Home » Modeling » EMF » How do I include an XML schema in an EMF model?
How do I include an XML schema in an EMF model? [message #391028] Wed, 09 February 2005 20:48 Go to next message
Originally posted by: john.sipher.ssaglobal.com
I want to wrap an XML schema inside an XML document that will be represented
by an EMF model, and I'd like to have the schema part of the document
processed by XSD when I load the parent document into my model.
For example, assume I have a schema that looks like this:
<xs:schema targetNamespace="http://mydomain/test"
xmlns="http://mydomain/test"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
<xs:complexType name="RootElement">
<xs:sequence>
<xs:element name="properties" type="ConfigProperty" minOccurs="0"
maxOccurs="unbounded"/>
<xs:any namespace="http://www.w3.org/2001/XMLSchema"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="ConfigProperty">
<xs:sequence>
<xs:element name="name" type="xs:string"/>
<xs:element name="value" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
If I use that schema to generate an EMF model, I think the generated model
ought to be able to process a document that looks like this:
<test:RootElement xmlns:test="http://mydomain/test">
<properties>
<name>name1</name>
<value>value1</value>
</properties>
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
</test:RootElement>
In other words, the <xs:schema> element ought to be legal content for the
<xs:any> element in my schema. However, when I try to load the document it
complains about Feature 'schema' not found. (model/test.test, 10, -1).
The code that tries to load the document looks like this:
XSDPackageImpl.init();
TestPackageImpl.init();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",new
TestResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResource(URI.createDeviceURI(schemaURL),true) ;
Any suggestions?
John Sipher
Re: How do I include an XML schema in an EMF model? [message #391031 is a reply to message #391028] Wed, 09 February 2005 21:01 Go to previous messageGo to next message
John,
This is much easier said than done. A schema model instance must be
constructed from a DOM, so you need to create a DOM when parsing and
then use that to create the XSDSchema. Similarly, when serializing, you
need to get the DOM from the XSDSchema and serialize that. The folks
doing a WSDL model need to solve this problem, but that's been done by
making the WSDL model work much like the XSD model. Probably is you
look at how XSDResourceImpl implements doSave and doLoad, it will be
more clear how it works (and that you have a hard problem to solve.).
><?xml version="1.0" encoding="UTF-8"?>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
></xs:schema>
> <properties>
> <name>name1</name>
> </properties>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
></test:RootElement>
>Any suggestions?
>Thanks,
>John Sipher
Re: How do I include an XML schema in an EMF model? [message #391049 is a reply to message #391031] Thu, 10 February 2005 15:42 Go to previous messageGo to next message
Ed,
Thanks for the quick response. For my purposes the solution is relatively
easy now that I know I'm not missing something easy in the original
approach. I did run across something that didn't work as I thought it
should from reading the XSD FAQ.
I think I should be able to do this to get empty resources that I can load.
// initalize packages
XSDPackage.eINSTANCE.getEFactoryInstance();
TestPackage.eINSTANCE.getEFactoryInstance();
// set up resource registry
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*.test",n
ew TestResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*.xsd",ne
w XSDResourceFactoryImpl());
// get "empty" resources
TestResourceImpl testResource =
(TestResourceImpl)resourceSet.createResource(URI.createURI("*.test "));
XSDResourceImpl xsdResource =
(XSDResourceImpl)resourceSet.createResource(URI.createURI("*.xsd "));
In both cases resourceSet.createResource() returns null, and I'm not sure
why. I traced into it and it looks as if the resource factory registry
hasn't been initialized yet.
John
The "solution" to the original problem follows. Please let me know if
anyone sees problems with it (exception handling obviously needs to be
added).
