Home » Modeling » EMF » generating RCP application
generating RCP application [message #388615] Thu, 14 October 2004 18:35 Go to next message
anupama is currently offline anupamaFriend
Member
I read the tutorial EMF goes RCP and tried.it out.
I have EMF 2.0 version with eclipse 3.0 and I could set the option
rcp=true in the genmodel file properties but the code generated did not
reflect the changes mentioned in the tutorial. (Changes in the plgin.xml
in editor package)
Here is the plugin.xml from library.editor pacahage
* <copyright>
* </copyright>
* $Id$
<plugin
name = "%pluginName"
id = "library rcp.editor"
version = "1.0.0"
provider-name = "%providerName"
class =
" com.example.library.presentation.LibraryEditorPlugin$Impleme ntation ">
<requires>
<import plugin="org.eclipse.core.runtime" />
<import plugin="library rcp.edit" export="true"/>
<import plugin="org.eclipse.emf.ecore.xmi" export="true"/>
<import plugin="org.eclipse.emf.edit.ui" export="true"/>
</requires>
<runtime>
<library name="runtime/">
<export name="*"/>
</library>
</runtime>
<extension point = "org.eclipse.ui.editors">
<editor
id = "com.example.library.presentation.LibraryEditorID"
name = "%_UI_LibraryEditor_label"
icon = "icons/full/obj16/LibraryModelFile.gif"
extensions = "library"
class = "com.example.library.presentation.LibraryEditor"
contributorClass=" com.example.library.presentation.LibraryActionBarContributor "
</editor>
</extension>
</plugin>
I am using following build for EMF
Eclipse Modeling Framework (EMF)
Version: 2.0.0
Build id: 200405200923
Am i not doing smething correctly or do I need a diffrent build?
-ANupama
Re: generating RCP application [message #388617 is a reply to message #388615] Thu, 14 October 2004 18:45 Go to previous messageGo to next message
--------------010309070802040500060801
Anupama,
Unfortunately we are not able to regenerate the plugin.xml, so once it
exists, it won't ever be modified by the generator. Deleting it will
allow you to regenerate it from scratch.
anupama wrote:
>Hi,
>in editor package)
> * <copyright>
> * </copyright>
> * $Id$
><plugin
> version = "1.0.0"
> class =
> <requires>
> </requires>
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <editor
> </editor>
> </extension>
></plugin>
>Version: 2.0.0
>Thanks
>-ANupama
<html>
<head>
http-equiv="Content-Type">
</head>
Anupama,<br>
<br>
Re: generating RCP application [message #388623 is a reply to message #388617] Thu, 14 October 2004 23:34 Go to previous messageGo to next message
Member
I dont think I understood u correctly. Do you mean that if the generated
EMF project and its plugins already exists, you can regenarate the
plugin.xml in that project again. Am I getting it correctly or you are
talking in terms of the fulkl workspace?
I created a new EMF project from the library.xsd and when the genmodel
file was created then selected RCP=true and then did generate ALL.
WHat am I missing here?Or do I needa latest build of EMF than what I have.?
-Anupama
Ed Merks wrote:
> Anupama,
> anupama wrote:
> >Hi,
> >in editor package)
> > * <copyright>
> > * </copyright>
> > * $Id$
> ><plugin
> > version = "1.0.0"
> > class =
> > <requires>
> > </requires>
> > <runtime>
> > <export name="*"/>
> > </library>
> > </runtime>
> > <editor
> > </editor>
> > </extension>
> ></plugin>
> >Version: 2.0.0
> >Thanks
> >-ANupama
Re: generating RCP application [message #388626 is a reply to message #388623] Fri, 15 October 2004 11:13 Go to previous message
--------------030604090601080905050407
Anupama,
Since you talked about *changes *in the plugin.xml, I assumed you were
*re*generating it from a previous version and were expecting it to
change. Once the file plugin.xml exists, the generator will not change
it. (And I'm only talking about this one file, not about anything more
general.)
Trying with a new project as you say you have done, I see stuff like
this in the .editor's plugin.xml:
<extension
point="org.eclipse.core.runtime.applications"
id="LibraryEditorAdvisorApplication">
<application>
<run
class=" com.example.library.presentation.LibraryEditorAdvisor$Applic ation ">
</run>
</application>
</extension>
So I don't really know what you are doing wrong. Perhaps you haven't
deleted the old projects and aren't really creating fresh new projects.
Try removing the plugin.xml and generating again...
>Thanks
>-Anupama
>Ed Merks wrote:
>>Anupama,
>>anupama wrote:
>>>Hi,
>>>in editor package)
>>>* <copyright>
>>>* </copyright>
>>>* $Id$
>>><plugin
>>> version = "1.0.0"
>>> class =
>>> <requires>
>>> </requires>
>>> <runtime>
>>> <export name="*"/>
>>> </library>
>>> </runtime>
>>> <editor
>>> </editor>
>>> </extension>
>>></plugin>
>>>Version: 2.0.0
>>>Thanks
>>>-ANupama
<html>
<head>
</head>
Anupama,<br>
<br>
Since you talked about <b>changes </b>in the plugin.xml, I assumed
you were <b>re</b>generating it from a previous version and were
expecting it to change.
Previous Topic:[Newbie] Is EMF only for structured data model like tree-structure or table-structure?
Next Topic:Switching from Rose model definition to Java model definition
Current Time: Wed May 23 03:40:07 GMT 2018
Powered by FUDForum. Page generated in 0.02111 seconds
