Home » Modeling » EMF » Datagraph change summary
Datagraph change summary [message #394612] Fri, 29 July 2005 14:34 Go to next message
Nicolas Tanghe is currently offline Nicolas TangheFriend
I use EMF/SDO and I have a problem with the change summary.
I initialize a EMF Object with a list of others EMF object (containment =
true). After that initialization, I make a beginLogin on the datagraph.
Then I add a children in my list and I want see this modification.
if (datagraph.getChangeSummary().isLogging()) {
datagraph.getChangeSummary().endLogging();
EChangeSummary summary = (EChangeSummary) ((DataGraph)
datagraph).getChangeSummary();
for (Iterator iter = summary.getObjectChanges().entrySet().iterator();
iter.hasNext();) {
Map.Entry entry = (Map.Entry) iter.next();
DataObject element = (DataObject) entry.getKey();
List oldValues = summary.getOldValues(element);
for (Iterator iterator = oldValues.iterator(); iterator.hasNext();) {
ChangeSummary.Setting change = (ChangeSummary.Setting) iterator
.next();
Property p = change.getProperty();
System.out.println("\tProperty " + p.getName() + ": "
+ change.getValue() + " => " + element.get(p));
There, no problem, the change summary see the added children, it's good.
Example, I have : Property list : [object 1,object 2] -> [object 1,object
2, Object 3]
I do a new beginLogging on the datagraph for see the new changes on the
"new" datagraph and now I delete one element in the list.
I return in the method :
iter.hasNext();) {
.next();
But, in this case, my ChangeSummary.Setting change is null, it don't see
the "old" list of children and I don't see my modifications in the list...
Property list : [] -> [object 1,object 2]
Someone body have the same problem ??
Help me please...
Nicolas
Re: Datagraph change summary [message #394639 is a reply to message #394612] Tue, 02 August 2005 06:51 Go to previous messageGo to next message
I think that I find the origin of my problem. It's de method : public List
getOldValues(DataObject dataObject) in package
org.eclipse.emf.ecore.sdo.impl.EchangeSummaryImpl.
Before, in a older version of EMF-SDO, the code of this method were :
public List getOldValues(DataObject dataObject)
return (List)getObjectChanges().get(dataObject);
And with this code, I have no problem, my code works fine...
Now, in the latest version, the code of this method is :
List sdoSettings = (List)cachedSDOObjectChanges.get(dataObject);
if (sdoSettings != null)
return sdoSettings;
List settings = (List)getObjectChanges().get(dataObject);
// TODO it is possible that settings is null, should we create empty
list then?
// TODO declaring serialVersionUID?
for (int i = 0; i < settings.size(); i++)
FeatureChange change = (FeatureChange)settings.get(i);
EStructuralFeature feature = change.getFeature();
if (FeatureMapUtil.isFeatureMap(feature))
final List values = (List)change.getValue();
if (sdoSettings == null)
sdoSettings = new BasicEList(settings);
DelegatingFeatureMap featureMap = new
DelegatingFeatureMap(((InternalEObject)dataObject), feature)
protected final List theList = values;
protected List delegateList()
return theList;
// create new settings and replace the setting for mixed feature
sdoSettings.set(i,
SDOFactory.eINSTANCE.createEChangeSummarySetting(feature, new
BasicESequence(featureMap), change.isSet()));
// add all derived features
for (int k = 0; k < featureMap.size(); k++)
EStructuralFeature f = featureMap.getEStructuralFeature(k);
sdoSettings.add(SDOFactory.eINSTANCE.createEChangeSummarySet ting(f,
featureMap.get(f, false), true));
sdoSettings = (sdoSettings != null) ? sdoSettings : settings;
cachedSDOObjectChanges.put(dataObject, sdoSettings);
return sdoSettings;
I observe that there is a "cache" : cachedSDOObjectChanges (but I don't
good understand how it's works). The first time, sdoSettings is null and
the method use (List)getObjectChanges().get(dataObject) and thus It's
works fine. But in a second time, the cache is not empty and the method
use List sdoSettings = (List)cachedSDOObjectChanges.get(dataObject) and
there, it's not good for me...
But It is a bug, a feature ? How use the new public List
getOldValues(DataObject dataObject) method ?
Someone can help me, please ?
Nicolas
Re: Datagraph change summary [message #394720 is a reply to message #394639] Tue, 02 August 2005 15:27 Go to previous messageGo to next message
Nicolas,
It's hard to know if there's a bug here or not. It certainly doesn't
sound so good. Could you provide a complete test case (one that I can
run myself locally) that illustrates the problem?
Nicolas wrote:
> Hello,
> List getOldValues(DataObject dataObject) in package
> return sdoSettings;
> empty list then? // TODO declaring serialVersionUID?
> return theList;
> sdoSettings.set(i,
> return sdoSettings;
> don't good understand how it's works). The first time, sdoSettings is
> null and the method use (List)getObjectChanges().get(dataObject) and
> thus It's works fine. But in a second time, the cache is not empty and
> the method use List sdoSettings =
> (List)cachedSDOObjectChanges.get(dataObject) and there, it's not good
> for me...
