Home » Modeling » EMF » Trying to generate model using headless invocation throws Exception
Trying to generate model using headless invocation throws Exception [message #395738] Wed, 21 September 2005 12:07 Go to next message
Enrique is currently offline EnriqueFriend
Member
I want to generate the ecore model automatically and modified the existing
example from org.eclipse.xsd.ecore.importer a little bit.
My root structure looks like this:
C:\test\eclipse\workspace\testp\src
C:\test\eclipse\workspace\testp\model\test.xsd
C:\test\eclipse\workspace\testp\emf
C:\test\eclipse\codegenWorkspace
My eclipse project is "testp" and from there I would like to generate the
genmodel of test.xsd
I would like to have the generated model file in the codegenWorkspace.
I am trying to do that with the following command
*** my gen.bat ***********************************************************
* set MAIN_DIR=C:\test\eclipse\workspace
* set WORKSPACE=%MAIN_DIR%\..\codegenWorkspace
* startup.jar org.eclipse.core.launcher.Main -clean -data %WORKSPACE%
* -application org.eclipse.xsd.ecore.importer.XSD2GenModel
* %MAIN_DIR%\model\test.xsd %MAIN_DIR%\emf\test.genmodel -modelProject
* %MAIN_DIR%\src -copyright "This is my code."
This produces the a .log file which contains information
about an IllegalArgumentException, which is shown below.
I would appreciate every little help.
Thanks.
*** .log file
!SESSION 2005-09-21 13:33:10.554
eclipse.buildId=I20050627-1435
java.version=1.4.2_09
Framework arguments: org.eclipse.core.launcher.Main -application
C:\test\eclipse\workspace\model\test.xsd
C:\test\eclipse\workspace\emf\test.genmodel -modelProject
C:\test\eclipse\workspace\src -copyright This is my code.
Command-line arguments: org.eclipse.core.launcher.Main -clean -data
C:\test\eclipse\workspace\..\codegenWorkspace -application
!ENTRY org.eclipse.emf.importer 2 0 2005-09-21 13:33:14.260
!MESSAGE Error
!STACK 1
org.eclipse.core.runtime.CoreException[0]:
java.lang.IllegalArgumentException: Error: No schema file (.xsd or .wsdl)
specified
org.eclipse.xsd.ecore.importer.XSDImporterApplication.proces sArguments(XSDImporterApplication.java:134)
org.eclipse.emf.importer.ModelImporterApplication.run(ModelI mporterApplication.java:143)
org.eclipse.emf.importer.ModelImporterApplication$1.run(Mode lImporterApplication.java:99)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
org.eclipse.emf.importer.ModelImporterApplication.run(ModelI mporterApplication.java:117)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!SUBENTRY 1 org.eclipse.emf.importer 4 0 2005-09-21 13:33:14.260
!MESSAGE Error
!STACK 0
specified
Re: Trying to generate model using headless invocation throws Exception [message #395739 is a reply to message #395738] Wed, 21 September 2005 12:34 Go to previous messageGo to next message
--------------070400000600050905060003
Enrique,
You say the file is at C:\test\eclipse\workspace\*testp\*model\test.xsd,
but your command line specifies C:\test\eclipse\workspace\model\test.xsd.
> existing example from org.eclipse.xsd.ecore.importer a little bit.
> the genmodel of test.xsd
> *** my gen.bat
> * -application org.eclipse.xsd.ecore.importer.XSD2GenModel *
> %MAIN_DIR%\model\test.xsd %MAIN_DIR%\emf\test.genmodel -modelProject *
> Thanks.
> *** .log file
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !MESSAGE Error
> !STACK 1
> .wsdl) specified
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Error
> !STACK 0
> .wsdl) specified
> at
> at
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
http-equiv="Content-Type">
</head>
Enrique,<br>
<br>
You say the file is at C:\test\eclipse\workspace\<b>testp\</b>model\test.xsd,
C:\test\eclipse\workspace\model\test.xsd.<br>
<br>
<br>
Enrique wrote:
<blockquote cite="mid061854482e48c66f0b33f2f71d4d75ca$1@www.eclipse.org"
type="cite">I want to generate the ecore model automatically and
modified the existing example from org.eclipse.xsd.ecore.importer a
little bit.
