Home » Modeling » EMF » edit a model in an eclipse view
| edit a model in an eclipse view [message #384989] |
Tue, 11 May 2004 08:21  |
Eike Stepper Messages: 5252 Registered: July 2009 |
i'd like to edit a model in an eclipse view and
started with the "new plug-in project" wizard.
i managed to replace the wizard's sample model
with the emf model from a resource by copying
some code from the emf generated editor to the
wizard generated view.
because of differences between an editor's and a
view's api, i was not able to copy some methods.
when running a run-time workbench, the model
is shown properly, but
1) there is no context menu
2) the command framework does not work,
moving and deleting has no effect
3) the properties view doesn't show anything
i've browsed the web and the newsgroup, but
couldn't find example code. don't you think, it
was nice to have a "generate View Code"
option in the genmodel?
here is my code:
package prototyping.views.views;
import org.eclipse.emf.common.command.BasicCommandStack;
import org.eclipse.emf.common.ui.viewer.IViewerProvider;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.emf.edit.domain.IEditingDomainProvider;
import org.eclipse.emf.edit.provider.ComposedAdapterFactory;
import org.eclipse.emf.edit.provider.ReflectiveItemProviderAdapterF actory;
import org.eclipse.emf.edit.provider.resource.ResourceItemProviderA dapterFactory;
import org.eclipse.emf.edit.ui.dnd.EditingDomainViewerDropAdapter;
import org.eclipse.emf.edit.ui.dnd.LocalTransfer;
import org.eclipse.emf.edit.ui.dnd.ViewerDragAdapter;
import org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er;
import org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider ;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.IMenuListener;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.action.Separator;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.ISelectionProvider;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerSorter;
import org.eclipse.swt.SWT;
import org.eclipse.swt.dnd.DND;
import org.eclipse.swt.dnd.Transfer;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.ui.part.DrillDownAdapter;
import org.eclipse.ui.part.ViewPart;
import org.eclipse.ui.views.properties.PropertySheetPage;
import prototyping.views.model.library.provider.LibraryItemProvider AdapterFactory;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Collection;
import java.util.Collections;
import java.util.Iterator;
import java.util.List;
* This sample class demonstrates how to plug-in a new workbench view. The view shows data obtained
* from the model. The sample creates a dummy model on the fly, but a real implementation would
* connect to the model available either in this or another plug-in (e.g. the workspace). The view
* is connected to the model using a content provider.
* <p>
* The view uses a label provider to define how model objects should be presented in the view. Each
* view can present the same model objects using different labels and icons, if needed.
* Alternatively, a single label provider can be shared between views in order to ensure that
* objects of the same type are presented in the same way everywhere.
* <p>
public class ProStepperView extends ViewPart implements IEditingDomainProvider, ISelectionProvider,
IMenuListener, IViewerProvider
* The constructor.
public ProStepperView()
// Create an adapter factory that yields item providers.
List factories = new ArrayList();
factories.add(new ResourceItemProviderAdapterFactory());
factories.add(new LibraryItemProviderAdapterFactory());
factories.add(new ReflectiveItemProviderAdapterFactory());
adapterFactory = new ComposedAdapterFactory(factories);
// Create the command stack that will notify this editor as commands are executed.
BasicCommandStack commandStack = new BasicCommandStack();
// Create the editing domain with a special command stack.
editingDomain = new AdapterFactoryEditingDomain(adapterFactory, commandStack);
resourceSet = editingDomain.getResourceSet();
URI uri = URI.createPlatformResourceURI("test/My.library");
Resource resource = resourceSet.createResource(uri);
try
resource.load(Collections.EMPTY_MAP);
catch (IOException ex)
ex.printStackTrace();
* This is a callback that will allow us to create the viewer and initialize it.
