Home » Modeling » EMF » model reference at runtime.
model reference at runtime. [message #395679] Mon, 19 September 2005 13:11 Go to next message
Rashmy A is currently offline Rashmy AFriend
I have created two EMF Projects GSConnection and GSUtil and generated its
model and edit code. Next I created a 3rd EMF project called GSBod that
references GSConnection and GSUtil. I was successful in generating the
model, edit and editor code for GSBod with all references resolved but when
I test GSBod Editor in my runtime workbench, I get the following error..
java.lang.ExceptionInInitializerError
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unsa feFieldAccessorF
actory.java:25)
sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFac tory.java:122)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:917)
at java.lang.reflect.Field.getFieldAccessor(Field.java:898)
at java.lang.reflect.Field.get(Field.java:357)
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(R
egistryReader.java:167)
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistry
Impl.java:107)
com.teamcenter.gside.model.connection.impl.GSConnectionPacka geImpl.init(GSCo
nnectionPackageImpl.java:118)
com.teamcenter.gside.model.bod.impl.GSBodPackageImpl.init(GS BodPackageImpl.j
ava:215)
com.teamcenter.gside.model.bod.GSBodPackage.<clinit>(GSBodPackage.java:62)
com.teamcenter.gside.model.bod.presentation.GSBodModelWizard . <init>(GSBodMod
elWizard.java:108)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAcces
sorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstruc
torAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:162)
nsion(ConfigurationElement.java:142)
nsion(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutab
leExtension(ConfigurationElementHandle.java:48)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:236)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExten
sion(WorkbenchWizardElement.java:118)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(Workbenc
hWizardElement.java:276)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$6.createWiz ard(NewWizardNew
Page.java:724)
Looks like the GSConnection and GSUtil are not found in the registry. Could
you please let me know what runtime references are required for GSBod Editor
to work in the runtime workbench.
Rashmy
Re: model reference at runtime. [message #395680 is a reply to message #395679] Mon, 19 September 2005 13:20 Go to previous messageGo to next message
Rashmy,
It sounds like there was an exception initializing the package, but you
are only showing the stack where the exception is caught and rethrown.
The information about what caused the exception is where the interesting
information is hiding and you've not shown that.
You didn't fiddle with classpaths to make your example compile, did you?
Rashmy wrote:
>Hi,
> at
>actory.java:25)
> at
> at
> at
>Impl.java:107)
> at
> at
>ava:215)
> at
> at
>elWizard.java:108)
> at
>sorImpl.java:39)
> at
> at
> at
> at
> at
> at
>:236)
> at
> at
> at
>Page.java:724)
>Thanks,
>Rashmy
Re: model reference at runtime. [message #395682 is a reply to message #395680] Mon, 19 September 2005 13:39 Go to previous messageGo to next message
Ed,
I did not make any changes to the classpath. While creating GSBod Project I
referenced GSConnection.genmodel and GSUtil.genmodel in the 'Referenced
generator models' area. There were absolutely no problems in generating the
model,edit or editor code for GSBod. When I create the model in the runtime
workbench I just the error -'Selected wizard could not be started' and in
the details pannel I see the error -
'java.lang.ExceptionInInitializerError'. The console does not have any error
message... Let me know how I should go about debugging this problem.
Here is the complete output from the log file -
actory.java:25)
Impl.java:107)
ava:215)
elWizard.java:108)
sorImpl.java:39)
:236)
Page.java:724)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNod
e.java:145)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNod
e.java:128)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizar
dNode.java:125)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage
..java:101)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(Wor
kbenchWizardSelectionPage.java:99)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:747)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContribu
tionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.eclipse.emf.common.util.WrappedException:
com.teamcenter.gside.model.util.UtilPackage
egistryReader.java:172)
Impl.java:107)
com.teamcenter.gside.model.util.impl.GSUtilPackageImpl.init( GSUtilPackageImp
l.java:106)
nnectionPackageImpl.java:123)
com.teamcenter.gside.model.connection.GSConnectionPackage.<clinit >(GSConnect
ionPackage.java:60)
Rashmy
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:dgmdt4$801$1@news.eclipse.org...