<br>
<br>
<br>
<br>
<br>
Re: Trying to generate model using headless invocation throws Exception [message #395766 is a reply to message #395739] Thu, 22 September 2005 06:52 Go to previous messageGo to next message
Member
Ooops, I fixed it. Thanks so far.
But even fixing this mistake there are exactly the same exception.
I tried following commands among others
-clean
-data %MAIN_DIR%
%MAIN_DIR%\testp\model\test.xsd %MAIN_DIR%\testp\emf\test.genmodel
-modelProject %MAIN_DIR%\testp\src
** and ************************************************************ ***
-clean
-data %WORKSPACE%
No one was working
Re: Trying to generate model using headless invocation throws Exception [message #395774 is a reply to message #395766] Thu, 22 September 2005 11:43 Go to previous messageGo to next message
--------------080807080503070107010900
Enrique,
According to the usage syntax, you need to specify two arguments after
-modelProject, i.e., I'd expect "-modelProject %MAIN_DIR%\testp src"
Usage: { <model.xsd> | <model.wsdl> }+ [ <model.genmodel> [ -reload
] ] <OPTION>
<OPTION> ::= [ <PROJECT-OPTION> ] [ <PACKAGE-MAP> ] [
<PACKAGES> ]
{ <REF-GEN-MODEL> }*
[ <TEMPLATE-PATH> ] [ <MODEL-PLUGIN-ID> ] [
<COPYRIGHT> ]
[ <SDO> ] [ <QUIET> ]
<PROJECT-OPTION> ::= <MODEL-PROJECT> [ <EDIT-PROJECT> ] [
<EDITOR-PROJECT> ]
[ <TESTS-PROJECT> ]
<MODEL-PROJECT> ::= *-modelProject <model-directory> <fragment-path>*
<EDIT-PROJECT> ::= -editProject <edit-directory> <fragment-path>
<EDITOR-PROJECT> ::= -editorProject <editor-directory> <fragment-path>
<TESTS-PROJECT> ::= -testsProject <tests-directory> <fragment-path>
<PACKAGE-MAP> ::= -packageMap { <nsURI> <qualified-package-name> }+
<PACKAGES> ::= -packages { <nsURI> }+
<REF-GEN-MODEL> ::= -refGenModel <model.genmodel> { <nsURI> }+
<TEMPLATE-PATH> ::= -templatePath <template-directory>
<MODEL-PLUGIN-ID> ::= -modelPluginID <plugin-ID>
<COPYRIGHT> ::= -copyright <copyright-string>
<SDO> ::= -sdo
<QUIET> ::= -quiet
Specifying no -packages is the same as specifying them all
Use ##local to represent the null nsURI
For example:
xsd2genmodel
example.xsd
result/model/Example.genmodel
-modelProject result src
-editProject result.edit src
-editorProject result.editor src
-packages http://www.example.com/Example1
> startup.jar org.eclipse.core.launcher.Main -clean -data %MAIN_DIR%
> -modelProject %MAIN_DIR%\testp\src -copyright "This is my code."
> No one was working
<html>
<head>
</head>
Enrique,<br>
<br>
<blockquote><small>Usage: { &lt;model.xsd&gt; | &lt;model.wsdl&gt; }+ [
&lt;model.genmodel&gt; [ -reload ] ] &lt;OPTION&gt;<br>
&lt;OPTION&gt;
Re: Trying to generate model using headless invocation throws Exception [message #395776 is a reply to message #395774] Thu, 22 September 2005 14:06 Go to previous messageGo to next message
Member
I tried it also with two arguments before, the same way you described the
example below. But it didn`t work either. No matter what I do, I always
get the same exception.