public void createPartControl(Composite parent)
viewer = new TreeViewer(parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
drillDownAdapter = new DrillDownAdapter(viewer);
viewer.setContentProvider(new AdapterFactoryContentProvider(adapterFactory));
viewer.setLabelProvider(new AdapterFactoryLabelProvider(adapterFactory));
viewer.setSorter(new NameSorter());
viewer.setInput(resourceSet);
createContextMenuFor(viewer);
* This creates a context menu for the viewer and adds a listener as well registering the menu for extension.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected void createContextMenuFor(TreeViewer viewer)
MenuManager contextMenu = new MenuManager("#PopUp");
contextMenu.add(new Separator("additions"));
contextMenu.setRemoveAllWhenShown(true);
contextMenu.addMenuListener(this);
Menu menu = contextMenu.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
getSite().registerContextMenu(contextMenu, viewer);
int dndOperations = DND.DROP_COPY | DND.DROP_MOVE | DND.DROP_LINK;
Transfer[] transfers = new Transfer[] { LocalTransfer.getInstance()};
viewer.addDragSupport(dndOperations, transfers, new ViewerDragAdapter(viewer));
viewer.addDropSupport(dndOperations, transfers, new EditingDomainViewerDropAdapter(
editingDomain, viewer));
* Passing the focus request to the viewer's control.
public void setFocus()
viewer.getControl().setFocus();
class NameSorter extends ViewerSorter
protected TreeViewer viewer;
protected DrillDownAdapter drillDownAdapter;
protected Action action1;
protected Action action2;
protected Action doubleClickAction;
protected ComposedAdapterFactory adapterFactory;
protected AdapterFactoryEditingDomain editingDomain;
protected ResourceSet resourceSet;
protected PropertySheetPage propertySheetPage;
* This keeps track of the selection of the editor as a whole.
protected ISelection viewerSelection;
* This keeps track of all the {@link org.eclipse.jface.viewers.ISelectionChangedListener}s that
* are listening to this editor.
protected Collection selectionChangedListeners = new ArrayList();
* This returns the editing domain as required by the {@link IEditingDomainProvider}interface.
* This is important for implementing the static methods of {@link AdapterFactoryEditingDomain}
* and for supporting {@link org.eclipse.emf.edit.ui.action.CommandAction}.
public EditingDomain getEditingDomain()
return editingDomain;
* This implements {@link org.eclipse.jface.viewers.ISelectionProvider}.
public void addSelectionChangedListener(ISelectionChangedListener listener)
selectionChangedListeners.add(listener);
* This implements {@link org.eclipse.jface.viewers.ISelectionProvider}to return this editor's
* overall selection.
public ISelection getSelection()
return viewerSelection;
public void removeSelectionChangedListener(ISelectionChangedListener listener)
selectionChangedListeners.remove(listener);
* This implements {@link org.eclipse.jface.viewers.ISelectionProvider}to set this editor's
* overall selection. Calling this result will notify the listeners.
public void setSelection(ISelection selection)
viewerSelection = selection;
for (Iterator listeners = selectionChangedListeners.iterator(); listeners.hasNext();)
ISelectionChangedListener listener = (ISelectionChangedListener) listeners.next();
listener.selectionChanged(new SelectionChangedEvent(this, selection));
//setStatusLineManager(selection);
public void menuAboutToShow(IMenuManager manager)
// TODO Auto-generated method stub
public Viewer getViewer()
return viewer;
/eike
| Re: edit a model in an eclipse view [message #384990 is a reply to message #384989] |
Tue, 11 May 2004 08:36   |
Ed Merks Messages: 25227 Registered: July 2009 |
Eike,
The list of nice to haves is endless. Generating a view that supports editing opens up a whole set of issues that
we can't address anytime soon.
> here is my code:
> * <p>
> * <p>
> * The constructor.
