Home » Modeling » EMF » Cross-Document References Loading/Saving.
Cross-Document References Loading/Saving. [message #387054] Mon, 16 August 2004 05:25 Go to next message
Originally posted by: scottwarren.myself.com
Here's a situation where I could use some advice:
I'm modeling a process flow and my original design of the EMF model had a
single top-level object that was the containment root for all objects in the
model. This worked fine. I could load/save without any problems. Now, I
have the requirement to make certain parts of the model "shareable". For
example, a user designs a sub-process that he/she wants to use across
multiple model instances. In an effort to accomplish this, I've changed
almost all references to non-containment references so that the component
parts can be written to separate files. Now, rather than one single file,
I've got quite a few (30+ in my unit test). So, it seems to save fine. I
load the "root" (top-level) document and load appears to work fine until I
go to save the model again. If I load the root document and immediately try
to save again (like a "Save As"), it appears that the other referenced
objects never get completely loaded. I find that if I write code that walks
the object tree after the load, everything gets demand loaded and the save
works correctly. Shouldn't the reference to each object by the EMF
serialization code cause the resources to be loaded?
If I'm going about this the wrong way, please let me know.
Scott
Re: Cross-Document References Loading/Saving. [message #387063 is a reply to message #387054] Mon, 16 August 2004 14:17 Go to previous messageGo to next message
Scott,
When a document with cross document references is read in, proxies are
created to refer to objects in other documents. Those proxies are
resolved on demand as you access them. But when the serializer accesses
the instance, it's careful to do so in a way that does not cause any
proxies to resolve. So what you are describing is what I would expect...
>Thanks,
>Scott
Re: Cross-Document References Loading/Saving. [message #387072 is a reply to message #387063] Mon, 16 August 2004 15:39 Go to previous messageGo to next message
Thanks Ed.
How would you suggest I handle this? I really don't want to walk the entire
model to get everything loaded and I REALLY don't want a half-cooked model
serialized. I've got a separate "manifest" that tells me all the files that
make up the model. Should I just do a resourceSet.getResource(uri, true)
for each file? My first take would be that the LoadOnDemand parameter would
be false, but I get a null back when I try that. Any suggestions?
-Scott
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cfqfi5$unf$1@eclipse.org...
> Scott,
the
I
file,
I
I
try
walks
save
> >Thanks,
> >Scott
Re: Cross-Document References Loading/Saving. [message #387086 is a reply to message #387072] Mon, 16 August 2004 17:11 Go to previous messageGo to next message
--------------020307020408060003050202
Content-Type: text/plain; charset=us-ascii; format=flowed
Scott,
You haven't actually described anything that sounds like a problem.
What do you see as the problem?
One way to force all proxies to be resolved is to iterate over
ResourceSet.getAllContents and for each EObject, iterate over
eCrossReferences...
Scott Warren wrote:
>Thanks Ed.
>Thanks,
>-Scott
>>Scott,
>the
>I
>file,
>I
>I
>try
>walks
>save
>>>Thanks,
>>>Scott
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Scott,<br>
<br>
You haven't actually described anything that sounds like a problem.&nbsp;
What do you see as the problem?&nbsp;&nbsp; <br>
<br>
eCrossReferences...<br>
<br>
<br>
<br>
Scott Warren wrote:<br>
<blockquote cite="midcfqk9v$8nj$1@eclipse.org" type="cite">
<pre wrap="">Thanks Ed.
-Scott
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cfqfi5$unf$1@eclipse.org">news:cfqfi5$unf$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Scott,
Scott Warren wrote:
</pre>
<pre wrap="">Here's a situation where I could use some advice:
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->the
</pre>
<pre wrap="">model. This worked fine. I could load/save without any problems. Now,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->I
</pre>
<pre wrap="">have the requirement to make certain parts of the model "shareable". For
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->file,
</pre>
<pre wrap="">I've got quite a few (30+ in my unit test). So, it seems to save fine.
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">load the "root" (top-level) document and load appears to work fine until
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">go to save the model again. If I load the root document and immediately
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->try
</pre>
<pre wrap="">to save again (like a "Save As"), it appears that the other referenced
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->walks
</pre>
<pre wrap="">the object tree after the load, everything gets demand loaded and the
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->save
</pre>
<pre wrap="">works correctly. Shouldn't the reference to each object by the EMF
Scott
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------020307020408060003050202--
Re: Cross-Document References Loading/Saving. [message #387547 is a reply to message #387086] Tue, 07 September 2004 20:05 Go to previous messageGo to next message
Phong Nguyen Le is currently offline Phong Nguyen LeFriend
Is it possible to save a containment reference of a object as a
cross-document reference? In other words, I'd like to save the parent
and child in separate files.
Phong.
Ed Merks wrote:
> Scott,
> eCrossReferences...
> Scott Warren wrote:
>>Thanks Ed.
>>Thanks,
>>-Scott
>>>Scott,
>>the
>>I
>>file,
>>I
>>I
>>try
>>walks
>>save
>>>>Thanks,
>>>>Scott
Re: Cross-Document References Loading/Saving. [message #387551 is a reply to message #387547] Wed, 08 September 2004 00:27 Go to previous message
David Steinberg is currently offline David SteinbergFriend
Hi Phong,
In order to be able to enforce reasonable containment semantics, EMF
does not allow cross-document containment references. You'll need to
make the reference non-containment if you want it to associate objects
in separate files.
Dave
Previous Topic:Loading a remote URI resource
Next Topic:how do i use ecore.sdo to support other data source
Current Time: Sat Feb 24 12:44:13 GMT 2018
Powered by FUDForum. Page generated in 0.02158 seconds