> Nicolas
Re: Datagraph change summary [message #394771 is a reply to message #394720] Wed, 03 August 2005 13:45 Go to previous messageGo to next message
Hello Ed,
I give you a complete class that illustrates my problem with an another
example... This class works locally, you can simply make a cut and paste.
Initially, I have a employee (Boss) wich have two employees (A and B).
I begin the logging and I add a employee C and I remove the employee A.
My datagraph is :
<sdo:datagraph xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:company="http://com.example.company.ecore"
xmlns:sdo="commonj.sdo"
xmlns:sdo_1="http://www.eclipse.org/emf/2003/SDO">
<changeSummary xmlns="">
<objectChanges key="#//@eRootObject">
<value xsi:type="sdo_1:EChangeSummarySetting"
featureName="employees">
<listChanges index="0"
referenceValues="#//@eChangeSummary/@objectsToAttach.0"/>
<listChanges kind="REMOVE" index="2"/>
</value>
</objectChanges>
<objectsToAttach xsi:type="company:Employee" name="A"/>
</changeSummary>
<company:Employee name="Boss">
<employees name="B"/>
<employees name="C"/>
</company:Employee>
</sdo:datagraph>
TO UPDATE:
Property employees:
Old value
New value
Ok, It's works fine !! Now, I begin the logging and I remove the employee C
My datagraph is :
<listChanges index="1"
</value>
</objectChanges>
<objectsToAttach xsi:type="company:Employee" name="C"/>
</changeSummary>
</company:Employee>
</sdo:datagraph>
TO UPDATE:
Property employees:
Old value
New value
And there, it's not good, my old value is A B and this must be B C ! (but
the change summary seem good ).
If I change the call to summary.getOldValues(element) by
summary.getObjectChanges().get(element) (wich is the body of the method
getOldValues in a older version of EMF, in the latest version this
function use also a cache), it's works fine, my Old value is B C...
Bug ?
Nicolas
public class TestGetOldValues {
protected EClass employeeClass;
protected EAttribute employeeNameFeature;
protected EReference employeeEmployeesFeature;
public TestGetOldValues() {
initializeEmployeeDataGraphModel();
protected void initializeEmployeeDataGraphModel() {
EcoreFactory ecoreFactory = EcoreFactory.eINSTANCE;
EcorePackage ecorePackage = EcorePackage.eINSTANCE;
employeeClass = ecoreFactory.createEClass();
employeeClass.setName("Employee");
// name
employeeNameFeature = ecoreFactory.createEAttribute();
employeeNameFeature.setName("name");
employeeNameFeature.setEType(ecorePackage.getEString());
employeeClass.getEStructuralFeatures().add(employeeNameFeatu re);
// employees (that the employee manages)
employeeEmployeesFeature = ecoreFactory.createEReference();
employeeEmployeesFeature.setName("employees");
employeeEmployeesFeature.setEType(employeeClass);
.setUpperBound(EStructuralFeature.UNBOUNDED_MULTIPLICITY);
employeeEmployeesFeature.setContainment(true); // must be true so that
// nested employees will
// be in the graph
employeeClass.getEStructuralFeatures().add(employeeEmployees Feature);
EPackage employeePackage = ecoreFactory.createEPackage();
employeePackage.setName("company");
employeePackage.setNsPrefix("company");
employeePackage.setNsURI("http://com.example.company.ecore");
employeePackage.getEClassifiers().add(employeeClass);
// Have the factory for this package build SDO Objects
employeePackage
.setEFactoryInstance(new DynamicEDataObjectImpl.FactoryImpl());
public EObject createDataObject(String name) {
EObject eObject = EcoreUtil.create(employeeClass);
// Note: we could cast the object to DataObject, but chose to use
// EObject APIs instead.
eObject.eSet(employeeNameFeature, name);
return eObject;
// Give a dataGraph with a Employee (Boss) wich have two employees (A and
B)
// and begin the logging
public DataGraph getInitDataGraph() {
EDataGraph employeeGraph = SDOFactory.eINSTANCE.createEDataGraph();
EObject rootObject = null;
EObject boss = createDataObject("Boss");
EObject A = createDataObject("A");
((List) boss.eGet(employeeEmployeesFeature)).add(A);
EObject B = createDataObject("B");
((List) boss.eGet(employeeEmployeesFeature)).add(B);
rootObject = boss;
if (rootObject != null) {
employeeGraph.setERootObject(rootObject);
// Call beginLogging() so that the Change Summary is populated when
// changes are made to the Data Graph.
