with Java 5
use of dynamic templates with Java 5 [message #396003] Tue, 04 October 2005 07:48 Go to next message
Henrik Rentz-Reichert is currently offline Henrik Rentz-ReichertFriend
--------------000400050206090409070004
Content-Type: text/plain; charset=us-ascii
I would like to use dynamic templates in conjunction with Java 5.
When I do so I see a warning in the error log (see attachment) and the
code generation aborts silently.
I'm using eclipse
Version: 3.1.0
Build id: I20050627-1435
Eclipse Modeling Framework (EMF)
Version: 2.2.0.I200508040200
Build id: 200508040200
Henrik
Henrik Rentz-Reichert mailto://hrr@protos.de
name="log.txt"
Content-Disposition: inline;
filename="log.txt"
Warning 2005-10-04 09:38:24.17
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel ActionBarContributor$GenerateAction.run(GenModelActionBarCon tributor.java:295)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.UnsupportedClassVersionError: org/eclipse/emf/codegen/ecore/templates/model/Interface_ (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at org.eclipse.emf.codegen.jet.JETEmitter.initialize(JETEmitter .java:472)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl$1.i nitialize(GenModelImpl.java:1355)
at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:592)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.gene rate(GenBaseImpl.java:381)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenClassImpl.gen erate(GenClassImpl.java:1129)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.g enerate(GenPackageImpl.java:2183)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.gen erate(GenModelImpl.java:1742)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel ActionBarContributor$8.generate(GenModelActionBarContributor .java:219)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel ActionBarContributor$9.execute(GenModelActionBarContributor. java:279)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:98)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:110)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
--------------000400050206090409070004--
Re: use of dynamic templates with Java 5 [message #396010 is a reply to message #396003] Tue, 04 October 2005 14:28 Go to previous messageGo to next message
--------------070103070002060507070306
Henrik,
It looks like you are trying to run something compiled for 1.5 in a 1.4
runtime, which doesn't work because the .class files produced by 1.5
can't be read by a 1.4 runtime...
Henrik Rentz-Reichert wrote:
>Hi,
>I'm using eclipse
>Version: 3.1.0
>Regards,
>Henrik
>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>at java.security.AccessController.doPrivileged(Native Method)
>Root exception:
<html>
<head>
</head>
Henrik,<br>
<br>
can't be read by a 1.4 runtime...<br>
<br>
<br>
<blockquote cite="middhtc5j$59g$1@news.eclipse.org" type="cite">
<pre wrap="">Hi,
I'm using eclipse
Version: 3.1.0
Henrik
</pre>
<pre wrap="">
<hr size="4" width="90%">
Root exception:
</pre>
</blockquote>
<br>
</body>
</html>
--------------070103070002060507070306--
Re: use of dynamic templates with Java 5 [message #396024 is a reply to message #396010] Wed, 05 October 2005 08:08 Go to previous message
Ed,
thanks. That solved the problem.
Regards, Henrik
Ed Merks wrote:
> Henrik,
>>Hi,
>>I'm using eclipse
>>Version: 3.1.0
>>Regards,
>>Henrik
Previous Topic:Access to EMF models
Next Topic:can the generator produce a log file
Current Time: Mon Apr 23 13:47:47 GMT 2018
Powered by FUDForum. Page generated in 0.01757 seconds