> try
> * @generated
> return viewer;
> /eike
| Re: edit a model in an eclipse view [message #384994 is a reply to message #384989] |
Tue, 11 May 2004 13:57   |
John Howard Messages: 83 Registered: July 2009 |
Member |
I had to do this for a project I was working on and although fiddly I
don't remember it being that difficult. I basically took the generated
Editor and generated ActionBarContributor and modified these to get the
view working. e.g. the Editor code extends ViewPart instead of
MultiPageEditorPart. I think in the end it took a couple of days to
sort out the issues. The main problem with editing the model in this
way is tracking changes and making sure everything is saved. Eclipse
handles all this for editors, but not for views.
John.
> here is my code:
> * <p>
> * <p>
> * The constructor.
> try
> * @generated
> return viewer;
> /eike
| Re: edit a model in an eclipse view [message #385006 is a reply to message #384994] |
Wed, 12 May 2004 04:34   |
john,
thanks for these more encouraging words ;-))
would you mind sharing your viewpart-code?
if i could spare the time of re-inventing the wheel,
i'd rather try to make some jet templates out of it
(and share it with the group of course).
/eike
"John Howard" <john.howard9@btinternet.com> schrieb im Newsbeitrag news:c7r3ov$7l2$1@eclipse.org...
> John.
> > here is my code:
> > * <p>
> > * <p>
> > * The constructor.
> > try
> > * @generated
> > return viewer;
> > /eike
| Re: edit a model in an eclipse view [message #385025 is a reply to message #385024] |
Thu, 13 May 2004 11:45   |
Eike,
Yes, I'm concerned about making breaking changes. It seems to me that all the actions would
potentially be desired in the view. Can you provide a simple example view part and show what
you changed in the framework to make it work? Then I'll give it some more thought. It does
sound useful, but I don't really understand how editing in views without an editor all hangs
together, e.g., how do you do a save?
Eike Stepper wrote:
> ed,
> no, until now i have only changed CreateChildAction,
> CreateSiblingAction and StaticSelectionCommandAction,
> but the view is quite new and might use more actions in
> the future. is it a question of effort or does it have negative
> side effects?
> the EditingDomainActionBarContributor will not be touched,
> since it is editor-specific. (btw: can you imagine, why a view
> has no ActionBarContributor? is the multiple-instances-per-view
> feature too new?)
> /eike
> "Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag news:40A39198.73A42F88@ca.ibm.com...
> Eike,
> There are quite a few uses of that:
> action/CommandAction.java
> action/CopyAction.java
> action/CreateChildAction.java
> action/CreateSiblingAction.java
> action/CutAction.java
> action/DelegatingCommandAction.java
> action/DeleteAction.java
> action/EditingDomainActionBarContributor.java
> action/LoadResourceAction.java
> action/PasteAction.java
> action/RedoAction.java
> action/StaticSelectionCommandAction.java
> action/UndoAction.java
> action/ValidateAction.java
> Did you have to change them all?
| Re: edit a model in an eclipse view [message #385026 is a reply to message #385025] |
Thu, 13 May 2004 12:11  |
ed,
i've attached three files. there's a ViewActionBarContributor that
would have to go into org.eclipse.emf.edit.ui.actions, too (for me).
it is extended by a special contributor (much like the EditingDomainActionBarContributor).
i have the feeling that these contributors simply came from
migrating the generated editor to a view, but now with multiple
instances of a view it seems a good idea anyway.
i'm quite new to the eclipse ui api, so if anyone would review
the viewpart and the contributor classes, i could try to make
jet templates out of them.
i will have to give saving more thoughts. for my application
i plan to present a save question to the user each time she/he
changes the selection. additionally the property sheet will have
a save button and dialogs will save on ok. but i find it interesting
to think about more general flows and how to implement them
(this way i could improve my understnding of the eclipse api).
/eike
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag news:40A39808.C252EBE1@ca.ibm.com...
> Eike,
Current Time: Tue Oct 08 08:05:55 EDT 2013
Powered by FUDForum. Page generated in 0.02423 seconds