Re: Trying to generate model using headless invocation throws Exception [message #395777 is a reply to message #395776] Thu, 22 September 2005 14:18 Go to previous messageGo to next message
Member
I forgot to mention that I am using
Eclipse 3.1 and EMF 2.1.
Maybe I missed something.
Re: Trying to generate model using headless invocation throws Exception [message #395779 is a reply to message #395777] Thu, 22 September 2005 15:51 Go to previous messageGo to next message
Enrique,
If even the basic usage printing isn't working, there's something
serious going wrong with the installation. Can you try clearing the
..log and doing the scenario again to see what things all show up in the
..log? (It's in <your-workspace>/.metadata/.log.)
Re: Trying to generate model using headless invocation throws Exception [message #395799 is a reply to message #395779] Fri, 23 September 2005 08:44 Go to previous messageGo to next message
Member
Trying:
set %ECL_PLUG%=C:\test\eclipse\plugins
set
classpath=;%ECL_PLUG%\org.eclipse.ant.core_3.1.0.jar;%ECL_PL UG%\org.eclipse.ant.ui_3.1.0.jar;%ECL_PLUG%\org.eclipse.comp are_3.1.0.jar;%ECL_PLUG%\org.eclipse.core.boot_3.1.0.jar;%EC L_PLUG%\org.eclipse.core.commands_3.1.0.jar;%ECL_PLUG%\org.e clipse.core.expressions_3.1.0.jar;%ECL_PLUG%\org.eclipse.cor e.filebuffers_3.1.0.jar;%ECL_PLUG%\org.eclipse.core.resource s.compatibility_3.1.0.jar;%ECL_PLUG%\org.eclipse.core.resour ces.win32_3.1.0.jar;%ECL_PLUG%\org.eclipse.core.resources_3. 1.0.jar;%ECL_PLUG%\org.eclipse.core.runtime.compatibility_3. 1.0.jar;%ECL_PLUG%\org.eclipse.core.runtime_3.1.0.jar;%ECL_P LUG%\org.eclipse.core.variables_3.1.0.jar;%ECL_PLUG%\org.ecl ipse.debug.core_3.1.0.jar;%ECL_PLUG%\org.eclipse.debug.ui_3. 1.0.jar;%ECL_PLUG%\org.eclipse.draw2d_3.1.0.jar;%ECL_PLUG%\o rg.eclipse.emf.activities_2.1.0.jar;%ECL_PLUG%\org.eclipse.e mf.ant_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.codegen.ecore.ui _2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.codegen.ecore_2.1.0.ja r;%ECL_PLUG%\org.eclipse.emf.codegen.ui_2.1.0.jar;%ECL_PLUG% \org.eclipse.emf.codegen_2.1.0.jar;%ECL_PLUG%\org.eclipse.em f.common.ui_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.common_2.1. 0.jar;%ECL_PLUG%\org.eclipse.emf.commonj.sdo_2.1.0.jar;%ECL_ PLUG%\org.eclipse.emf.ecore.change.edit_2.1.0.jar;%ECL_PLUG% \org.eclipse.emf.ecore.change_2.1.0.jar;%ECL_PLUG%\org.eclip se.emf.ecore.edit_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.ecore .editor_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.ecore.sdo.edit_ 2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.ecore.sdo.editor_2.1.0. jar;%ECL_PLUG%\org.eclipse.emf.ecore.sdo_2.1.0.jar;%ECL_PLUG %\org.eclipse.emf.ecore.xmi_2.1.0.jar;%ECL_PLUG%\org.eclipse .emf.ecore_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.edit.ui_2.1. 