Home » Eclipse Projects » Buckminster » Save/Export Bill of Material (BOM) in headless build
Save/Export Bill of Material (BOM) in headless build [message #381643] Fri, 09 January 2009 10:24 Go to next message
Markus Kuppe is currently offline Markus KuppeFriend
how can I save/export the generated BOM during a headless build started
off from a CQUERY or MSPEC?
Markus
Re: Save/Export Bill of Material (BOM) in headless build [message #381644 is a reply to message #381643] Fri, 09 January 2009 10:58 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Marcus,
You do:
buckminster resolve --bomfile <bom output file> <query or mspec>
You can also prevent materialization at that point so that the query
resolution stops when the BOM is created by doing
buckminster resolve --bomfile <bom output file> --noimport <query or mspec>
Thomas Hallgren
Markus Alexander Kuppe wrote:
> Markus
Re: Save/Export Bill of Material (BOM) in headless build [message #381645 is a reply to message #381644] Fri, 09 January 2009 11:05 Go to previous messageGo to next message
Thomas Hallgren wrote:
> Hi Marcus,
> You do:
Hi Thomas,
thanks for the quick reply. Unfortunately this doesn't work with
"import". Is this intended or simply missing?
Markus
Re: Save/Export Bill of Material (BOM) in headless build [message #381646 is a reply to message #381645] Fri, 09 January 2009 11:31 Go to previous messageGo to next message
> Hi Thomas,
It was originally intended but the idea behind it is perhaps no longer
applicable. The resolve was originally intended to resolve from cquery
to bom and import was intended to actually materialize the bom. After
that, the resolve command was extended to also include the import and
the import was extended to automatically resolve when given a cquery
instead of a bom.
A better way would probably be to make resolve an alias for import and
move all functionality to that command. Can you please enter a bugzilla
for that?
- thomas
Re: Save/Export Bill of Material (BOM) in headless build [message #381654 is a reply to message #381646] Mon, 12 January 2009 10:29 Go to previous message
> for that?
https://bugs.eclipse.org/260675
Previous Topic:Version resolution problem
Next Topic:org.eclipse.buckminster.pde.targetOS and others don't take wildcard (*)
Current Time: Tue May 22 17:54:08 GMT 2018
Powered by FUDForum. Page generated in 0.02173 seconds
