Home » Archived » GMT (Generative Modeling Technologies) » extend
extend [message #383949] Tue, 08 July 2008 20:19 Go to next message
Jim is currently offline JimFriend
Hello ...
I have an OAW extend file in a plugin called p1 ...
Is it possible to use the extend file from a 2nd plugins (p2) expand
file ? If so how do i referenece it?
<<EXTENSION ?? >>
Jim
Re: extend [message #383952 is a reply to message #383949] Tue, 08 July 2008 22:08 Go to previous messageGo to next message
Enrico Schnepel is currently offline Enrico SchnepelFriend
Hello Jim,
> <<EXTENSION ?? >>
You will have to enter the classpath with "::" instead of "." or "/". this
includes that p1 should be on the imported plugins and p1 should contain
the xtend file in a source folder.
Enrico Schnepel
Re: extend [message #383953 is a reply to message #383952] Wed, 09 July 2008 08:32 Go to previous messageGo to next message
Well, ehm, I should not answer questions after midnight... ;-)
It is the resource-path to find the .ext file without the classpath-part.
The oaw editors provide a completion if both projects are oaw projects.
Enrico
Re: extend [message #383956 is a reply to message #383953] Wed, 09 July 2008 13:44 Go to previous message
Thank you that worked ...
Jim
> Enrico
Re: extend [message #618233 is a reply to message #383949] Tue, 08 July 2008 22:08 Go to previous message
Hello Jim,
> <<EXTENSION ?? >>
Enrico Schnepel
Re: extend [message #618234 is a reply to message #383952] Wed, 09 July 2008 08:32 Go to previous message
Enrico
Re: extend [message #618235 is a reply to message #383953] Wed, 09 July 2008 13:44 Go to previous message
Jim
> Enrico
Previous Topic:extend
Next Topic:[Epsilon] Problem with HUTN and sqlmodel
Current Time: Fri Feb 23 08:59:56 GMT 2018
Powered by FUDForum. Page generated in 0.02006 seconds