String modelURL = args[0];
DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
factory.setNamespaceAware(true);
DocumentBuilder builder = factory.newDocumentBuilder();
Document document = builder.parse(new FileInputStream(modelURL));
ByteArrayOutputStream baos = new ByteArrayOutputStream();
Transformer transformer =
TransformerFactory.newInstance().newTransformer();
// TestResourceImpl testResource =
// XSDResourceImpl xsdResource =
TestResourceImpl testResource = new
TestResourceImpl(URI.createURI("*.test"));
XSDResourceImpl xsdResource = new
XSDResourceImpl(URI.createURI("*.xsd"));
resourceSet.getResources().add(testResource);
resourceSet.getResources().add(xsdResource);
// get the embedded schema, load it into an XSDSchema instance, and add
it to the xsd resource
Element schemaElement =
(Element)document.getDocumentElement().getElementsByTagNameN S( "http://www.w3
..org/2001/XMLSchema","schema").item(0);
DOMResult domResult = new DOMResult(builder.newDocument());
transformer.transform(new DOMSource(schemaElement),domResult);
XSDSchema schema = XSDFactory.eINSTANCE.createXSDSchema();
schema.setElement(((Document)domResult.getNode()).getDocumen tElement());
xsdResource.getContents().add(schema);
// remove the schema from the original document and load the remainder
into the test resource.
document.getDocumentElement().removeChild(schemaElement);
transformer.transform(new DOMSource(document),new StreamResult(baos));
testResource.load(new
ByteArrayInputStream(baos.toByteArray()),resourceSet.getLoad Options());
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cudtig$22c$1@www.eclipse.org...
> John,
represented
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> ></xs:schema>
model
> > <properties>
> > <name>name1</name>
> > </properties>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> ></test:RootElement>
it
> >Any suggestions?
> >Thanks,
> >John Sipher
Re: How do I include an XML schema in an EMF model? [message #391050 is a reply to message #391049] Thu, 10 February 2005 17:39 Go to previous messageGo to next message
--------------060302030506000303070109
John,
You should register "test" and "xsd", not "*.test" and "*.xsd". Note also that if the schema contains schemaLocation="..." where the ... is a relative path, it's important that the URI of the containing resource be an absolute path so that relative location can be interpreted properly. In that case "*.xsd" would not be so good and you might want to take the name of the actual location of the bigger file (modelURL) and append .xsd to it to create your "fake" XSD URI.
I also made a comment line below about the add of the resource being unnecessary since the createResource will already have added it...
John Sipher wrote:
>Ed,
>(TestResourceImpl)resourceSet.createResource(URI.createURI( "*.test"));
>John
>added).
The created resource is already added, so this is a no-op.
>>John,
>represented
>>> <xs:sequence>
>>> </xs:sequence>
>>></xs:complexType>
>>> <xs:sequence>
>>> </xs:sequence>
>>></xs:complexType>
>>></xs:schema>
>model
>>> <properties>
>>> <name>name1</name>
>>> </properties>
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </xs:schema>
>>></test:RootElement>
>it
>>>Any suggestions?
>>>Thanks,
>>>John Sipher
<html>
<head>
</head>
John,<br>
<pre wrap="">You should register "test" and "xsd", not "*.test" and "*.xsd". Note also that if the schema contains schemaLocation="..." where the ... is a relative path, it's important that the URI of the containing resource be an absolute path so that relative location can be interpreted properly. In that case "*.xsd" would not be so good and you might want to take the name of the actual location of the bigger file (modelURL) and append .xsd to it to create your "fake" XSD URI.
</pre>
<br>
John Sipher wrote:
<blockquote cite="midcug16k$snl$1@www.eclipse.org" type="cite">
<pre wrap="">Ed,
John
added).