> Rashmy,
> Rashmy wrote:
> >Hi,
when
> > at
F
> >actory.java:25)
> > at
> > at
R
> > at
y
> >Impl.java:107)
> > at
o
> > at
j
> >ava:215)
> > at
> > at
d
> >elWizard.java:108)
> > at
s
> >sorImpl.java:39)
> > at
c
> > at
e
> > at
e
> > at
e
> > at
b
> > at
> > at
a
> >:236)
> > at
n
> > at
c
> > at
w
> >Page.java:724)
Could
Editor
> >Thanks,
> >Rashmy
Re: model reference at runtime. [message #395684 is a reply to message #395682] Mon, 19 September 2005 13:52 Go to previous messageGo to next message
--------------000203020908020401020900
Rashmy,
The trace still looks truncated to me. I still can't tell what is the
ultimate cause here is. Can you try clearing your .log and ensuring
that you capture all the information produced when running into this
problem?
Rashmy wrote:
>Ed,
> at
>actory.java:25)
> at
> at
> at
>Impl.java:107)
> at
> at
>ava:215)
> at
> at
>elWizard.java:108)
> at
>sorImpl.java:39)
> at
> at
> at
> at
> at
> at
>:236)
> at
> at
> at
>Page.java:724)
> at
>e.java:145)
> at
>:1044)
> at
>e.java:128)
> at
>dNode.java:125)
> at
>.java:101)
> at
> at
> at
> at
>tem.java:488)
> at
>tionItem.java:400)
> at
> at
>java:226)
> at
> at
> at
> at
>.java:25)
> at
> at
>Impl.java:107)
> at
>l.java:106)
> at
> at
>ionPackage.java:60)
>Thanks,
>Rashmy
>>Rashmy,
>>Rashmy wrote:
>>>Hi,
>when
>>>at
>F
>>>actory.java:25)
>>>at
>>>at
>R
>>>at
>y
>>>Impl.java:107)
>>>at
>o
>>>at
>j
>>>ava:215)
>>>at
>>>at
>d
>>>elWizard.java:108)
>>>at
>s
>>>sorImpl.java:39)
>>>at
>c
>>>at
>e
>>>at
>e
>>>at
>e
>>>at
>b
>>>at
>>>at
>a
>>>:236)
>>>at
>n
>>>at
>c
>>>at
>w
>>>Page.java:724)
>Could
>Editor
>>>Thanks,
>>>Rashmy
<html>
<head>
</head>
Rashmy,<br>
<br>
The trace still looks truncated to me.&nbsp; I still can't tell what is the
ultimate cause here is.&nbsp; Can you try clearing your .log and ensuring
problem?<br>
<br>
<br>
Rashmy wrote:
<blockquote cite="middgmf1s$9nv$1@news.eclipse.org" type="cite">
<pre wrap="">Ed,
actory.java:25)
Impl.java:107)
ava:215)
com.teamcenter.gside.model.bod.GSBodPackage.&lt;clinit&a mp;gt;(GSBodPackage.java:62)
com.teamcenter.gside.model.bod.presentation.GSBodModelWizard .&lt;init&gt;(GSBodMod
elWizard.java:108)
sorImpl.java:39)
:236)
Page.java:724)
e.java:145)
:1044)
e.java:128)
dNode.java:125)
..java:101)
tem.java:488)
tionItem.java:400)
<a class="moz-txt-link-freetext" href="java:226">java:226</a>)
..java:25)
Impl.java:107)
l.java:106)
com.teamcenter.gside.model.connection.GSConnectionPackage.&a mp;lt;clinit&gt;(GSConnect
ionPackage.java:60)
Rashmy
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:dgmdt4$801$1@news.eclipse.org">news:dgmdt4$801$1@news.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Rashmy,
Rashmy wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->when
</pre>
<pre wrap="">I test GSBod Editor in my runtime workbench, I get the following error..