0.jar;%ECL_PLUG%\org.eclipse.emf.edit_2.1.0.jar;%ECL_PLUG%\o rg.eclipse.emf.examples_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf .importer.ecore_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.importe r.java_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.importer.rose_2. 1.0.jar;%ECL_PLUG%\org.eclipse.emf.importer_2.1.0.jar;%ECL_P LUG%\org.eclipse.emf.java.edit_2.1.0.jar;%ECL_PLUG%\org.ecli pse.emf.java.editor_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.jav a_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.mapping.ecore2ecore.e ditor_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.mapping.ecore2eco re_2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.mapping.ecore2xml.ui _2.1.0.jar;%ECL_PLUG%\org.eclipse.emf.mapping.ecore2xml_2.1. 0.jar;%ECL_PLUG%\org.eclipse.emf.mapping.ui_2.1.0.jar;%ECL_P LUG%\org.eclipse.emf.mapping.xsd2ecore.editor_2.1.0.jar;%ECL _PLUG%\org.eclipse.emf.mapping.xsd2ecore_2.1.0.jar;%ECL_PLUG %\org.eclipse.emf.mapping_2.1.0.jar;%ECL_PLUG%\org.eclipse.e mf_2.1.0.jar;%ECL_PLUG%\org.eclipse.gef.examples.flow_3.1.0. jar;%ECL_PLUG%\org.eclipse.gef.examples.logic_3.1.0.jar;%ECL _PLUG%\org.eclipse.gef.examples.shapes_3.1.0.jar;%ECL_PLUG%\ org.eclipse.gef.examples.text_3.1.0.jar;%ECL_PLUG%\org.eclip se.gef_3.1.0.jar;%ECL_PLUG%\org.eclipse.help.appserver_3.1.0 .jar;%ECL_PLUG%\org.eclipse.help.base_3.1.0.jar;%ECL_PLUG%\o rg.eclipse.help.ui_3.1.0.jar;%ECL_PLUG%\org.eclipse.help_3.1 .0.jar;%ECL_PLUG%\org.eclipse.jdt.core_3.1.0.jar;%ECL_PLUG%\ org.eclipse.jdt.debug.ui_3.1.0.jar;%ECL_PLUG%\org.eclipse.jd t.launching_3.1.0.jar;%ECL_PLUG%\org.eclipse.jdt.ui_3.1.0.ja r;%ECL_PLUG%\org.eclipse.jdt_3.1.0.jar;%ECL_PLUG%\org.eclips e.jface.text_3.1.0.jar;%ECL_PLUG%\org.eclipse.jface_3.1.0.ja r;%ECL_PLUG%\org.eclipse.uml2.codegen.ecore.ui_1.1.0.jar;%EC L_PLUG%\org.eclipse.uml2.codegen.ecore_1.1.0.jar;%ECL_PLUG%\ org.eclipse.uml2.common.edit_1.1.0.jar;%ECL_PLUG%\org.eclips e.uml2.common_1.1.0.jar;%ECL_PLUG%\org.eclipse.uml2.ecore.im porter_1.1.0.jar;%ECL_PLUG%\org.eclipse.uml2.edit_1.1.0.jar; %ECL_PLUG%\org.eclipse.uml2.editor_1.1.0.jar;%ECL_PLUG%\org. eclipse.uml2.examples.emof2ecore_1.1.0.jar;%ECL_PLUG%\org.ec lipse.uml2.examples.ui_1.1.0.jar;%ECL_PLUG%\org.eclipse.uml2 .examples_1.1.0.jar;%ECL_PLUG%\org.eclipse.uml2.resources_1. 1.0.jar;%ECL_PLUG%\org.eclipse.uml2_1.1.0.jar;%ECL_PLUG%\org .eclipse.xsd.ecore.importer_2.1.0.jar;%ECL_PLUG%\org.eclipse .xsd.edit_2.1.0.jar;%ECL_PLUG%\org.eclipse.xsd.editor_2.1.0. jar;%ECL_PLUG%\org.eclipse.xsd_2.1.0.jar
-modelProject %MAIN_DIR%\testp src -packages
http://www.example.com/Example1 -copyright "This is my code."
This is the .log file:
!SESSION 2005-09-23 09:37:22.938
C:\test\eclipse\workspace\testp\emf\test.genmodel -modelProject
C:\test\eclipse\workspace\testp src -packages
http://www.example.com/Example1 -copyright This is my code.