</pre>
</blockquote>
The created resource is already added, so this is a no-op.<br>
<pre wrap="">
(Element)document.getDocumentElement().getElementsByTagNameN S( <a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3
..org/2001/XMLSchema"</a>,"schema").item(0);
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cudtig$22c$1@www.eclipse.org">news:cudtig$22c$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">John,
John Sipher wrote:
</pre>
<pre wrap="">I want to wrap an XML schema inside an XML document that will be
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->represented
</pre>
<pre wrap="">by an EMF model, and I'd like to have the schema part of the document
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
&lt;xs:schema targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://mydomain/test">"http://mydomain/test"</a>
xmlns=<a class="moz-txt-link-rfc2396E" href="http://mydomain/test">"http://mydomain/test"</a>
xmlns:xs=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
elementFormDefault="unqualified" attributeFormDefault="unqualified"&gt;
&lt;xs:complexType name="RootElement"&gt;
&lt;xs:sequence&gt;
&lt;xs:element name="properties" type="ConfigProperty" minOccurs="0"
maxOccurs="unbounded"/&gt;
&lt;xs:any namespace=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>/&gt;
&lt;/xs:sequence&gt;
&lt;/xs:complexType&gt;
&lt;xs:complexType name="ConfigProperty"&gt;
&lt;xs:sequence&gt;
&lt;xs:element name="name" type="xs:string"/&gt;
&lt;xs:element name="value" type="xs:string"/&gt;
&lt;/xs:schema&gt;
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->model
</pre>
<pre wrap="">ought to be able to process a document that looks like this:
&lt;test:RootElement xmlns:test=<a class="moz-txt-link-rfc2396E" href="http://mydomain/test">"http://mydomain/test"</a>&gt;
&lt;properties&gt;
&lt;name&gt;name1&lt;/name&gt;
&lt;value&gt;value1&lt;/value&gt;
&lt;/properties&gt;
&lt;xs:sequence&gt;
&lt;xs:sequence&gt;
&lt;/xs:schema&gt;
&lt;/test:RootElement&gt;
In other words, the &lt;xs:schema&gt; element ought to be legal content for the
&lt;xs:any&gt; element in my schema. However, when I try to load the document
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->it
</pre>
<pre wrap="">complains about Feature 'schema' not found. (model/test.test, 10, -1).
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",new
</pre>
<pre wrap="">TestResourceFactoryImpl());
Any suggestions?
John Sipher
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060302030506000303070109--
Re: How do I include an XML schema in an EMF model? [message #391065 is a reply to message #391050] Fri, 11 February 2005 16:04 Go to previous messageGo to next message
------=_NextPart_000_0009_01C51029.6B40A770
charset="iso-8859-1"
Thanks Ed. Now another problem. =20
This works as long as the schema embedded in my model document is =
entirely self contained, but it breaks when the schema has <xs:import> =
elements. I assume the problem is that XSDResourceImpl() can't resolve =
relative schema locations when it's loading from a ByteArrayInputStream. =
Is there an easy way around that (maybe something I can set in the load =
options)?
John
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:cug6ae$lrb$1@www.eclipse.org...
John,
You should register "test" and "xsd", not "*.test" and "*.xsd". Note =
also that if the schema contains schemaLocation=3D"..." where the ... is =
a relative path, it's important that the URI of the containing resource =
be an absolute path so that relative location can be interpreted =
properly. In that case "*.xsd" would not be so good and you might want =
to take the name of the actual location of the bigger file (modelURL) =
I also made a comment line below about the add of the resource being =
John Sipher wrote:=20
Ed,
Thanks for the quick response. For my purposes the solution is =
relatively
I think I should be able to do this to get empty resources that I can =
load.
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*.test=
",n
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*.xsd"=
,ne
ResourceSet resourceSet =3D new ResourceSetImpl();
TestResourceImpl testResource =3D
XSDResourceImpl xsdResource =3D
In both cases resourceSet.createResource() returns null, and I'm not =
sure
John
added).
String modelURL =3D args[0];
DocumentBuilderFactory factory =3D =
DocumentBuilder builder =3D factory.newDocumentBuilder();
Document document =3D builder.parse(new FileInputStream(modelURL));
ByteArrayOutputStream baos =3D new ByteArrayOutputStream();
Transformer transformer =3D
",n
,ne
// TestResourceImpl testResource =3D
// XSDResourceImpl xsdResource =3D
TestResourceImpl testResource =3D new
XSDResourceImpl xsdResource =3D new
// get the embedded schema, load it into an XSDSchema instance, and =
add
Element schemaElement =3D
(Element)document.getDocumentElement().getElementsByTagNameN S( "http://www=
..w3
DOMResult domResult =3D new DOMResult(builder.newDocument());
XSDSchema schema =3D XSDFactory.eINSTANCE.createXSDSchema();
// remove the schema from the original document and load the =
remainder
transformer.transform(new DOMSource(document),new =
John,
represented
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<xs:schema targetNamespace=3D"http://mydomain/test"
xmlns=3D"http://mydomain/test"
xmlns:xs=3D"http://www.w3.org/2001/XMLSchema"
elementFormDefault=3D"unqualified" attributeFormDefault=3D"unqualified">
<xs:complexType name=3D"RootElement">
<xs:sequence>
<xs:element name=3D"properties" type=3D"ConfigProperty" =
minOccurs=3D"0"
maxOccurs=3D"unbounded"/>
<xs:any namespace=3D"http://www.w3.org/2001/XMLSchema"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name=3D"ConfigProperty">
<xs:sequence>
<xs:element name=3D"name" type=3D"xs:string"/>
<xs:element name=3D"value" type=3D"xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
model
<test:RootElement xmlns:test=3D"http://mydomain/test">
<properties>
<name>name1</name>
</properties>
<xs:sequence>
minOccurs=3D"0"
</xs:sequence>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
</test:RootElement>
In other words, the <xs:schema> element ought to be legal content for =
the
it
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",new=
Any suggestions?
