Home » Eclipse Projects » EclipseLink » Native Query issues
Native Query issues [message #385295] Sat, 24 January 2009 09:13 Go to next message
Ari Meyer is currently offline Ari MeyerFriend
I'm using EclipseLink 1.0.2, and I need to hit an Oracle 10.2 sequence
in ad hoc fashion (NOT when inserting a record), so I created a native
query like so (snippet):
final String query =
"SELECT proj_num_seq.nextval " +
"FROM dual ";
return (Long) _entityManager
.createNativeQuery(query)
.getSingleResult();
When this was executed, I got this bizarre error:
java.lang.ClassCastException:
org.eclipse.persistence.internal.helper.NonSynchronizedVecto r
So I see that it's returning a List, not the "single result" I
requested. Bug?
I then tried this:
List aList = (List) _entityManager
.getSingleResult();
return (Long) aList.get(0);
.... which resulted in:
java.lang.ClassCastException: java.math.BigDecimal
Finally, I ended up having to do this:
.getSingleResult();
return ((BigDecimal) aList.get(0)).longValue();
or this with generics:
List<BigDecimal> aList = (List<BigDecimal>)
_entityManager.createNativeQuery(query)
.getSingleResult();
return aList.get(0).longValue();
All good now!
But the first attempt should have worked correctly, right? It should
not have returned a List holding a BigDecimal (maybe just a BigDecimal
for me to deal with, which at least would have been somewhat
acceptable). Also, just for fun, when I tried it with getResultList()
instead of getSingleResult(), it wrapped the List in another List, which
is what I expected.
So is createNativeQuery(String).getSingleResult() misbehaving, or am I
doing something wrong? I didn't find any similar bug reports or news
postings.
Ari
Re: Native Query issues [message #385296 is a reply to message #385295] Sun, 25 January 2009 10:19 Go to previous messageGo to next message
Doug Clarke is currently offline Doug ClarkeFriend
This has been fixed since 1.0.2.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229627
You should now get either a Object or Object[] for a getSingleResult()
query execution. If you are querying for multiple rows the result will be
either List<Object> or List<Object[]>.
When issuing a native query the type returned is really database and JDBC
specific and could even vary between JDBC versions. When returning a
single number like this I tend to write my query execution like:
return ((Number) _entityManager
getSingleResult()).longValue();
Doug
Re: Native Query issues [message #385297 is a reply to message #385296] Sun, 25 January 2009 23:25 Go to previous messageGo to next message
Thanks Doug -- when are they planning to release a 1.0.3 (or whatever
new version)?
Ari
> be either List<Object> or List<Object[]>.
> JDBC specific and could even vary between JDBC versions. When returning
> a single number like this I tend to write my query execution like:
> Doug
Re: Native Query issues [message #385298 is a reply to message #385297] Mon, 26 January 2009 02:59 Go to previous messageGo to next message
We are working towards a 1.1 release in February. Our original date of Feb
4th will not work out we just got the final reviews completed on our IP
Log and will schedule the release review this week.
http://wiki.eclipse.org/EclipseLink/Development/RoadMap
Doug
Re: Native Query issues [message #385304 is a reply to message #385298] Tue, 27 January 2009 09:19 Go to previous message
Thanks Doug -- looking forward to it!
> Feb 4th will not work out we just got the final reviews completed on our
> IP Log and will schedule the release review this week.
> Doug
Previous Topic:Tree structure - avoid select on parent_id
Next Topic:JPQL and partial attributes
Current Time: Thu May 24 08:22:30 GMT 2018
Powered by FUDForum. Page generated in 0.02184 seconds