// The DMS should call beginLogging() and endLogging(), not the client.
employeeGraph.getChangeSummary().beginLogging();
return employeeGraph;
public DataGraph saveUpdate(DataGraph datagraph) throws Exception {
EChangeSummary summary = (EChangeSummary) ((DataGraph) datagraph)
if (summary.isLogging()) {
summary.endLogging();
System.out.println("\nTO UPDATE:");
iter
.hasNext();) {
if (summary.isCreated(element)) {
System.out.println("created: " + element);
System.out.println("\n");
} else if (summary.isDeleted(element)) {
System.out.println("deleted: " + element);
} else {
//List oldValues = (List) summary.getObjectChanges().get(element);
.hasNext();) {
.next();
// We wath the list of employee
if (p.getName().equals("employees")) {
System.out.println("\tProperty " + p.getName() + ": ");
// System.out.println(change.getValue());
System.out.println("Old value ");
for (Iterator iterator2 = ((List) change.getValue())
.iterator(); iterator2.hasNext();) {
DataObject empl = (DataObject) iterator2.next();
System.out.println("Name: "
+ empl.getString("name"));
System.out.println(" => ");
System.out.println("New value ");
for (Iterator iterator3 = ((List) element.get(p))
.iterator(); iterator3.hasNext();) {
DataObject empl = (DataObject) iterator3.next();
return datagraph;
public void testChanges() {
DataGraph graph = getInitDataGraph();
EObject boss = (EObject) graph.getRootObject();
// add a employee C and remove employee A
EObject C = createDataObject("C");
((List) boss.eGet(employeeEmployeesFeature)).add(C);
((List) boss.eGet(employeeEmployeesFeature)).remove(0);
try {
((EDataGraph) graph).getDataGraphResource().save(System.out, null);
} catch (IOException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
try {
saveUpdate(graph);
} catch (Exception e) {
e.printStackTrace();
// I make a new beginLogging
graph.getChangeSummary().beginLogging();
//I remove employee C
((List) boss.eGet(employeeEmployeesFeature)).remove(1);
try {
try {
saveUpdate(graph);
TestGetOldValues test = new TestGetOldValues();
test.testChanges();
Re: Datagraph change summary [message #394790 is a reply to message #394771] Wed, 03 August 2005 18:04 Go to previous messageGo to next message
Nicolas,
Marcelo will look into the problem. Thanks for the test case!
Nicolas Tanghe wrote:
> Hello Ed,
> another example... This class works locally, you can simply make a cut
> and paste.
> My datagraph is :
> </value>
> </objectChanges>
> </changeSummary>
> </company:Employee>
> </sdo:datagraph>
> TO UPDATE:
> Property employees: Old value Name: A
> => New value Name: B
> employee C
> My datagraph is :
> </value>
> </objectChanges>
> </changeSummary>
> </company:Employee>
> </sdo:datagraph>
> TO UPDATE:
> (but the change summary seem good ).
> method getOldValues in a older version of EMF, in the latest version
> this function use also a cache), it's works fine, my Old value is B C...
> Bug ?
> Nicolas
> // name
> so that
> // be in the graph
> employeePackage
> return eObject;
> (A and B)
> rootObject = boss;
> when
> the client.
> summary.getObjectChanges().entrySet().iterator(); iter
> .hasNext();) {
> } else {
> .hasNext();) {
> .next();
> change.getValue())
> iterator2.next();
> iterator3.next();
> return datagraph;
> try {
> ((EDataGraph)
> try {
> saveUpdate(graph);
> try {
> ((EDataGraph)
> try {
> saveUpdate(graph);
> public static void main(String[] args) {
> test.testChanges();
Re: Datagraph change summary [message #394809 is a reply to message #394790] Thu, 04 August 2005 05:41 Go to previous messageGo to next message
Marcelo Paternostro is currently offline Marcelo PaternostroFriend
Hi Nicolas,
I believe this is a bug. The cachedSDOObjectChanges should probably be
cleared when you begin recording and when the changes are consolidated.
Can you please open a bugzilla?
Marcelo
Ed Merks wrote:
> Nicolas,
>> Hello Ed,
>> and paste.
>> My datagraph is :
>> <?xml version="1.0" encoding="UTF-8"?>
>> </value>
>> </objectChanges>
>> </changeSummary>
>> </company:Employee>
>> </sdo:datagraph>
>> TO UPDATE:
>> employee C
>> My datagraph is :
>> </value>
>> </objectChanges>
>> </changeSummary>
>> </company:Employee>
>> </sdo:datagraph>
>> TO UPDATE:
>> Bug ?
>> Thanks,
>> Nicolas
>> // name
>> so that
>> // be in the graph
>> employeePackage
>> return eObject;
>> (A and B)
>> rootObject = boss;
>> when
>> the client.
>> .hasNext();) {
>> } else {
>> .hasNext();) {
>> .next();
>> change.getValue())
>> iterator2.next();
>> value ");
>> iterator3.next();
>> return datagraph;
>> try {
>> ((EDataGraph)
>> try {
>> saveUpdate(graph);
>> try {
>> ((EDataGraph)
>> try {
>> saveUpdate(graph);
>> test.testChanges();
Re: Datagraph change summary [message #394829 is a reply to message #394809] Thu, 04 August 2005 14:23 Go to previous message
Hi Marcelo,
A bugzilla is open...
Nicolas
Previous Topic:Generate the error code from EMF project
Next Topic:Validator
Current Time: Sat May 26 02:14:16 GMT 2018
Powered by FUDForum. Page generated in 0.02023 seconds