John Sipher
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1491" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks Ed.&nbsp; Now another =
problem.&nbsp;=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>This works as long as the schema =
embedded in my=20
model document is entirely self contained, but it breaks when the schema =
has=20
&lt;xs:import&gt; elements.&nbsp; I assume the problem is that =
XSDResourceImpl()=20
can't resolve relative schema locations when it's loading from a=20
ByteArrayInputStream.&nbsp; Is there an easy way around that (maybe =
something I=20
can set in the load options)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>John</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:cug6ae$lrb$1@www.eclipse.org">news:cug6ae$lrb$1@www.eclipse.=
org</A>...</DIV>John,<BR><PRE wrap=3D"">You should register "test" and =
"xsd", not "*.test" and "*.xsd". Note also that if the schema contains =
schemaLocation=3D"..." where the ... is a relative path, it's important =
that the URI of the containing resource be an absolute path so that =
relative location can be interpreted properly. In that case "*.xsd" =
would not be so good and you might want to take the name of the actual =
location of the bigger file (modelURL) and append .xsd to it to create =
</PRE><BR>John Sipher wrote:=20
<BLOCKQUOTE cite=3Dmidcug16k$snl$1@www.eclipse.org type=3D"cite"><PRE =
wrap=3D"">Ed,
relatively
load.
",n
,ne
sure
John
added).
",n
,ne
</PRE></BLOCKQUOTE>The created resource is already added, so this is a =
no-op.<BR>
wrap=3D""> // get the embedded schema, load it into an XSDSchema =
instance, and add
(Element)document.getDocumentElement().getElementsByTagNameN S( <A =
class=3Dmoz-txt-link-rfc2396E =
href=3D"http://www.w3.org/2001/XMLSchema">"http://www.w3
..org/2001/XMLSchema"</A>,"schema").item(0);
remainder
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</A> wrote in =
message
<A class=3Dmoz-txt-link-freetext =
href=3D"news:cudtig$22c$1@www.eclipse.org">news:cudtig$22c$1@www.eclipse.=
org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">John,
John Sipher wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I want to wrap an XML =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->represented
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">by an EMF model, and I'd =
&lt;?xml version=3D"1.0" encoding=3D"UTF-8"?&gt;
&lt;xs:schema targetNamespace=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"http://mydomain/test">"http://mydomain/test"</A>
xmlns=3D<A class=3Dmoz-txt-link-rfc2396E =
xmlns:xs=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSche=
ma"</A>
elementFormDefault=3D"unqualified" =
attributeFormDefault=3D"unqualified"&gt;
&lt;xs:complexType name=3D"RootElement"&gt;
&lt;xs:sequence&gt;
&lt;xs:element name=3D"properties" type=3D"ConfigProperty" =
minOccurs=3D"0"
maxOccurs=3D"unbounded"/&gt;
&lt;xs:any namespace=3D<A class=3Dmoz-txt-link-rfc2396E =
ma"</A>/&gt;
&lt;xs:complexType name=3D"ConfigProperty"&gt;
&lt;xs:sequence&gt;
&lt;xs:element name=3D"name" type=3D"xs:string"/&gt;
&lt;xs:element name=3D"value" type=3D"xs:string"/&gt;
&lt;/xs:schema&gt;
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->model
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">ought to be able to =
&lt;test:RootElement xmlns:test=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"http://mydomain/test">"http://mydomain/test"</A>&gt;
&lt;properties&gt;
&lt;/properties&gt;
ma"</A>
&lt;xs:sequence&gt;
minOccurs=3D"0"
ma"</A>/&gt;
&lt;xs:sequence&gt;
&lt;/xs:schema&gt;
In other words, the &lt;xs:schema&gt; element ought to be legal content =
for the
&lt;xs:any&gt; element in my schema. However, when I try to load the =
document
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->it
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">complains about Feature =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE =
wrap=3D""><!---->Resource.Factory.Registry.INSTANCE.getExtensionToFactory=
Map().put("*",new
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE =
wrap=3D"">TestResourceFactoryImpl());
Any suggestions?
