Home » Modeling » EMF » reading in XML file in generated editor
reading in XML file in generated editor [message #380908] |
Wed, 10 December 2003 18:37 |
Rajesh Kumar Messages: 17 Registered: July 2009 |
Junior Member |
I wrote an parser class inside the generated XEditor.java file and tried
to instantiate it in the XEditor() method (to call the parser when the
editor is being initialized)
However when I know run the plugin it gives an error saying
"Exception creating editor: Unable to instantiate editor:
verify.presentation.VerifyEditorID java.lang.NoClassDefFoundError:
org/xml/sax/HandlerBase"
My guess is that this is a classpath problem somewhere.
I had written the XML parser class inside the XEditor.java file
extending "HandlerBase" as follows (I had also added "import
org.xml.sax.AttributeList;
import org.xml.sax.HandlerBase;
import org.xml.sax.Parser;
import org.xml.sax.SAXException;
import org.xml.sax.SAXParseException;
import org.xml.sax.helpers.ParserFactory;
import org.xml.sax.XMLReader;
import org.apache.xerces.parsers.SAXParser;
import java.io.*;" at the top of the file)
class ParseProj extends HandlerBase
public ParseProj(String fileName)
try
Parser myParser = new SAXParser();
myParser.setDocumentHandler(this);
myParser.parse(fileName);
catch(Exception e)
System.out.println("Exc " + e);
}//end of constru
public void startDocument()
} // startDocument()
public void endDocument()
} // endDocument()
public void startElement(String name, AttributeList attrs)
} // startElement(String,AttributeList)
public void endElement(String name)
} // endElement(String)
public void characters(char ch[], int start, int length)
} // characters(char[],int,int);
public void processingInstruction(String target, String data)
} // processingInstruction(String,String)
public void ignorableWhitespace(char ch[], int start, int length)
} // ignorableWhitespace(char[],int,int);
}//end of ParseProj
Re: reading in XML file in generated editor [message #380909 is a reply to message #380908] |
Wed, 10 December 2003 18:43 |
Junior Member |
I am running Eclipse 2.1 with EMF 1.2.1. The code which I added in the
XEditor.java method was
try{
System.out.println("calling the parser");
ParseProj pux = new ParseProj("proj.svm");
}catch(Exception e){
System.out.println(e.toString());
> try
> catch(Exception e)
> }//end of constru
> } // endDocument()
> }//end of ParseProj
Re: reading in XML file in generated editor [message #380910 is a reply to message #380909] |
Wed, 10 December 2003 19:38 |
Ed Merks Messages: 33141 Registered: July 2009 |
Rajesh,
You'll need to add org.apache.xerces to your plugin.xml.
> try{
> > try
> > catch(Exception e)
> > }//end of constru
> > } // endDocument()
> > }//end of ParseProj
Ed Merks
Re: reading in XML file in generated editor [message #380914 is a reply to message #380910] |
Thu, 11 December 2003 04:31 |
Junior Member |
Thanks for the quick response!
Ed Merks wrote:
> Rajesh,
>> try{
>>> try
>>> catch(Exception e)
>>> }//end of constru
>>> } // endDocument()
>>>}//end of ParseProj
Current Time: Thu Apr 25 15:20:45 GMT 2024
Powered by FUDForum. Page generated in 0.02649 seconds
