Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript] Problems with creating and editing a MOFSCript File
[MOFScript] Problems with creating and editing a MOFSCript File [message #379047] Wed, 22 August 2007 15:16 Go to next message
Toñi Reina is currently offline Toñi ReinaFriend
I have worked with previous releases of MOFScript. I stopped for a
while, and now, I want to start again to create MOFScript files.
As I'm working with other Eclipse plugins that require the Eclipse
Europe release (that is the Version 3.3.0), I'll try to install MOFScript in
this new Eclipse version.
The installation has been made through the following update site:
http://www.modelbased.net/mofscript/update/
But when I start Eclipse I have two problems. On the one hand, I can't
edit my old .m2t mofscript files. And on the other hand, I can't create a
new MOFScript file. When I try to select New > Other > MOFScript > MOFScript
File, I obtain the following error:
The selected Wizard could not be started. Reason: Plugin
org.sintef.mofscript.editor was unable to load class
org.sintef.mofscript.editor.wizards. MofScript new Wizard.
The details are,
The selected wizards could not be started.
It seems that I have installed MOFScript 1.2.4 .
Is this error related to Eclipse Europe? and if so, are there any plans to
migrate MOFScript to Eclipse Europe?
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379048 is a reply to message #379047] Thu, 23 August 2007 06:44 Go to previous messageGo to next message
Gøran K. Olsen is currently offline Gøran K. OlsenFriend
Hello To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379049 is a reply to message #379048] Thu, 23 August 2007 11:21 Go to previous messageGo to next message
Dear G
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379050 is a reply to message #379049] Thu, 23 August 2007 11:52 Go to previous messageGo to next message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379051 is a reply to message #379050] Thu, 23 August 2007 12:05 Go to previous messageGo to next message
See the answers inline
"G
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379052 is a reply to message #379051] Thu, 23 August 2007 12:13 Go to previous messageGo to next message
I also have tried to do the same operation starting Eclipse with the -clean
option, but problems remain the same.
"To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379053 is a reply to message #379051] Thu, 23 August 2007 12:26 Go to previous messageGo to next message
Reinstallation made.
It seems that although the .jar files have been deleted from the plugin
directory, there are some directories left. At last, I have been able to
install the plugin again by erasing manually these directories.
However, despite having installed again the plugin, the initial problem
remains the same, that is, neither I can edit my older mofscript files nor I
can create new ones.
"To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379054 is a reply to message #379053] Mon, 27 August 2007 08:51 Go to previous messageGo to next message
Finally, I've made the installation. It seems that although the .jar files
I
> "To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379561 is a reply to message #379054] Thu, 30 August 2007 14:19 Go to previous messageGo to next message
Ondrej Rohlik is currently offline Ondrej RohlikFriend
I had the same experience with me Topcased 1.0.0 installation that I was
using for about a month or so.
I could not open the m2t files. Also I could not open MOFSript preferences.
The installation was smooth with brand new Topcased installation. It is
the same Topcased version that I used before -- the only difference was
that the new one was fresh, not spoiled with other plugins.
I know I am not giving you the best advice...
This is the Topcased in question:
http://gforge.enseeiht.fr/frs/download.php/617/org.topcased. toolkit.rcp-win32-I200707051726.zip
Good luck!
> I
>> "Toñi Reina Quintero" <reinaqu@lsi.us.es> escribió en el mensaje
>> news:fajt6d$10e$1@build.eclipse.org...
>>> "Gøran K. Olsen" <Goran.K.Olsen@Sintef.no> escribió en el mensaje
>>> news:fajse7$sac$1@build.eclipse.org...
>>>> Toñi ,
>>>> Some questions,
>>>> Did you remove the mofscript feature and plugins manually by deleting
>>>> them in the features and plugins directory first. (All versions)?
>>> No, I did it with the configuration Manager :
>>> Help>SoftwareUpdates>Manage Configuration, and then going back to an
>>> earlier configuration. After that I have checked if the org.simtef.*
>>> files were at the features and plugin directories, and efectively they
>>> have been removed. Furthermore, I also have checked if the plugin is
>>> avalaible with Help > About Eclipse > Plugins installed, and Features
>>> installed, but it isn't.