</pre>
</blockquote>
<pre wrap=""> sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unsa feFieldAccessor
</pre>
</blockquote>
<pre wrap=""><!---->F
</pre>
<pre wrap="">actory.java:25)
</pre>
</blockquote>
<pre wrap=""> sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFac tory.java:122)
</pre>
<pre wrap="">at java.lang.reflect.Field.acquireFieldAccessor(Field.java:917)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(
</pre>
</blockquote>
<pre wrap=""><!---->R
</pre>
<pre wrap="">egistryReader.java:167)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistr
</pre>
</blockquote>
<pre wrap=""><!---->y
</pre>
<pre wrap="">Impl.java:107)
</pre>
</blockquote>
<pre wrap=""> com.teamcenter.gside.model.connection.impl.GSConnectionPacka geImpl.init(GSC
</pre>
</blockquote>
<pre wrap=""><!---->o
</pre>
<pre wrap="">nnectionPackageImpl.java:118)
</pre>
</blockquote>
<pre wrap=""> com.teamcenter.gside.model.bod.impl.GSBodPackageImpl.init(GS BodPackageImpl.
</pre>
</blockquote>
<pre wrap=""><!---->j
</pre>
<pre wrap="">ava:215)
</pre>
</blockquote>
<pre wrap=""> com.teamcenter.gside.model.bod.GSBodPackage.&lt;clinit&a mp;gt;(GSBodPackage.java:62)
</pre>
<pre wrap="">at
</pre>
</blockquote>
<pre wrap=""> com.teamcenter.gside.model.bod.presentation.GSBodModelWizard .&lt;init&gt;(GSBodMo
</pre>
</blockquote>
<pre wrap=""><!---->d
</pre>
<pre wrap="">elWizard.java:108)
</pre>
</blockquote>
<pre wrap=""> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAcce
</pre>
</blockquote>
<pre wrap=""><!---->s
</pre>
<pre wrap="">sorImpl.java:39)
</pre>
</blockquote>
<pre wrap=""> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstru
</pre>
</blockquote>
<pre wrap=""><!---->c
</pre>
<pre wrap="">torAccessorImpl.java:27)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExt
</pre>
</blockquote>
<pre wrap=""><!---->e
</pre>
<pre wrap="">nsion(ConfigurationElement.java:162)
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
<pre wrap="">nsion(ConfigurationElement.java:142)
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
<pre wrap="">nsion(ConfigurationElement.java:129)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecuta
</pre>
</blockquote>
<pre wrap=""><!---->b
</pre>
<pre wrap="">leExtension(ConfigurationElementHandle.java:48)
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:240)
</pre>
<pre wrap="">at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.jav
</pre>
</blockquote>
<pre wrap=""><!---->a
</pre>
<pre wrap="">:236)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExte
</pre>
</blockquote>
<pre wrap=""><!---->n
</pre>
<pre wrap="">sion(WorkbenchWizardElement.java:118)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(Workben
</pre>
</blockquote>
</pre>
<pre wrap="">hWizardElement.java:276)
</pre>
</blockquote>
<pre wrap=""> org.eclipse.ui.internal.dialogs.NewWizardNewPage$6.createWiz ard(NewWizardNe
</pre>
</blockquote>
</pre>
<pre wrap="">Page.java:724)
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->Could
</pre>
<pre wrap="">you please let me know what runtime references are required for GSBod
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->Editor
</pre>
<pre wrap="">to work in the runtime workbench.
Rashmy
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------000203020908020401020900--
Re: model reference at runtime. [message #395685 is a reply to message #395680] Mon, 19 September 2005 14:14 Go to previous message
Ed,
I created a shortcut solution. I decided to combine both GSConnection and
GSUtil into one project and then referenced it in GSBod and it works like a
charm now!
Rashmy
> Rashmy,
> Rashmy wrote:
> >Hi,
when
> > at
F
> >actory.java:25)
> > at
> > at
R
> > at
y
> >Impl.java:107)
> > at
o
> > at
j
> >ava:215)
> > at
> > at
d
> >elWizard.java:108)
> > at
s
> >sorImpl.java:39)
> > at
c
> > at
e
> > at
e
> > at
e
> > at
b
> > at
> > at
a
> >:236)
> > at
n
> > at
c
> > at
w
> >Page.java:724)
Could
Editor
> >Thanks,
> >Rashmy
Previous Topic:schemaLocation in <import>
Next Topic:headless-batch processing of: genmodel.reload and genmodel.generate
Current Time: Sun May 27 05:32:40 GMT 2018
Powered by FUDForum. Page generated in 0.01796 seconds