John Sipher
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0009_01C51029.6B40A770--
Re: How do I include an XML schema in an EMF model? [message #391071 is a reply to message #391065] Fri, 11 February 2005 16:35 Go to previous message
--------------010501030403060100060501
John,
I was anticipating this problem which is why I added my comment about
making sure that the URI of the XSDResourceImpl is the correct absolute
URI against which relative locations should be resolved. Are you using
modelURL + ".xsd" as the URI now? The URI needs to be absolute, i.e,.
http://..., file:/, platform:/, and so on...
> ByteArrayInputStream. Is there an easy way around that (maybe
> something I can set in the load options)?
> John
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:cug6ae$lrb$1@www.eclipse.org...
> John,
> John Sipher wrote:
>>Ed,
>>(XSDResourceImpl)resourceSet.createResource(URI.createURI( "*.xsd"));
>>John
>>added).
>>>John,
>>represented
>>>> <xs:sequence>
>>>> </xs:sequence>
>>>></xs:complexType>
>>>> <xs:sequence>
>>>> </xs:sequence>
>>>></xs:complexType>
>>>></xs:schema>
>>model
>>>> <properties>
>>>> <name>name1</name>
>>>> </properties>
>>>> <xs:sequence>
>>>> </xs:sequence>
>>>> </xs:complexType>
>>>> <xs:sequence>
>>>> </xs:sequence>
>>>> </xs:complexType>
>>>> </xs:schema>
>>>></test:RootElement>
>>it
>>>>Any suggestions?
>>>>Thanks,
>>>>John Sipher
<html>
<head>
</head>
John,<br>
<br>
URI against which relative locations should be resolved.&nbsp; Are you using
modelURL&nbsp; + ".xsd" as the URI now?&nbsp; The URI needs to be absolute, i.e,.
<a class="moz-txt-link-freetext" href="http://">http://</a>..., <a class="moz-txt-link-freetext" href="file:/">file:/</a>, platform:/, and so on...<br>
<br>
<br>
John Sipher wrote:
<blockquote cite="midcuil1r$2rd$1@www.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2800.1491" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Thanks Ed.&nbsp; Now another problem.&nbsp; </font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">This works as long as the schema
embedded in my model document is entirely self contained, but it breaks
when the schema has &lt;xs:import&gt; elements.&nbsp; I assume the problem
is that XSDResourceImpl() can't resolve relative schema locations when
it's loading from a ByteArrayInputStream.&nbsp; Is there an easy way around
that (maybe something I can set in the load options)?</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div><font face="Arial" size="2">John</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt;
wrote in message <a href="news:cug6ae$lrb$1@www.eclipse.org">news:cug6ae$lrb$1@www.eclipse.org</a>...</div>
John,<br>
</pre>
<br>
<pre wrap="">Ed,
John
added).
</pre>
</blockquote>
<pre wrap=""> // get the embedded schema, load it into an XSDSchema instance, and add
</pre>
<pre wrap="">John,
John Sipher wrote:
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
&lt;xs:sequence&gt;
&lt;xs:sequence&gt;
&lt;/xs:schema&gt;
</pre>
</blockquote>
</blockquote>
</pre>
&lt;properties&gt;
&lt;/properties&gt;
&lt;xs:sequence&gt;
&lt;xs:sequence&gt;
&lt;/xs:schema&gt;
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
Any suggestions?
John Sipher
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010501030403060100060501--
Previous Topic:Dynamic model transformation
Next Topic:Code generation pbm: missing class
Current Time: Tue Feb 20 16:02:38 GMT 2018
Powered by FUDForum. Page generated in 0.22420 seconds