>>>> Started eclipse with -clean?
>>> No, I have started without that option.
>>>> Used the update manager from modelbased:
>>>> http://www.modelbased.net/mofscript/update/ ?
>>> Yes, and also the other one.
>>>> I could not find anything wrong with the update site.
>>>> /Gøran
>>>> "Toñi Reina Quintero" <reinaqu@lsi.us.es> wrote in message
>>>> news:fajqk1$nj5$1@build.eclipse.org...
>>>>> Dear Gøran,
>>>>> I've been following your advice, and as the MOFScript plugin was the
>>>>> last one I had installed, I have turned back to a previous
>>>>> configuration, having, in this way, the plugin uninstalled. However,
>>>>> when I try to install again the plugin using the update manager, I
>>>>> obtain the following message:
>>>>> No features found on the selected site(s). Choose a different site or
>>>>> site category.
>>>>> I have tried the update from the two following web sites:
>>>>> http://download.eclipse.org/technology/gmt/mofscript/update/
>>>>> and
>>>>> I also have tried to find the binary .zip file corresponding to the
>>>>> 1.2.4 plugin version, but I haven't been able to find it anywhere.
>>>>> Are there any problems with the update sites?
>>>>> Is the zip file avaible somewhere?
>>>>> Regards,
>>>>> Toñi
>>>>> news:fajad1$5c2$1@build.eclipse.org...
>>>>>> Hello Toñi,
>>>>>> I believe a reinstallation and a startup using -clean will do it.
>>>>>> When it comes to MOFScript and Europa, I have installed and used it
>>>>>> without proplems, but there are some minor issues that will be
>>>>>> addressed in the next release (in a week or so).
>>>>>> Regards,
>>>>>> Gøran
>>>>>> news:fahk18$j06$1@build.eclipse.org...
>>>>>>> Hello,
>>>>>>> a while, and now, I want to start again to create MOFScript files.
>>>>>>> MOFScript in this new Eclipse version.
>>>>>>> can't edit my old .m2t mofscript files. And on the other hand, I
>>>>>>> can't create a new MOFScript file. When I try to select New > Other >
>>>>>>> MOFScript > MOFScript File, I obtain the following error:
>>>>>>> The details are,
>>>>>>> plans to migrate MOFScript to Eclipse Europe?
>>>>>>> Regards,
>>>>>>> Toñi
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #379564 is a reply to message #379561] Fri, 31 August 2007 10:40 Go to previous messageGo to next message
Thanks, maybe you could bring light to the problem, because I also have
installed the Topcased toolset.
But let me repeat it, cause I think I didn't undersstand very well the
solution.
You state that you solved the problem installing again the topcased toolset,
but instead of using the update site, you have used the packages you have
referenced below. Then, you have installed again the mofscript plugin. Is
that right?
If this is right, it means that there is some kind of incompatibility
between MOFScript and some other plugin.
"Ondrej Rohlik" <rohlik@control.ee.ethz.ch> escribi
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #380585 is a reply to message #379564] Thu, 20 December 2007 00:07 Go to previous messageGo to next message
Hello!
Sorry for very very VERY late reply.
I just want to say that I still do have the same problem as you, Toni.
To make it crystal clear I say: I DO NOT HAVE SOLUTION. I don't state I
solved the problem.
When experimenting with the various Topcased 1.0 installations trying to
make the MOFScript working, I got one configuration which is working.
The problem is that I don't know/remember what installations step led to
this specific configuration. I just did pack the installation to a ZIP
file and keep it on a safe place together with my MOFScript development
workspace. It is my precious [Tolkien 1937].
It is also interesting that when I use this precious Topcased
configuration and switch to OTHER Topcased 1.0 workspace then, our error
is back and (!) even when going back to the prevously working workspace
I still have the error. I can't open the m2t files any longer! The only
way out is to delete the Topcased installation and unpack my precious to
be able to open m2t files again.
Conclusion:
The error is still there and is really really strange.