C:\test\eclipse\workspace -application
!ENTRY org.eclipse.emf.importer 2 0 2005-09-23 09:37:26.534
!MESSAGE Error
!STACK 1
specified
!SUBENTRY 1 org.eclipse.emf.importer 4 0 2005-09-23 09:37:26.534
!MESSAGE Error
!STACK 0
specified
Re: Trying to generate model using headless invocation throws Exception [message #395803 is a reply to message #395799] Fri, 23 September 2005 10:18 Go to previous messageGo to next message
Enrique,
I have a feeling that the problem is caused by what you've put on your
classpath. One does not normally put all the Eclipse plugins on the
classpath and I have a feeling that doing that will prevent proper
plugin initialization. Try it with only startup.jar on your classpath.
If you can't get the usage print-out when passing no arguments to the
application the really must be a configuration issue and the classpath
sounds like a likely possibility...
Enrique wrote:
> Trying:
> set
> !MESSAGE Error
> !STACK 1
> .wsdl) specified
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Error
> !STACK 0
> .wsdl) specified
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Trying to generate model using headless invocation throws Exception [message #395810 is a reply to message #395803] Fri, 23 September 2005 12:15 Go to previous messageGo to next message
Member
I was despereate. That`s the reason I have added almost everything to the
classpath. :-)
The issues were the same before.
Re: Trying to generate model using headless invocation throws Exception [message #395811 is a reply to message #395810] Fri, 23 September 2005 12:22 Go to previous messageGo to next message
--------------050607040305070106010605
Enrique,
I know these kind of problems can be really frustrating. Maybe you
should try running it under debug control.
You've stated that running just this doesn't print the usage
so I would try setting a breakpoint in
org.eclipse.emf.importer.ModelApplicationImporter and see what's going
on with the arguments since there should be none for this simple case
public void run(IProgressMonitor progressMonitor, String[]
arguments) throws Exception
try
progressMonitor.beginTask("", 1);
if (arguments.length == 0 ||
"-help".equalsIgnoreCase(arguments[0].toString()))
printUsage();
else
processArguments(arguments, 0);
execute(new SubProgressMonitor(progressMonitor, 1));
finally
progressMonitor.done();
> the classpath. :-)
<html>
<head>
</head>
Enrique,<br>
<br>
Re: Trying to generate model using headless invocation throws Exception [message #395849 is a reply to message #395811] Mon, 26 September 2005 14:01 Go to previous messageGo to next message
Member
Thanks a lot for your help!
I knew that I missed something. I`ve deleted everything(eclipse, ...) and
cleaned up my classpath and added step by step only a few paths. After
each step I`ve tried to run the generator. Every time the same exception
came. At the end IŽve added the startup.jar to the classpath, then the
help instruction was displayed, you have already shown me. I was really
absolutely sure taht IŽve added it before, but ...
Now I`m trying to generate the model.
