Home » Modeling » EMF » java.lang.ExceptionInInitializerError problem
java.lang.ExceptionInInitializerError problem [message #391238] Fri, 18 February 2005 13:20 Go to next message
Gabriela Mising name is currently offline Gabriela Mising nameFriend
Hi all,
I am migrating to eclipse 3 and I have the following exception when it
is trying to instanciate the model
Unhandled event loop exception
Reason:
The exception is raised when it is trying to execute this line
CommonRootModel commonRootModel = modelFty.createCommonRootModel();
the method createCommonRootModel is EMF generated
public CommonRootModel createCommonRootModel() {
CommonRootModelImpl commonRootModel = new CommonRootModelImpl();
return commonRootModel;
To do this, the program should initialize the static fields. In
CommonRootModelImpl there is a static field PROPERTIES_EDEFAULT, EMF
generated.
protected static final Hashtable PROPERTIES_EDEFAULT =
(Hashtable)DatatypeFactory.eINSTANCE.createFromString(Dataty pePackage.eINSTANCE.getJavaHashtable(),
"new java.util.Hashtable()");
This field is never initialized, and here the exception is raised.
I will appreciate any idea to find the problem... :)
Gaby
Re: java.lang.ExceptionInInitializerError problem [message #391240 is a reply to message #391238] Fri, 18 February 2005 13:43 Go to previous message
--------------010104080508020801030409
Gaby,
It sounds like your model (Rose?) has something like this in it:
JavaHashTable x = new java.util.Hashtable()
This is not supported. The thing after the "=" has to be the
convertToString version of an empty hashtable. I.e., I would expect
something like this in your model:
JavaHashTable x = ""
And I would expect that your JavaHashtable's createFromString method
would create an empty hash map given an empty string.
Note that having a mutable default value sounds potentially kind of bad...
Gaby Perez wrote:
> Hi all, I am migrating to eclipse 3 and I have the following
> exception when it is trying to instanciate the model
> Reason:
> generated.
> Gaby
<html>
<head>
http-equiv="Content-Type">
</head>
Gaby,<br>
<br>
It sounds like your model (Rose?) has something like this in it:<br>
<blockquote>JavaHashTable x = new java.util.Hashtable()<br>
</blockquote>
Previous Topic:Using equals() instead of "==" in Resource
Next Topic:[Newbie] Need advises to clarify my mind
Current Time: Fri Apr 20 11:03:34 GMT 2018
Powered by FUDForum. Page generated in 0.02014 seconds