I haven't tried upgrading to Topcased 1.1 or 1.2. Have you?
Ondrej 2
> solution.
> that right?
> "Ondrej Rohlik" <rohlik@control.ee.ethz.ch> escribió en el mensaje
> news:fb6jl2$3bq$1@build.eclipse.org...
>> preferences.
>> Good luck!
>>> nor I
>>>>>> Toñi ,
>>>>>> Some questions,
>>>>>> /Gøran
>>>>>>> Dear Gøran,
>>>>>>> the last one I had installed, I have turned back to a previous
>>>>>>> site category.
>>>>>>> and
>>>>>>> Regards,
>>>>>>> Toñi
>>>>>>>> Hello Toñi,
>>>>>>>> Regards,
>>>>>>>> Gøran
>>>>>>>>> Hello,
>>>>>>>>> for a while, and now, I want to start again to create MOFScript
>>>>>>>>> files.
>>>>>>>>> Eclipse Europe release (that is the Version 3.3.0), I'll try to
>>>>>>>>> install MOFScript in this new Eclipse version.
>>>>>>>>> site:
>>>>>>>>> The details are,
>>>>>>>>> Regards,
>>>>>>>>> Toñi
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #380595 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous messageGo to next message
No, I haven't tried a new topcased release. What I have finally done is to
have two different Eclipse versions: Eclipse 3.2.2 with MOFScript, and
Eclipse Europa with Topcased.
Thanks for your late response,
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #380597 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous messageGo to next message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #380599 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607044 is a reply to message #379047] Thu, 23 August 2007 06:44 Go to previous message
Hello To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607045 is a reply to message #379048] Thu, 23 August 2007 11:21 Go to previous message
Dear G
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607047 is a reply to message #379049] Thu, 23 August 2007 11:52 Go to previous message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607048 is a reply to message #379050] Thu, 23 August 2007 12:05 Go to previous message
"G
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607050 is a reply to message #379051] Thu, 23 August 2007 12:13 Go to previous message
"To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607051 is a reply to message #379051] Thu, 23 August 2007 12:26 Go to previous message
"To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607053 is a reply to message #379053] Mon, 27 August 2007 08:51 Go to previous message
I
> "To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607066 is a reply to message #379054] Thu, 30 August 2007 14:19 Go to previous message
Good luck!
> I
>>>> Toñi ,
>>>> Some questions,
>>>> /Gøran
>>>>> Dear Gøran,
>>>>> site category.
>>>>> and
>>>>> Regards,
>>>>> Toñi
>>>>>> Hello Toñi,
>>>>>> Regards,
>>>>>> Gøran
>>>>>>> Hello,
>>>>>>> The details are,
>>>>>>> Regards,
>>>>>>> Toñi
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #607072 is a reply to message #379561] Fri, 31 August 2007 10:40 Go to previous message
solution.
that right?
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #611029 is a reply to message #379564] Thu, 20 December 2007 00:07 Go to previous message
Hello!
solved the problem.
Conclusion:
Ondrej 2
> solution.
> that right?
>> preferences.
>> Good luck!
>>> nor I
>>>>>> Toñi ,
>>>>>> Some questions,
>>>>>> /Gøran
>>>>>>> Dear Gøran,
>>>>>>> site category.
>>>>>>> and
>>>>>>> Regards,
>>>>>>> Toñi
>>>>>>>> Hello Toñi,
>>>>>>>> Regards,
>>>>>>>> Gøran
>>>>>>>>> Hello,
>>>>>>>>> files.
>>>>>>>>> site:
>>>>>>>>> The details are,
>>>>>>>>> Regards,
>>>>>>>>> Toñi
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #611089 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #611091 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous message
To
Re: [MOFScript] Problems with creating and editing a MOFSCript File [message #611093 is a reply to message #380585] Sat, 22 December 2007 11:32 Go to previous message
To
Previous Topic:[TCS] development of a TCS tool
Next Topic:[TCS] playing with km3 metamodel and syntax
Current Time: Thu Apr 19 17:47:45 GMT 2018
Powered by FUDForum. Page generated in 0.02540 seconds