My model looks like this:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:element name="testApp" type="xsd:string"/>
</xsd:schema>
Of course I tried also some schemas with more complexity, but it didn`t
work either. And I get the following exception:
!SESSION 2005-09-26 15:57:00.285
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application
Command-line arguments: -data C:\test\eclipse\workspace -application
!ENTRY org.eclipse.emf.importer 2 0 2005-09-26 15:57:03.179
!MESSAGE Error
!STACK 1
org.eclipse.core.runtime.CoreException[0]: java.lang.NullPointerException
at org.apache.crimson.tree.ElementNode2.getAttributeNodeNS(Unkn own Source)
at org.apache.crimson.tree.ElementNode2.hasAttributeNS(Unknown Source)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:2336)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:2329)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEStructuralFeature( XSDEcoreBuilder.java:2004)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2117)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:2067)
org.eclipse.xsd.ecore.importer.XSDImporter.doComputeEPackage s(XSDImporter.java:123)
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:664)
org.eclipse.emf.importer.ModelImporterApplication.computeEPa ckages(ModelImporterApplication.java:350)
org.eclipse.emf.importer.ModelImporterApplication.execute(Mo delImporterApplication.java:186)
org.eclipse.emf.importer.ModelImporterApplication.run(ModelI mporterApplication.java:144)
!SUBENTRY 1 org.eclipse.emf.importer 4 0 2005-09-26 15:57:03.179
!MESSAGE Error
!STACK 0
!ENTRY org.eclipse.osgi 2005-09-26 15:57:03.259
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.team.core (66).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.team.internal.core.TeamPlugin.start() of bundle
org.eclipse.team.core.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.core.internal.resources.Workspace.initializeTeam Hook(Workspace.java:1300)
org.eclipse.core.internal.resources.Workspace.getTeamHook(Wo rkspace.java:1181)
at org.eclipse.core.internal.resources.Rules.<init>(Rules.java:40)
org.eclipse.core.internal.resources.Workspace.getRuleFactory (Workspace.java:1161)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:132)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:200)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/team/internal/core/UserStringMappings
at org.eclipse.team.core.Team.<clinit>(Team.java:64)
at org.eclipse.team.internal.core.TeamPlugin.start(TeamPlugin.j ava:75)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
... 23 more
Root exception:
Re: Trying to generate model using headless invocation throws Exception [message #395850 is a reply to message #395849] Mon, 26 September 2005 14:05 Go to previous messageGo to next message
Member
IŽve just seen that there is a popular bug from crimson ...
I guess it is this one. I try to fix that.
Re: Trying to generate model using headless invocation throws Exception [message #395855 is a reply to message #395850] Mon, 26 September 2005 14:32 Go to previous messageGo to next message
Member
Finally it works!!!
java org.eclipse.core.launcher.Main -data %MAIN_DIR% -application
Re: Trying to generate model using headless invocation throws Exception [message #395857 is a reply to message #395855] Mon, 26 September 2005 14:34 Go to previous messageGo to next message
Enrique,
I'm glad to hear it finally worked. Sorry it was such a hassle.
Enrique wrote:
> Finally it works!!!
Re: Trying to generate model using headless invocation throws Exception [message #395860 is a reply to message #395857] Mon, 26 September 2005 16:11 Go to previous messageGo to next message
Member
Now ,there is even one issue.
How do invoke the generation using RSA (version 6.0.1)?
IŽve found an eclipse sub directory of it, having a startup.jar file.
Trying to start an invocation by adding this startup.jar file to the
classpath failed.
Do you know how get this invocation?
If not, I think IŽm gonne ask some guys of the RSA development team. (If
there one)
Re: Trying to generate model using headless invocation throws Exception [message #395862 is a reply to message #395860] Mon, 26 September 2005 20:39 Go to previous messageGo to next message
Enrique,
Sorry, I can't really provide help for product specific issues.
> classpath failed.
> (If there one)
Re: Trying to generate model using headless invocation throws Exception [message #395868 is a reply to message #395862] Tue, 27 September 2005 06:02 Go to previous messageGo to next message
Member
Ok, no problem.
I`m gonna ask some guys of RSA.
Thanks a lot for you help.
Re: Trying to generate model using headless invocation throws Exception [message #718793 is a reply to message #395860] Thu, 25 August 2011 11:20 Go to previous messageGo to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
i want to do the similar task, I am creating ecore dynamically and i want to generate classes from ecore model, i think, i also need to use headless invocation. Can you please guide me how to do that?
i will be very thankful to you
Warmest Regards,
Re: Trying to generate model using headless invocation throws Exception [message #718905 is a reply to message #718793] Thu, 25 August 2011 15:08 Go to previous message
You've considered using the Ant tasks?
On 25/08/2011 4:20 AM, ModelGeek wrote:
> Warmest Regards,
Previous Topic:(no subject)
Next Topic:creating genmodel and generating code from genmodel in standalone application
Current Time: Sat Apr 21 23:21:34 GMT 2018
Powered by FUDForum. Page generated in 0.02592 seconds
