Home » Eclipse Projects » Buckminster » targetPlatformPath and installLocation
targetPlatformPath and installLocation [message #381424] Mon, 01 December 2008 12:09 Go to next message
Markus Kuppe is currently offline Markus KuppeFriend
buckminster setpref targetPlatformPath=/foo/bar
buckminster import mymspec.mspec
still causes BM to materialize to ${buckminster.home} whereas I expect
it to use ${targetPlatformPath} instead (if installLocation isn't set in
the mspec). Is this a bug?
As a workaround how does one pass the installLocation property to BM to
set the mspec var without using a properties file?
Markus
Re: targetPlatformPath and installLocation [message #381426 is a reply to message #381424] Mon, 01 December 2008 13:11 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Markus Alexander Kuppe wrote:
Yes, this sounds like a bug. It should select whatever TP that is
defined in the WS that you're using. Can you please report it?
Thomas Hallgren
Re: targetPlatformPath and installLocation [message #381428 is a reply to message #381426] Mon, 01 December 2008 13:39 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257069
Previous Topic:eclipse.build actor failed - cannot find java.lang.Enum; Java 1.5 compliance preference set
Next Topic:SVN content materialization
Current Time: Sun Apr 22 10:56:40 GMT 2018
Powered by FUDForum. Page generated in 0.01460 seconds
